Nguyên văn bởi sonmai
Mở luồng mới cho các vấn đề liên quan tới EAGLE
Nguyên văn bởi cocconden Xem bài viếtbác Sonmai có cái ""ấy"" của thằng DipTrace ko,,,,vẽ nó mà bị giời hạn 400pin cũng khổ
• Online DRC - dynamically checks design rules while you add objects, route traces or edit anything in layout. Static DRC check was improved and optimized.
• 3D VRML 2.0 Export of PC board. Allows you to export solid body of your board with models to mechanical CAD.
• Custom Non-Signal layers.
• Arranging PCB components by hierarchical blocks. Copying routing/placement between similar blocks.
• Automatic showing/hiding ratlines for copper pours depending on pouring areas and traces ("Hide Net Ratlines" option has been removed).
• Pour priority for copper pour.
• Separate "Place Ratline" mode, no more ratlines in "default" and "edit traces" modes.
• "Manual Route" mode hot-key (~).
• Configuring and saving file names for Gerber export by layers (name and extension for each layer).
• Exporting dimensions into Gerber and DXF.
• Checking pin/wire superimposing without connection in Schematic ERC.
• Saving connections without wires while copying/pasting parts in Schematic.
• Moving objects between pages in Schematic.
• Rearranging sheets in Schematic.
• Saving "open/save dialog" initial folders by file type (globally for all programs).
• Blocking file by the program while editing it. Overwriting by second/network appearance is prohibited.
• Backward compatibility of binary file formats starting from this version (it can open files of further versions).
• Windows 8 compatibility.
• Ordering engine has been added (see File/Order PCB).
• Online check for new versions and DipTrace news.
• Library update: 8000+ new components, euro symbols, new patterns.
Bảng 2.3.0 full, tớ tìm lại key (cái ""ấy"") sẻ gởi qua mail sau.Last edited by sonmai; 25-04-2013, 23:18.
Nguyên văn bởi newfolder92 Xem bài viếtnhìn con dip trace có vẻ ngon nghẻ hơn em kia thì phải...
Hôm qua, 07:44 -
Hôm qua, 02:00 -
22-02-2025, 22:18 -
22-02-2025, 14:51 -
22-02-2025, 14:39 -
22-02-2025, 14:28 -
21-02-2025, 20:26 -
21-02-2025, 12:32 -
20-02-2025, 21:31 -
