Phần mềm vẽ mạch in PowerPCB-PADS
  • Phần mềm vẽ mạch in PowerPCB-PADS
    Mục này dành để trao đổi về PowerPCB-PADS. Đề nghị các bạn không xin phần mềm và c***k ở đây.
    Chao cac bac. Bay gio minh se pót tat ca kien thuc cua PCB pads Layout len cho tat ca moi nguoi tham khao nhe. Nho các bác giup va phien dich ra nhe. Thanks.
    minh se post tat ca neu các bác hợp tác dịch tài liệu cùng mình nhé
    Creating Assembly Options Tutorial
    You can quickly and easily document design variations made from a single source PCB design. You can define variants through a simple, table-driven user interface. As variations are added, designers can preview them with a graphical preview.
    In this lesson:
    y Defining an assembly option
    Restriction
    This tutorial requires the Assembly Variants and CAM licensing options. On the
    Help menu, click Installed Options to determine whether you can proceed.
    Preparation
    If it is not already running, start PADS Layout and open the file named
    previewole.pcb in the \PADS Projects\Samples folder.
    You define assembly variants using the Assembly Options dialog box. You must first define a new variant name and then assign the component status of
    installed, not installed, or substituted for each member of the variant.
    Creating a variant
    Tools menu > Assembly Options
    To create an assembly option:
    1. In the New option's name box, type Build01.
    2. In the Option area, click Create. You can now define a Build01 assembly.
    Copyright © Mentor Graphics Corporation 2005
    All Rights Reserved.
    This document contains information that is trade secret and proprietary to Mentor Graphics Corporation or its licensors and is subject to license terms. No part of this document may be photocopied, reproduced, translated, distributed, disclosed or provided to third parties without the prior written consent of Mentor Graphics.
    Trademarks that appear in Mentor Graphics product publications that are not owned by Mentor Graphics are trademarks of their respective owners.
    Creating Assembly Options Tutorial 1
    Assigning component status
    Remove components from the new assembly option by changing the status of some components.
    To change component status:
    1. In the Name column, Shift+click U1 and U2.
    2. In the Status area at the top of the dialog box, select Not Installed. The
    Status for U1 and U2 changes to Not Installed.
    Previewing the build assignment
    Examine an assembly drawing of the new assembly option to see the changes.
    To preview the option:
    1. In the Option area, click Preview.
    Result: A preview for Build01 appears in a new window. Notice the disappearance of U1 and U2 (the two large SO28s).
    2. In the Preview window, click Options. The Preview/Option dialog box appears.
    3. On the line for the Build01 option, double-click the Not Installed cell. A list
    of viewing options appears.
    4. Select Color to open the Colors dialog box.
    5. Select the red color and click OK.
    Result: All of the Not Installed components in Build01 are now red.
    6. Click OK in the Preview/Option dialog box.
    In the preview for Build01 window you can now see a view of the board that shows which components are installed for the assembly option Build01.
    Tip: You can zoom in by clicking and zoom out by right-clicking.
    7. When you finish viewing the preview for Build01, click Close.
    Although no change is made to the design itself, Reports and CAM outputs can be created based on the assembly option instead of the base option.
    Creating an option parts list
    Use the Report option in the Assembly Options dialog box to generate reports including parts lists based on the option and not the original design.
    To create a report:
    1. In the Option area, click Reports. The Reports dialog box appears.
    2. In the Select Report Files for Output list, select Parts List 1
    3. Select the Use Assembly Option check box.
    Creating Assembly Options Tutorial 2
    4. In the Name list, select Build01.
    5. Click OK to produce the report.
    Result: The parts list appears in the default text editor. Examine the list and note the <Not installed> text for U1 and U2.
    6. Close the report file.
    7. In the Assembly Options dialog box, click OK to save the assembly option definition and close the dialog box.
    Creating an option assembly CAM document
    File menu > CAM > Add
    When outputting an Assembly CAM document, click the Assembly button in the Customize Document section of the Add/Edit Document dialog box to use the option for its generation.
    To create a CAM document for a variant:
    1. In the Document Type list, select Assembly.
    2. When the Layer Association dialog box appears, click OK to accept the default Primary Component Side setting.
    3. In the Customize Document area, click the Assembly button.
    4. In the Select Assembly Option dialog box, select the Use Assembly Option
    check box.
    5. In the Name list, select Build01, and then click OK.
    The Assembly document produced will be based on the chosen option.
    6. In the Add Document dialog box, click Preview Selections.
    7. In the CAM Preview window that opens, click Board. Note the absence of the
    U1 and U2 SO28 devices that were located on the Primary Component Side.
    8. Close all open CAM windows.
    9. Do not save a copy of the design.
    You completed the creating assembly options tutorial.
    Creating Assembly Options Tutorial 3
    Mong cac bác nao quan tâm hãy dich ra rùi mình gởi tiếp nhé...tất cả sẽ hoàn tất nếu hợp tác vui vẽ nhé các bác. hhhheheeeee
      thanks ! Nhân tiện cho mình hỏi , để thay đổi linh kiện theo 1 góc khác ngoài 90, lật theo chiều X, Y thì ta có thể tạo góc bất kì cho linh kiện đc không ? Ví dụ góc 135
        Được. Muốn linh kiện quay một góc bất kỳ làm như sau: Chọn "Component"/ CTRL + Q/ Rotation ---> Nhập vào góc nào mà bạn muốn. 0-360
          ko biết bạn có bị nhầm không? Khi bấm Ctrl+Q thì hộp thoại Query/Modify Part xuất hiện và không hề có Rotation . Cái này mình cũng tửng thử rồi, quay linh kiện mình muốn nói đến là trong phần Pads Logic .
            day ne
            Tạo Options hội Hướng dẫn
            Bạn nhanh chóng và dễ dàng có thể tài liệu thiết kế biến thể được làm từ một thiết kế đơn PCB nguồn. Bạn có thể định nghĩa các biến thể thông qua một giao diện đơn giản, người sử dụng bàn điều khiển. Khi các biến thể được thêm vào, các nhà thiết kế có thể xem trước chúng với một bản xem trước đồ họa.
            Trong bài học này:
            Xác định y là một lựa chọn lắp ráp
            Hạn chế
            Hướng dẫn này yêu cầu các biến thể hội và các tùy chọn cấp phép CAM. Trên
            Trợ giúp của trình đơn, nhấn chọn cài đặt để xác định xem bạn có thể tiến hành.
            Chuẩn bị
            Nếu nó không phải là đang chạy, bắt đầu miếng Giao diện và mở các tập tin có tên
            previewole.pcb trong thư mục \ mẫu miếng dự án \.
            Xác định là một lựa chọn lắp ráp
            Bạn xác định các biến thể lắp ráp bằng cách sử dụng hộp hội thoại Options. Bạn phải xác định một tên biến thể mới và sau đó giao cho tình trạng thành phần của
            cài đặt, không được cài đặt, hoặc thay thế cho mỗi thành viên của biến thể này.
            Tạo một biến thể
            Menu Tools> Options hội
            Để tạo ra một tùy chọn lắp ráp:
            1. Trong hộp tên các tùy chọn mới của, đánh Build01.
            2. Trong khu vực lựa chọn, nhấp vào Tạo. Bạn có thể xác định một hội đồng Build01.
            Bản quyền © Tổng công ty Mentor Graphics 2005
            Tất cả các quyền.
            Tài liệu này chứa thông tin đó là bí mật thương mại và sở hữu độc quyền cho Tổng công ty Mentor Graphics hoặc cấp giấy phép và chịu sự điều khoản cấp phép. Không có một phần của tài liệu này có thể được sao, sao chép, dịch, phân phối, công bố hoặc cung cấp cho bên thứ ba mà không được sự đồng ý trước bằng văn bản của Mentor Graphics.
            Thương hiệu xuất hiện trong ấn phẩm Mentor Graphics sản phẩm không thuộc sở hữu của Mentor Graphics là thương hiệu của chủ sở hữu tương ứng.
            Tạo Options hội Hướng dẫn 1
            Phân công các thành phần trạng thái
            Hủy bỏ các thành phần từ các tùy chọn lắp ráp mới bằng cách thay đổi trạng thái của một số thành phần.
            Để thay đổi trạng thái thành phần:
            1. Trong cột Name, Shift + click U1 và U2.
            2. Trong khu vực Tình trạng ở phía trên cùng của hộp thoại, chọn Không phải cài đặt. Các
            Tình trạng thay đổi U1 và U2 để không cài đặt.
            Xem trước xây dựng giao
            Kiểm tra một bản vẽ lắp ráp các tùy chọn lắp ráp mới để xem các thay đổi.
            Để xem các tùy chọn:
            1. Trong khu vực Tùy chọn, bấm vào Xem trước.
            Kết quả: Một bản xem trước cho Build01 xuất hiện trong một cửa sổ mới. Thông báo sự biến mất của U1 và U2 (hai lớn SO28s).
            2. Trong cửa sổ Preview, kích chọn Options. Xem trước / hộp thoại Option xuất hiện.
            3. Trên đường cho các tùy chọn Build01, kích đúp vào các tế bào không phải cài đặt. Một danh sách
            các tùy chọn xem xuất hiện.
            4. Chọn màu để mở hộp thoại Colors.
            5. Chọn màu đỏ và click OK.
            Kết quả: Tất cả các thành phần không được cài đặt trong Build01 bây giờ màu đỏ.
            6. Click OK trong / Xem trước hộp thoại Option.
            Trong cửa sổ xem trước cho Build01 bạn có thể nhìn thấy một cái nhìn của hội đồng quản trị đó cho thấy các thành phần được cài đặt cho các tùy chọn lắp ráp Build01.
            Mẹo: Bạn có thể phóng to bằng cách click và thu nhỏ bằng cách kích chuột.
            7. Khi đã xem xong xem trước cho Build01, click Close.
            Mặc dù không thay đổi được thực hiện để thiết kế riêng của mình, báo cáo và CAM ra có thể được tạo ra dựa trên các tùy chọn lắp ráp, thay vì lựa chọn cơ bản.
            Tạo một tùy chọn danh phận
            Sử dụng các tùy chọn báo cáo trong hộp hội thoại Options để tạo các báo cáo bao gồm các bộ phận danh sách dựa trên các tùy chọn và không phải là thiết kế ban đầu.
            Để tạo một báo cáo:
            1. Trong khu vực lựa chọn, báo cáo nhấn chuột. Hộp thoại báo cáo xuất hiện.
            2. Trong Báo cáo tập tin để chọn ra danh sách, chọn phần Danh mục 1
            3. Chọn Sử dụng hộp hội lựa chọn.
            Tùy chọn Tạo hội Hướng dẫn 2
            4. Trong danh sách Name, chọn Build01.
            5. Click OK để tạo báo cáo.
            Kết quả: Danh sách các phần xuất hiện trong trình soạn thảo văn bản mặc định. Kiểm tra danh sách và lưu ý các <Not installed> văn bản cho U1 và U2.
            6. Đóng tập tin báo cáo.
            7. Trong hộp hội thoại Options, nhấn OK để lưu các định nghĩa tùy chọn lắp ráp và đóng hộp thoại.
            Tạo ra một hội đồng lựa chọn tài liệu CAM
            File menu> CAM> Add
            Khi xuất ra một hội CAM tài liệu, nhấn nút hội trong phần Tùy chỉnh tài liệu của Add / Edit Document hộp thoại để sử dụng tùy chọn cho thế hệ của mình.
            Để tạo một tài liệu CAM cho một biến thể:
            1. Trong danh sách Loại văn bản, chọn hội.
            2. Khi hộp thoại Layer Hiệp hội xuất hiện, nhấp OK để chấp nhận các thiết lập mặc định phụ tiểu hợp phần.
            3. Trong khu vực Tùy chỉnh tài liệu, nhấn nút hội.
            4. Trong hộp thoại Select hội Option, chọn tùy chọn Sử dụng hội
            kiểm tra hộp.
            5. Trong danh sách Name, chọn Build01, sau đó kích OK.
            Các tài liệu hội sản xuất sẽ được dựa trên các tùy chọn đã lựa chọn.
            6. Trong hộp thoại Add tài liệu, bấm vào Xem trước Selections.
            7. Trong cửa sổ CAM Xem trước mở ra, nhấp vào Hội đồng. Lưu ý sự vắng mặt của
            thiết bị SO28 U1 và U2 mà được đặt ở bên phần chính.
            8. Đóng tất cả cửa sổ đang mở CAM.
            9. Không lưu một bản sao của thiết kế.
            Bạn hoàn tất các tùy chọn lắp ráp tạo ra các hướng dẫn.
            Tạo Options hội Hướng dẫn 3
            NgheĐọc ngữ âm
            Mới! Nhấp vào các từ bên trên để xem các bản dịch thay thế. Loại bỏ
            Từ điểnGoogle Dịch cho:Tìm kiếmVideoEmailĐiện thoạiTrò chuyệnDoanh nghiệpGiới thiệu về Google DịchTắt dịch nhanhBảo mậtTrợ giúp
            ©2010Công cụ cho Doanh nghiệpBộ công cụ DịchGiới thiệu về Google DịchBlogBảo mậtTrợ giúp
              a
              goolge dịch ah, vãi đạn. Ko bít dịch thì đề nghị đừng post tùm lum nha ! nản
                Hiện giờ mình đang rất bực mình với phần mêm này,sofware cài kiểu gì mà không thấy trong bộ cài,cài vào giờ gỡ ra không được.Nó còn lưu giữ cả lịch làm việc của mình dạng text.Chạy chương trình mà không có trong process,mình thật không hiểu nó đang làm cái trò gì nữa.Các bạn cẩn thận có thể có keylog trong đó nếu dowload phải soft lởm
                Viet Thinh Tìm hiểu thêm về Viet Thinh
