ảnh của em nó đây
Cadence Allegro
Nguyên văn bởi dinhchithanh Xem bài viếtGặp cao thủ ở ĐN, định vào làm quen nhưng chạy đâu mất roài.
co gi ma chay
rat vui duoc lam
quen
Đã có Cadence Allegro SPB / OrCAD 16.3 rồi đó các bạn.Link download ở dưới bài viết.Nhưng mình chưa Cr**ck được,bạn nào đã Cr**ck rồi thì hãy share hướng dẩn cho mình và anh em điên tử với nhé!!!!thanks trước nha.hjhj
Cadence SPB / OrCAD 16.30.000 (2009)
1.76 GB | UG
Cadence SPB / OrCAD 16.30.000 is a comprehensive package of design of electronic circuits, analog and digital simulation, IC design of programmable logic and custom circuits, as well as the development and preparation for the production of printed circuit boards.
This release combines previously unreleased separate products from Cadence - Allegro SPB and OrCAD. When you install you must install one of the Cadence SPB 16.3 ticks or Cadence OrCAD 16.3. Package OrCAD is a subset of SPB. So if you want to set the maximum option - select the SPB and do not choose OrCAD. Choice of two options will not add additional programs or Fitch.
Installing Cadence SPB / Orcad 16.3
1. Install the license server
2. Overwrite file cdslmd.exe in the installation folder of the license manager on the tablet attached to the
3. Create an environment variable with the value CDS_LIC_FILE this_host @ 5280. this_host replaced with the name of your machine (My computer-> properties-> advanced-> enviromnent variables)
4. Edit the first line in the file license163.lic - replace this_host to the real name of your computer
5. Run LicenseServerConfiguration.exe folder license manager (LicenseManager)
6. In the Select license, select the edited file license163.lic
7. Click Next
8. In the Port number edit check the value 5280
9. In the editing window Host Name check your machines hostname (computer name)
10. Click Next
11. Click Next again
12. Click Finish
13. Reboot
14. Set Cadence SPB / OrCAD 16.3
15. Copy the files from a folder Aspirinpatch in the installation directory
16. Start RunMe!. Bat
17. Wait
18. Wait a little
19. Enjoy the Cadence SPB / OrCAD 16.3
System requirements:
Operating system: Windows 2008 Server, Windows 2003 Server, all Service Packs (only 32-bit); Windows XP Professional; Windows Vista (32 and 64 bit) except Home Basic.
Processor: Intel IA-32 compatible (including Intel P4 EMT and AMD OpteronTM); 1.2 GHz minimum, recommended 2.4 GHz or more.
Memory: At least 1 GB of physical RAM, 2 GB recommended
Virtual memory: at least twice the available physical memory.
Disk space: minimum of 10 GB, 50 GB recommended
Display: 1024×768 @ 64000 colors recommended 1280×1024 @ 32-bit color
Cadence SPB / OrCAD 16.30.000 (Allegro SPB)
Year: 2009
Version: 16.30.000
Developer: Cadence
Platform: Windows
Compatibility with Vista: Yes
Language: English
Tabletka: Present
Download Links
Single extraction. All links are interchangeable (take 1 part from 1 host, take another part from another host save on waiting times).
http://ugotfile.com/file/698882/Cade...6.3.part01.rar
http://ugotfile.com/file/698884/Cade...6.3.part02.rar
http://ugotfile.com/file/698885/Cade...6.3.part03.rar
http://ugotfile.com/file/698887/Cade...6.3.part04.rar
http://ugotfile.com/file/698886/Cade...6.3.part05.rar
http://ugotfile.com/file/698889/Cade...6.3.part06.rar
http://ugotfile.com/file/698888/Cade...6.3.part07.rar
http://ugotfile.com/file/698891/Cade...6.3.part08.rar
http://ugotfile.com/file/698894/Cade...6.3.part09.rar
http://ugotfile.com/file/698895/Cade...6.3.part10.rar
http://ugotfile.com/file/698898/Cade...6.3.part11.rar
http://ugotfile.com/file/698900/Cade...6.3.part12.rar
http://ugotfile.com/file/698902/Cade...6.3.part13.rar
http://ugotfile.com/file/698901/Cade...6.3.part14.rar
http://ugotfile.com/file/698905/Cade...6.3.part15.rar
http://ugotfile.com/file/698915/Cade...6.3.part16.rar
http://ugotfile.com/file/698914/Cade...6.3.part17.rar
http://ugotfile.com/file/698916/Cade...6.3.part18.rar
No pass.Last edited by tinhkiet; 23-03-2010, 14:52.
Yahoo!:caotinheltn9999
0982473586
Nguyên văn bởi longkhanh58 Xem bài viếtCadence Allegro 16.01
http://rapidshare.com/files/15628572....01.part01.rar
http://rapidshare.com/files/15628573....01.part02.rar
http://rapidshare.com/files/15070438....01.part03.rar
http://rapidshare.com/files/15070439....01.part04.rar
http://rapidshare.com/files/15628587....01.part05.rar
http://rapidshare.com/files/15628587....01.part06.rar
http://rapidshare.com/files/15660440....01.part07.rar
http://rapidshare.com/files/15660441....01.part08.rar
http://rapidshare.com/files/15664860....01.part09.rar
http://rapidshare.com/files/15664860....01.part10.rar
http://rapidshare.com/files/15691216....01.part11.rar
http://rapidshare.com/files/15691217....01.part12.rar
http://rapidshare.com/files/15692062....01.part13.rar
http://rapidshare.com/files/15692062....01.part14.rar
http://rapidshare.com/files/15694982....01.part15.rar
http://rapidshare.com/files/15694983....01.part16.rar
http://rapidshare.com/files/15693607....01.part17.rar
Hi các bác,
Bên mình hiện đang là phân phối của Cadence tại Việt Nam. Các bác có nhu cầu về PCB , IC design software của Cadence thì cho em biết nhé.
Đây là website công ty mình : http://www.ftdsolutions.com/
Thanks các bác ! Chúc anh em DTVN sức khỏe, thành công !
Nguyên văn bởi trungcad Xem bài viếtMình cũng dùng cái này rồi mà của công ty xin nó ko cho!mình có file cài của allegro 15.2,15.5 rồi bạn nào biết cách cài chỉ mình với.Vì mình cài mãi ma ko dược thế mới đau!thank"winner never quit, quitter never win"
Nguyên văn bởi trungcad Xem bài viếtUhm! chuẩn đấy sao bạn biết rành thế
Nguyên văn bởi baohvs Xem bài viếtbản 16.2 tôi đang dung rất ổn
thân chào.=====================================
Nhận thiết kế mạch in bằng Allegro tại nhà với
các version từ 13.6,14.2, 15.7,16.3 )
Trả lời cho Cần Cao Thủ Giải Bài Tập Lý Thuyết Mạchbởi SangchunhatAi tốt môn này không ạ, hỗ trợ e phát
hôm nay, 09:51 -
bởi SangchunhatEm cần cao thủ giỏi giải bài tập đề thi Lý Thuyết Mạch
Bác nào làm được inboxx em với
Có gửi cafe cảm ơn
Xin cảm ơn ạ-
hôm nay, 08:56 -
Trả lời cho Hàn chì thiếc lên nhôm.bởi vi van phamSai bét. Bà í không biết cầm mỏ hàn điện (phải viết to chữ điện), nên tui ra chơi với diễn đàn . Chớ thấy vậy mà chê bai tui.
Hôm qua, 20:54 -
Trả lời cho Biết gì nói nấy, cãi chửi thoải máibởi nhathung1101Và mai tôi lại phải bay...
Chỉ mong muốn anh em hiểu: Là đừng làm dối lòng, khiến đàn em nức nở..
Cứ cãi nhau, ra việc lớn. Chứ đừng vì cái "tôi" rồi làm hỏng bọn chúng..
Ai hiểu cứ nói. Ai thấy sai cứ cãi. Kỹ thuật là vậy. Chỉ đúng khi có kết quả.-
Hôm qua, 20:37 -
Trả lời cho Biết gì nói nấy, cãi chửi thoải máibởi nhathung1101Xin thưa là tôi rất dốt món Ing Lịch. Chỉ là các bạn đưa lên những từ không ai hiểu, nên tôi phải theo.
Chứ ngày xưa được huấn luyện, cũng không như bạn nói đâu, và bạn Mỹ của tôi, hiểu như người nhà.
Bạn học giỏi thì đưa mấy từ lên đây đi, về điện tử thuần túy để anh em nghiên cứu....-
Hôm qua, 19:59 -
Trả lời cho Biết gì nói nấy, cãi chửi thoải máibởi nhathung1101Tôi "cũng tưởng thế". Nhưng giờ tôi sẽ để họ hiểu "Phổ biến kiến thức đường phố" nó khác thế nào.
Mời bạn theo dõi tiếp....-
Hôm qua, 19:53 -
Trả lời cho Biết gì nói nấy, cãi chửi thoải máibởi nhathung1101Lão lại quên: Nhất Thủy nhì Hỏa
Hà Nội lụt thì toi cả quần chip....-
Hôm qua, 19:49 -
Trả lời cho Biết gì nói nấy, cãi chửi thoải máibởi nhathung1101Cứ cãi chửi nhau đi mà...
Nhưng nhớ là vào đây cãi chửi nhau, chứ mấy luồng kỹ thuật bên ngoài thì làm cho đúng.
Ai thích cãi chửi nhau cứ vào đây gặp tôi!-
Hôm qua, 19:45 -
Trả lời cho Hàn chì thiếc lên nhôm.bởi nhathung1101
Lão lại bị bà í bắt ngủ riêng rồi....
Hôm qua, 19:38 -
Trả lời cho Sạc bình acquy 30ahbởi nhathung11014r có luồng "Đánh giá...." sao không đăng???
Đề nghị bqv chuyển luôn. Và xóa bài của tôi luôn cho gọn....-
Hôm qua, 19:32 -
