Mình mới học sử dụng Orcad để vẽ mạch nguyên lý.khi kiểm tra sơ đồ nguyên lý thì mắc phải lỗi này mọi người sửa giúp với.
Sửa lỗi trong orcad.?
Nguyên văn bởi tuantu90 Xem bài viếtMình mới học sử dụng Orcad để vẽ mạch nguyên lý.khi kiểm tra sơ đồ nguyên lý thì mắc phải lỗi này mọi người sửa giúp với.
Bạn chú ý nối nguồn vào GND và VCC là được
minh có mach dieu khien robot bang gsm nhung bi loi trong orcad,bạn nào giúp mình được k?Attached Files
The following 1 points have been identified as net connectivity change points from the last operation
(3.10, 4.80)
* Design Rules Check
Checking Pins and Pin Connections
Checking Schematic: SCHEMATIC1
Checking Electrical Rules
ERROR [DRC0004] Possible pin type conflict U7,VS Power Connected to Output: SCHEMATIC1, PAGE1 (2.70, 6.00)
Checking for Unconnected Nets
WARNING [DRC0006] Net has fewer than two connections GND: SCHEMATIC1, PAGE1 (6.40, 4.40)
WARNING [DRC0006] Net has fewer than two connections VCC: SCHEMATIC1, PAGE1 (6.40, 2.00)
Checking for Invalid References
Checking for Duplicate References
cho hoi lam sao khac phuc loi tren
(3.10, 4.80)
Bạn nào cho mình biết cách sửa các lỗi trên không?
Netlist Format: LAYOUT
Design Name: D:\ELECTRONICS\ROBOTMACH\TD1.DSN
ERROR [MNL0019] 'U7.4' is tied to nets '5V' and 'C'.
ERROR [MNL0019] 'U8.4' is tied to nets '5V' and 'C'.
ERROR [MNL0019] 'U7.7' is tied to nets 'CAMBIEN2' and 'A'.
ERROR [MNL0019] 'U8.7' is tied to nets 'A' and 'CAMBIEN6'.
ERROR [MNL0019] 'U8.6' is tied to nets 'LEDTHU6' and 'B'.
ERROR [MNL0019] 'U7.2' is tied to nets 'D' and 'LEDTHU1'.
ERROR [MNL0019] 'U9.6' is tied to nets 'B' and 'C ROLE3'.
ERROR [MNL0019] 'U9.3' is tied to nets 'N75689' and 'C PWM2'.
ERROR [MNL0019] 'U9.9' is tied to nets 'GND_EARTH' and 'F'.
ERROR [MNL0019] 'U7.9' is tied to nets 'LEDTHU3' and 'F'.
ERROR [MNL0019] 'U9.4' is tied to nets 'C' and 'C ROLE2'.
ERROR [MNL0019] 'U7.1' is tied to nets 'CAMBIEN1' and 'E'.
ERROR [MNL0019] 'U9.1' is tied to nets 'C PWM1' and 'E'.
ERROR [MNL0019] 'U8.10' is tied to nets 'G' and 'N1302749'.
ERROR [MNL0019] 'U9.7' is tied to nets 'A' and 'C PWM4'.
ERROR [MNL0019] 'U9.2' is tied to nets 'D' and 'C ROLE1'.
ERROR [MNL0019] 'U7.6' is tied to nets 'B' and 'LEDTHU2'.
ERROR [MNL0019] 'U9.10' is tied to nets 'G' and '12V'.
ERROR [MNL0019] 'R15.2' is tied to nets 'N761071' and 'P2.6'.
ERROR [MNL0019] 'U8.9' is tied to nets 'F' and 'LEDTHU7'.
ERROR [MNL0019] 'U8.1' is tied to nets 'E' and 'CAMBIEN5'.
ERROR [MNL0019] 'U7.10' is tied to nets 'G' and 'N1301047'.
ERROR [MNL0019] 'U7.3' is tied to nets 'N761071' and 'N75597'.
ERROR [MNL0019] 'U8.3' is tied to nets 'N75643' and 'N1301862'.
ERROR [MNL0019] 'U8.2' is tied to nets 'D' and 'LEDTHU5'.
ERROR [MNL0019] 'R15.1' is tied to nets 'GND' and 'N15670591'.
ERROR [MNL0023] 32 errors found in file.
ERROR [NET0011] Netlist failed or may be unusable.Attached Files
* Create Netlist
Netlist Format: EDIF200
Design Name: D:\ORCAD16.5\WIRELESS CONTROL.DSN
WARNING: Name contains illegal characters 'IRF540N/TO', changed to IRF540NBARTO
WARNING: Name contains illegal characters 'RELAY DPDT', changed to RELAY_DPDT
WARNING: Name contains illegal characters 'CAP NP', changed to CAP_NP
WARNING: Name contains illegal characters 'CONNECTOR DB9', changed to CONNECTOR_DB9
WARNING: Name contains illegal characters 'LCD 16X2', changed to LCD_16X2
WARNING: Name contains illegal characters 'SW PUSHBUTTON', changed to SW_PUSHBUTTON
WARNING [DRC0006] Net has fewer than two connections SDA: SCHEMATIC1, PAGE1 (3.90, 2.60)
WARNING [DRC0006] Net has fewer than two connections GND_POWER: SCHEMATIC1, PAGE1 (0.90, 4.10)
WARNING [DRC0006] Net has fewer than two connections ENCODER: SCHEMATIC1, PAGE1 (4.90, 4.20)
WARNING [DRC0006] Net has fewer than two connections SCL: SCHEMATIC1, PAGE1 (4.10, 2.60)
WARNING [DRC0006] Net has fewer than two connections LCD_D6: SCHEMATIC1, PAGE1 (3.70, 1.40)
WARNING [DRC0006] Net has fewer than two connections LCD_D7: SCHEMATIC1, PAGE1 (3.80, 1.40)
WARNING [DRC0006] Net has fewer than two connections LCD_E: SCHEMATIC1, PAGE1 (3.00, 1.40)
bởi nguyendinhvanTại sao nó lại có cơ sở dữ liệu như thế này.
Ciệc kiếm một danh sách điện thoại dể quảng cáo ,tiếp thị, thậm chí là cả việc xấu hoàn toàn dễ dàng.
Channel: Công nghệ internet và mạng có dây
Hôm qua, 22:26 -
Hôm qua, 08:30 -
Hôm qua, 07:21 -
Hôm qua, 07:02 -
bởi vi van phamNhắn tin khẩn:
Hôm qua, 05:57 -
26-04-2025, 23:16 -
26-04-2025, 21:33 -
26-04-2025, 20:52 -
Trả lời cho Tổng hợp quạt điện : điện tử , Cơ , phun sươngbởi Nikon57Mình có cái quạt trần điện cơ, xông điện vào không chạy . Dỡ xuống tháo ra quan sát thấy một đầu dây trong một bối dây bị đứt thò ra goài. Quạt cố, cả cuộn làm việc và cuồn đề bố trí thành một vòng . Xin xem ảnh kèm theo. Đo trở...
26-04-2025, 15:09 -
Trả lời cho Xin hỏi về chiết ápbởi mèomướpDạ cháu hông có tiền để mua điện thoại riêng chơi mạng xã hội đâu ạ. Chú có điều kiện thì tài trợ cho cháu cái ai phôn 16 pờ rồ mắc để cháu học dùng facebook rồi kết bạn với chú ạ...
26-04-2025, 13:14 -
