Hướng dẫn cài Orcad 15.7
    bác nào có orcad 15.7 không gửi cho em qua email:hatran_hieu@yahoo.com
    em xin cảm ơn
      Hướng dẫn cài đặt ngắn gọn đây:
      Cadence OrCAD 15.7
      Install Instruction :
      1-At the first copy "Keygen.exe" from "Keygen" directory into your Hard Disk.
      Then run it; Enter your "Enternet Address" into HOSTID dialog box and press
      "Generate" button to get License file.
      2-Open "license.dat" with NotePad and edit it.
      *Replace "this_host" in first line of "license.dat" with Your Computer Name.
      *Replace the "DAEMON cdslmd" term in second line of "license.dat" with "DAEMON cdslmd ./cdslmd.exe".
      3-After that, Run "Setup.exe" and install product. In "Install Options" screen
      click on "Set Up Licensing" and press next. In the next screen click on "Browse"
      button; choose "license.dat" and click next several time to install License Manager.
      Press Ok and Ignore the "Failure to parse FLEXLm license file" error when
      "License Manager Test Failed" appeare.
      4-Then install OrCAD 15.7 . At the "Control File Location" dialog, just clear up
      the text box (BLANK) and then press next. Now you have to choose products to install
      and finally press next several times to finish installation.
      ***Note:
      In addition to that:
      * A bit further in the license manager install it will complain there is no file "controlfile.txt".
      Make a copy of the "license.dat" file, and name it "controlfile.txt".
      Put this file in the same directory as the license manager.
      Other info that you might find useful: Most of the products in the list of products-to-install overlap.
      They are bundles that include the other products.
      As far as I can tell, you will have a full install with all of Orcad's products when you install options
      PO1110, PO1320, PO1331, PO1332, PO1336, PO1340, PO1420, PO1600, PO3400.
      Leave the rest unchecked.
      Last edited by van8x10; 25-09-2007, 09:48. Lý do: Sao thêm file đính kèm không được nhỉ?
        híc
        các bác giúp em zoi'
        em tải chương trình về rùi nhưng giải nén thì nó bảo "you need to start eptraction from a previous volume to uptrack ORCAD 15.7\NRclient\data1.cab
          Winh nào biết xin chỉ dzùm
          đang cài ngon lành nó báo bỏ disk 2 dzô vì thiếu data3.cab
          mình bó tay luôn
          tải về đầy đủ giải nén ra không báo lỗi nhưng không có file data3.cab
          mình phải làm sao đây ai bít chỉ dùm xin cám ơn nhiều
          orcad 9.2 mình dùng rồi bây giờ muốn tìm hiểu thêm 15.7
          chúc mọi người mạnh khỏe nhé.
            Nguyên văn bởi caynhalavuon Xem bài viết
            mình bó tay luôn
            Tui cũng bị như dzậy .
              Nguyên văn bởi cooloo Xem bài viết
              Mình chỉ up len đĩa 1, khi cài các bạn chỉ chọn Capture với Layout Plus thôi là đủ! Vậy nhé!
                Các bro cho em hỏi bản orcad 15.7 này có cài đc lên vista ko ạ? Em vẫn dùng 9.2 nhưng cài lên vista thì ko chạy. hizz... Em cũng chưa thử bản 10.5 ko biết thế nào?...
                  Tui đang xaì 9.2 với XP , thử chạy 15.7 với XP works good . Chưa thử với dzịt ta .
                    hix
                    êm cài cái bản 1o.5 vô mà không được,
                    nền thiết kế là nền trắng mà của êm lại là nền đen
                    các bác giúp êm zới
                      Nguyên văn bởi neo9x Xem bài viết
                      hix
                      các bác giúp êm zới
                      Cái này thì dễ như ăn ốc rùi . Em vào cái color của nó mà sửa lại . Trong phần color chỉ cần right click thì muốn chọn màu nào cũng được . Chừng nào đi HN nhớ đãi tui tô bún ốc .
                        anh nao` pro làm ơn chỉ dùm em cái , cài cả ngày mà ko được huhun nếu có chỉ thì pót mấy cái hình lên cho em coi với đọc cũng hok hiêu hjx dân cùi bắp mà ocard 15.7 đó hen , thanks trước
                          Nguyên văn bởi bgvye44 Xem bài viết
                          Anh natra2k2 cho bạn cách cài đặt ở trang đầu tiên . Có hình ảnh rỏ ràng không thể chê vào đâu được . Bạn bị kẹt chổ nào ? Bạn post hình lên cho mọi người đi .
                          • #28
                            ai biet cai cadence ko? minh co dia ban 15.5 ma cai ko duoc. ai biet chi gium minh voi!
                            • #29
                              minh co dia allegro cadence 15.5 ma ko cai duoc, ai biet chi minh voi!
                              • #30
                                Chùi lèm gì mà post 2 lần dữ vậy ?
                                natra2k2 Tìm hiểu thêm về natra2k2
                                  hôm nay, 14:51
                                  hôm nay, 14:39
                                  hôm nay, 14:28
                                  Hôm qua, 20:26
                                  Hôm qua, 12:32
                                  20-02-2025, 11:52
                                  Cái khó bó cái...
                                  19-02-2025, 23:05
                                  19-02-2025, 21:27
