Hướng dẫn cài đặt ngắn gọn đây:
Cadence OrCAD 15.7
Install Instruction :
1-At the first copy "Keygen.exe" from "Keygen" directory into your Hard Disk.
Then run it; Enter your "Enternet Address" into HOSTID dialog box and press
"Generate" button to get License file.
2-Open "license.dat" with NotePad and edit it.
*Replace "this_host" in first line of "license.dat" with Your Computer Name.
*Replace the "DAEMON cdslmd" term in second line of "license.dat" with "DAEMON cdslmd ./cdslmd.exe".
3-After that, Run "Setup.exe" and install product. In "Install Options" screen
click on "Set Up Licensing" and press next. In the next screen click on "Browse"
button; choose "license.dat" and click next several time to install License Manager.
Press Ok and Ignore the "Failure to parse FLEXLm license file" error when
"License Manager Test Failed" appeare.
4-Then install OrCAD 15.7 . At the "Control File Location" dialog, just clear up
the text box (BLANK) and then press next. Now you have to choose products to install
and finally press next several times to finish installation.
***Note:
In addition to that:
* A bit further in the license manager install it will complain there is no file "controlfile.txt".
Make a copy of the "license.dat" file, and name it "controlfile.txt".
Put this file in the same directory as the license manager.
Other info that you might find useful: Most of the products in the list of products-to-install overlap.
They are bundles that include the other products.
As far as I can tell, you will have a full install with all of Orcad's products when you install options
PO1110, PO1320, PO1331, PO1332, PO1336, PO1340, PO1420, PO1600, PO3400.
Leave the rest unchecked.
Lý do: Sao thêm file đính kèm không được nhỉ?
híc
các bác giúp em zoi'
em tải chương trình về rùi nhưng giải nén thì nó bảo "you need to start eptraction from a previous volume to uptrack ORCAD 15.7\NRclient\data1.cab
Winh nào biết xin chỉ dzùm
đang cài ngon lành nó báo bỏ disk 2 dzô vì thiếu data3.cab
mình bó tay luôn
tải về đầy đủ giải nén ra không báo lỗi nhưng không có file data3.cab
mình phải làm sao đây ai bít chỉ dùm xin cám ơn nhiều
orcad 9.2 mình dùng rồi bây giờ muốn tìm hiểu thêm 15.7
chúc mọi người mạnh khỏe nhé.
mình bó tay luôn
Các bro cho em hỏi bản orcad 15.7 này có cài đc lên vista ko ạ? Em vẫn dùng 9.2 nhưng cài lên vista thì ko chạy. hizz... Em cũng chưa thử bản 10.5 ko biết thế nào?...
hix
êm cài cái bản 1o.5 vô mà không được,
nền thiết kế là nền trắng mà của êm lại là nền đen
các bác giúp êm zới
Cái này thì dễ như ăn ốc rùi . Em vào cái color của nó mà sửa lại . Trong phần color chỉ cần right click thì muốn chọn màu nào cũng được . Chừng nào đi HN nhớ đãi tui tô bún ốc .
anh nao` pro làm ơn chỉ dùm em cái , cài cả ngày mà ko được huhun nếu có chỉ thì pót mấy cái hình lên cho em coi với đọc cũng hok hiêu hjx dân cùi bắp mà ocard 15.7 đó hen , thanks trước
Anh natra2k2 cho bạn cách cài đặt ở trang đầu tiên . Có hình ảnh rỏ ràng không thể chê vào đâu được . Bạn bị kẹt chổ nào ? Bạn post hình lên cho mọi người đi .
Một số kết quả test với mô-tơ quạt khác.
[Video test các loại cánh quạt chứng tỏ loại 7 cánh hiệu...
Xin upload kết quả thí nghiệm, mọi người sẽ tự hiểu và biết phân tích đúng sai hợp lí hay không. Ai không biết kĩ thuật thì chẳng dám tin vào cảm giác của bản thân, chỉ tin những gì nsx nói, dù họ có nói phét thế nào!!!
Em rất là quý bac, nhưng hôm nay em thấy bác sai đấy.
Cái sai của bác là đem cái cơ sở lý luận kỹ thuật công nghệ của Tư bản Chủ nghĩa để trao đổi với người theo Chủ Nghĩa Kinh Nghiệm. ...
Tốn wifi 4G quá !
Cộng với một bản số liệu...
Cánh nhỏ là của tàu đem qua giờ mình copy theo mà tàu thì chuyên ăn bớt vật liệu để giảm giá thành từ cánh cho đến mô tơ mới thành ra vậy .
Cách thử của dinhthuong có đúng thì chỉ đúng với cái quạt Senko còn với quạt khác mô tơ...
Thôi, bác cứ tin nsx thì để tối nay cháu sẽ test 2 cây quạt cùng hãng Senko, một cây 3 cánh lớn 47W-57.6m3/min và 1 cây 65W-88.6m3/min xem nsx có nói láo không ạ, cứ cái nào cùng số bật mà thổi cho cái quạt hư kia quay được nhiều vòng hơn là...
