Cần giải thích mạch máy bơm nước IC555
  • Cần giải thích mạch máy bơm nước IC555
    Working of Automatic water tank level controller
    - We know the property of 555 timer IC, i.e. its output goes HIGH when voltage at the second pin(trigger pin) is less than 1/3 Vcc.
    Also we can reset back the IC by applying a LOW voltage at the 4th pin (Reset pin).
    - In this project 3 wires are dipped in water tank. Let us define two water levels- Bottom (Low) level and Top (Up) level. One of the wire or probe is from Vcc.
    - The probe from bottom level is connected to the trigger (2nd) pin of 555 IC. So the voltage at 2nd pin is Vcc when it is covered by water.
    When water level goes down, the 2nd pin gets disconnected(untouched) from water i.e. voltage at the trigger pin becomes less than Vcc. Then the output of 555 becomes high.
    - The output of 555 is fed to a BC548 transistor, it energizes the relay coil and the water pump set is turned ON.
    While the water level rises, the top level probe is covered by water and the transistor becomes ON. Its collector voltage goes to Vce(sat) =0.2.
    The low voltage at the 4th pin resets the IC. So the output of 555 becomes 0V. Hence the motor will turn OFF automatically.
    - For simple demonstration of this project you can use a DC motor directly at the output of 555 instead of relay.
    - For practical implementation, you must use a relay. Rating of relay is chosen according to the load (Motor). 32 Ampere relay is best suited for domestic applications.
    Máy bơm nước tự động khi mực nước dưới hoặc = chân low thì chạy, đến chân high thì dừng bơm dùng mạch này dc ko ạ, ai có thể giải thích hộ mình dc ko?? Xin cảm ơn.
    Bạn xem sơ đồ trải của IC 555 sẽ giải thích được ngay.
    cauutonline Tìm hiểu thêm về cauutonline
