Mình có đề bài bằng tiếng Anh nhưng không hiểu đề cho lắm, mong mọi người giúp đỡ giải thích hộ
Thanks,
Thanks,
Design a circuit that has a 2-bit input that is a binary number and an
output that goes high when the input is the largest input that has been
seen since the last reset. The output should go high as soon as
possible. Reset will reset the machine such that an input of 00 will be
the largest input seen so far. When reset is high, however, the output
should always be low. Draw a state diagram for this circuit and
determine the next state and output equations.
