- All-in-ONE embedded network solution
- Hardwired TCP/IP stack
-Fully software compatible with industrial;
- Pipelined architecture which enables execution of instructions 4~5 times;
- 2 Data Pointers (DPTRs) for fast memory blocks processing
> Advanced INC & DEC modes
> Auto-switch of current DPTR;
- Internal 2K Byte boot ROM;
- Internal 64K Bytes embedded program FLASH memory;
- Internal 256 Bytes embedded data FLASH memory;
- Internal 64K Bytes SRAM;
- External 11.0592 MHz operation frequency for internal PLL logic;
- Interrupt controller
> 2 priority levels
> 4 external interrupt sources
> 1 watchdog interrupt;
- Four 8-bit I/O Ports;
- Three timers/counters;
- Full-duplex UART;
- Programmable watchdog timer;
- DoCD&trade compatible debugger;
- Support hardwired TCP/IP protocols;
- Support 8 independent SOCKETs simultaneously;
- Support hybrid TCP/IP stack;
- Internal 32K Bytes memory for TCP/IP data communication;
- 10BaseT/100BaseTX Ethernet PHY embedded;
- Auto Negotiation (Full-duplex and half duplex);
- Auto MDI/MDIX.
Thanks các bác
> 2 priority levels
- Full-duplex UART;
- Auto MDI/MDIX.
Thanks các bác
