em đã làm theo hưỡng dẫn nhưng không thể nào cài được ocad!bác nào biết nguyên nhân chỉ jup em cái?
bước 4 hình như chẳng có tác dụng j?nếu như ta ấn cancel?
em đổi tên ocad16.lic thế đã đúng chưa?
tai sao khi nhấn Satrt/Stop/Reread lai báo như hình vẽ!(cad)
bác nào đã từng cài thành công rồi xinh chỉ jao!
đừng bảo em quay lại dùng bản 9.2 đấy nhé!
Thank các bác nhiều!
HD:
1. Install the license manager first by choosing Set Up Licensing from setup.exe.
Donot enter any paths. for license file. Leave it blank.
2. Copy the contents of license_manager from SHooTERS folder to installed dir C:OrCADlicense_manager.
Overwrite files.
3. Open orcad16.lic (stored on the hard drive not from the CD) in text editor and replace this_host with the
name of the Computer (in the first line of the file), and save the file.
4. Run setup again and choose Set up License and enter the path of license file C:OrCAD\license_manager\orcad16.lic
.Click Next. Ignore the failure error and press Cancel.
5. Run setup again, and choose Install products, enter port as 5280 and host id/name as the name of your Computer.
Next select the apps you want to install. Leave the installinfo and contr.. file paths blank.
6. After the installation is completed, go to Start->Programs->Cadence License Manager->License Manager Tools
and change the path of license file to
C:OrCAD\license_manager\orcad16.lic in the Config Services tab. (it would be some license.dat initially)
7. Click on Start Server button in the Satrt/Stop/Reread tab of the license manager utility.
Next click on Reread License File. Wait for the reread operation to be completed (see status bar).
8. Now check if the Cadence License Manager
service is running in the Control Panel->Administrator Tools->Services.
9. Run orcad_16.0_patcher.exe.
10. Done
If you get the ERROR message "The procedure entry point RWSetO2K3Color
could not be located in the dynamic link library RWUXThemeS.dll",
go in to environment variables and move the link "%CDSROOT%\tools\bin" in the Path variable to the beginning of it.
1. ban vào thu muc C:\OrCAD\OrCAD_16.0\tools\bin copy file RWUXThemeS.dll
roi paste nó vào thu muc C:\OrCAD\OrCAD_16.0\tools\capture
2. viec thu 2 can phai làm bây gi?: là click chu?t ph?i
vào My computer -> propreties -> advanced -> environment variables r?i tìm dòng nhu hình v?
HD:
Overwrite files.
10. Done
