Hien tai e co con amply 8so tu rap.nghe nhac rat ok.nhung khi hat karaoke mo volume 50% thi...1ve loa ben phai bi ngat=>mat tieng,mat nhac 1ben.2loa e da test lai,deu ok het.bay gio chi con phan amply.xin cac cao thu huong dan e cach khac phuc.tks...online bang dt nen ko go dau dc,xin mod thong cam
Can giup do ve amply
https://vn.shp.ee/dWYVgq7-
Hôm qua, 12:48 -
Hôm qua, 11:55 -
Hôm qua, 00:47 -
Hôm qua, 00:16 -
19-01-2025, 19:00 -
19-01-2025, 15:47 -
18-01-2025, 20:47 -
18-01-2025, 20:42 -
18-01-2025, 18:56 -
17-01-2025, 21:36 -
