Điều Khiển Động Cơ DC
  • Điều Khiển Động Cơ DC
    Mình đang làm mạch điều khiển động cơ DC, nhưng khi mô phỏng với Proteus ko chạy. Ai bjt lỗi gì ko?
    Mô phỏng Proteus: http://www.mediafire.com/?tkk2cghepz34vp5
    CODE:
    #include <16F877A.h>
    #fuses NOWDT,PUT,HS,NOPROTECT,NOLVP
    #use delay(clock=10000000)
    #use fast_io(b)
    #define tocdo0 0 //toc do bang 0
    #define td_macdinh 80 //toc do mac dinh
    #define tocdo1 124 //1/5 toc do cuc dai
    #define tocdo2 248 //2/5 toc do cuc dai
    #define tocdo3 372 //3/5 toc do cuc dai
    #define tocdo4 496 //4/5 toc do cuc dai
    #define tocdo5 620 //toc do cuc dai
    #byte PORTB =0x06
    int16 duty1=0;
    int16 duty2=0;
    int8 bientocdo=0;
    int1 bienthuan=0;
    int1 biennghich=0;
    void main() //bo PMW1 dk dong o quay thuan
    { //bo PMW2 dk dco quay nghich
    set_tris_b(0x0ff); //khoi tao port B la port nhap
    setup_ccp1(CCP_PWM); //khoi tao bo PWM1
    setup_ccp2(CCP_PWM); //khoi tao bo PWM2
    setup_timer_2(T2_div_by_16,154,1); //tao chu ky xung 1ms
    //(1/clock)*4*t2div*(period+1)
    //(1/10e6)*4*16*(154+1)=1e-3=1ms
    set_pwm1_duty(duty1);
    set_pwm2_duty(duty2);
    //gia tri duty cua PWM duoc tinh theo cong thuc duty1*t2div/clock
    //khoi tao duty=0 -> tat dong co
    while(true)
    if (!bit_test(portb,1)) //neu nhan phim FO : chay thuan
    duty1=tocdo0;
    duty2=tocdo0;
    set_pwm1_duty(duty1); //cho duty cua 2 bo PMW=0 de
    set_pwm2_duty(duty2); //tat dong co
    delay_ms(1000); //delay 1s de giam quan tinh dong co
    bienthuan=1;
    biennghich=0;
    goto next;
    if (!bit_test(portb,2)) //neu nhan phim RE : chay nghich
    duty1=tocdo0;
    duty2=tocdo0;
    delay_ms(1000); //delay 1s de giam quan tinh dco
    bienthuan=0;
    biennghich=1;
    goto next;
    if (!bit_test(portb,3)) //nhan phim toc do 1
    bientocdo=1;
    goto next;
    if (!bit_test(portb,4)) //nhan phim toc do 2
    bientocdo=2;
    goto next;
    if (!bit_test(portb,5)) //nhan phim toc do 3
    bientocdo=3;
    goto next;
    if (!bit_test(portb,6)) //nhan phim toc do 4
    bientocdo=4;
    goto next;
    if (!bit_test(portb,7)) //nhan phim toc do 5
    bientocdo=5;
    next:
    if (!bit_test(portb,0)) //neu nhan phim OFF
    duty1=tocdo0;
    duty2=tocdo0;
    bienthuan=0;
    biennghich=0;
    bientocdo=0; //xoa bien toc do
    if (bienthuan)
    duty2 = tocdo0;
    switch (bientocdo)
    case 1: duty1= tocdo1;
    break;
    case 2: duty1= tocdo2;
    break;
    case 3: duty1= tocdo3;
    break;
    case 4: duty1= tocdo4;
    break;
    case 5: duty1= tocdo5;
    break;
    default : duty1 = td_macdinh;
    break;
    set_pwm1_duty(duty1); //cho dco chay thuan
    if (biennghich)
    duty1 = tocdo0;
    switch (bientocdo)
    case 1: duty2= tocdo1;
    break;
    case 2: duty2= tocdo2;
    break;
    case 3: duty2= tocdo3;
    break;
    case 4: duty2= tocdo4;
    break;
    case 5: duty2= tocdo5;
    break;
    default : duty2 = td_macdinh;
    break;
    set_pwm1_duty(duty1); //cho dco chay nghich
    help me!!! Ko có ai giúp hết vậy.
    holy_ghost Tìm hiểu thêm về holy_ghost
