Nguyên văn bởi 207.207
download từ ieee
Bạn taolao ơi down giùm tớ cái này nhé.
Cảm ơn bạn nhiều.
Link: http://ieeexplore.ieee.org/Xplore/lo...3B+Cihlar%2C+J.
Development of a robust haze removal algorithm: assessment using temporally invariant targetsYing Zhang; Guindon, B.; Cihlar, J.
Geoscience and Remote Sensing Symposium, 2002. IGARSS apos;02. 2002 IEEE International
Volume 1, Issue , 2002 Page(s): 101 - 103 vol.1
Digital Object Identifier 10.1109/IGARSS.2002.1024954
Summary: A robust haze-removal algorithm based on the Haze Optimized Transformation (HOT) is applied to ETM+ imagery. Its effectiveness is evaluated using temporally invariant targets identified in a multi-temporal data set of scenes of WRS-2 Path15/Row29. In the data set, clear scenes serve as 'benchmarks' against which the effectiveness of haze removal can be assessed. In the quantitative assessment, two hundred coniferous forest patches were randomly sampled and served as 'benchmark' targets since they exhibit both spatial and temporal radiometric invariance on clear data. Comparisons were made of the radiometric characteristics of the patch population in hazy vs. de-hazed and de-hazed vs. clear image pairs. Results show that image contaminated by low to moderate haze can be significantly improved. Reductions of 20 to 90% in intra-scene radiometric dispersion have been achieved with the de-hazed scenes exhibiting residual dispersion levels comparable to those of the benchmark scenes.
Bác taolao có thể lấy giùm e mấy tiêu chuẩn sau đây được ko:
1. IEEE Std 1048-1990: Hướng dẫn của IEEE cho việc bảo vệ chạm đất các đường dây tải điện - IEEE guide for protective grounding of power lines.
http://ieeexplore.ieee.org/Xplore/lo...799.pdf?temp=x
2. IEEE Std 1036-1992: Hướng dẫn của IEEE cho việc ứng dụng các tụ công suất bù ngang - IEEE guide for application of shunt power capacitors.
http://ieeexplore.ieee.org/Xplore/lo...735.pdf?temp=x
3. IEEE Std 1019-2004 (Revision of IEEE Std 1019-1991): Khuyến nghị của IEEE cho các thông số kỹ thuật của cáp chôn ngầm - Cách điện Polypropylene - IEEE Recommended Practice for Specifying Electric Submersible Pump Cable-Polypropylene Insulation
http://ieeexplore.ieee.org/Xplore/lo...number=1425767
4. IEEE Std 1124-2003: Hướng dẫn cho việc phân tích và xác định sóng hài một chiều của hệ thống truyền dẫn HVDC - IEEE guide for the analysis and definition of DC-side harmonic performance of HVDC transmission systems
http://ieeexplore.ieee.org/Xplore/lo...number=1237536
Thanks bác nhiều
DownloadPhen này ông quyết buôn băng dính,
Vừa bán vừa hm... hm... cũng đắt hàng.
Nguyên văn bởi jefflieu Xem bài viếtNhieu lam, chiu kho' search di roi chi ra chinh xac tai lieu na`o roi Jeff down cho ....
my mail: quoc_tho2003@yahoo.com
link: http://ieeexplore.ieee.org/xpl/freea...rnumber=502360
Doubly fed induction generator using back-to-back PWM convertersand its application to variable-speed wind-energy generation
Pena, R. Clare, J.C. Asher, G.M.
Dept. of Electr. & Electron. Eng., Nottingham Univ.;
This paper appears in: Electric Power Applications, IEE Proceedings -
Publication Date: May 1996
Volume: 143, Issue: 3
On page(s): 231-241
ISSN: 1350-2352
References Cited: 21
CODEN: IEPAER
INSPEC Accession Number: 5292558
Posted online: 2002-08-06 20:26:09.0
Abstract
The paper describes the engineering and design of a doubly fed induction generator (DFIG), using back-to-back PWM voltage-source converters in the rotor circuit. A vector-control scheme for the supply-side PWM converter results in independent control of active and reactive power drawn the supply, while ensuring sinusoidal supply currents. Vector control of the rotor-connected converter provides for wide speed-range operation; the vector scheme is embedded in control loops which enable optimal speed tracking for maximum energy capture from the wind. An experimental rig, which represents a 7.5 kW variable speed wind-energy generation system is described, and experimental results are given that illustrate the excellent performance characteristics of the system. The paper considers a grid-connected system; a further paper will describe a stand-alone system
hic, ko biết lấy gì cảm ơn bác đây, giá như bác ở Đà Nẵng thì e có dịp hậu tạ. Luôn tiện bác down thêm giùm e mấy cái tiêu chuẩn nữa được ko?
http://ieeexplore.ieee.org/Xplore/lo...number=1277892
http://ieeexplore.ieee.org/Xplore/lo...619.pdf?temp=x
http://ieeexplore.ieee.org/iel1/3273...rnumber=467494
http://ieeexplore.ieee.org/Xplore/lo...number=1194457
http://ieeexplore.ieee.org/xpl/freea...&punumber=5076
http://ieeexplore.ieee.org/Xplore/lo...294.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...661.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...number=1315281
http://ieeexplore.ieee.org/Xplore/lo...003.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...number=1424424
http://ieeexplore.ieee.org/Xplore/lo...rnumber=863650
http://ieeexplore.ieee.org/Xplore/lo...837.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...number=1225051
http://ieeexplore.ieee.org/Xplore/lo...number=1355860
http://ieeexplore.ieee.org/Xplore/lo...number=1042562
http://ieeexplore.ieee.org/Xplore/lo...number=1203094
http://ieeexplore.ieee.org/Xplore/lo...rnumber=916616
http://ieeexplore.ieee.org/iel1/2900...rnumber=182873
http://ieeexplore.ieee.org/xpl/stand...?isnumber=5491
http://ieeexplore.ieee.org/Xplore/lo...976.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...620.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...rnumber=475522
http://ieeexplore.ieee.org/Xplore/lo...arnumber=30653
http://ieeexplore.ieee.org/Xplore/lo...number=1033175
http://ieeexplore.ieee.org/xpl/freea...number=4014492
http://ieeexplore.ieee.org/xpl/freea...number=1519743
http://ieeexplore.ieee.org/Xplore/lo...985.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...923.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...481.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...768.pdf?temp=x
http://ieeexplore.ieee.org/Xplore/lo...number=1611106
http://ieeexplore.ieee.org/Xplore/lo...rnumber=875997
http://ieeexplore.ieee.org/Xplore/lo...number=1605067
http://ieeexplore.ieee.org/Xplore/lo...977.pdf?temp=x
Thanks bác trước
Nhờ download tài liệu IEEEXPLORE
Bạn Taolao oi giúp minh cái này với :
Measuring asymmetric link bandwidths in Internet using a multi-packet delay model
Yu Lin; Haitao Wu; Shiduan Cheng; Wenyan Wang; Chonggang Wang
Communications, 2003. ICC apos;03. IEEE International Conference on
Volume 3, Issue , 11-15 May 2003 Page(s): 1601 - 1605 vol.3
Digital Object Identifier 10.1109/ICC.2003.1203872
Summary: Accurate measurement of network bandwidth is crucial for many flexible Internet applications and protocols. Based on a new multi-packet delay model, this paper presents a new algorithm called ALBP (asymmetric link bandwidth probing) to measure each hop's link bandwidth in both directions in an IP network, and uses the kernel density estimator to produce a final estimate. Compared with previous techniques, ALBP can eliminate (at least partially) the errors introduced by ICMP replies through the use of interarrival time of two probing packets, and avoid the problem of error accumulation. Simulation results show that ALBP is usually more accurate than both one-packet and packet tailgating techniques, and the bandwidth consumption of ALBP is close to that of packet tailgating.
Cảm ơn nhiều nhiều
Wind Energy
Bac down giup minh tai lieu nay nhe, minh dang can lam, gui qua mail dum minh. Chan thanh cam on
On page(s): 231-241
ISSN: 1350-2352
CODEN: IEPAER
Abstract
Nguyên văn bởi 207.207 Xem bài viếtBạn Taolao oi giúp minh cái này với :
Cảm ơn nhiều nhiềuPhen này ông quyết buôn băng dính,
Nguyên văn bởi thotran Xem bài viếtBac down giup minh tai lieu nay nhe, minh dang can lam, gui qua mail dum minh. Chan thanh cam on
hôm nay, 12:43 -
hôm nay, 10:23 -
Sao trang không vào được bạn-
Hôm qua, 12:06 -
Hôm qua, 11:16 -
Hôm qua, 11:09 -
Hôm qua, 10:26 -
Hôm qua, 09:35 -
Vào trang của hãng...-
Hôm qua, 07:35 -
Hôm qua, 07:19 -
Trả lời cho Hỗ trợ tìm linh kiện mạch hạ áp 220V - 110Vbởi ngtuhanCòn thiếu con trở 330 ohm/10W nối song song CE của transitor công suất. Mạch này có từ cái thời VN dùng tivi nội địa Nhật, thay thế cho phần ổn áp 110v (nếu bị hỏng). Giờ chỉ là dĩ vãng.
Hôm qua, 02:27 -
