download từ ieee
  • Có bác nào download được tài liệu ở trang này không ?
    http://www.springerlink.com
    Nếu được lấy giúp mấy bài với nhé.
    Cảm ơn
    Bác TAOLAO có thể giúp em vụ này không ?!
    • các bác ơi có thể tải giùm mình tài liệu về "lead-acid batteries" được không. giúp mình nhé cám ơn các bác nhiều.
      Dynamical models of lead-acid batteries: implementation issues
      http://ieeexplore.ieee.org/xpl/freea...rnumber=986432
      New Dynamical Models of Lead-Acid Batteries
      http://ieeexplore.ieee.org/xpl/freea...rnumber=898088
      • các bác tải giùm mình tài liệu này nhé.cám ơn nhiều
        http://ieeexplore.ieee.org/Xplore/lo...041.pdf?temp=x
        • các bác ơi sao mình tìm cách tải bài báo ieee mà không được giúp mình nhé. cám ơn các bác nhiều.
          • Bac Taolao lay giup em voi :
            Towards a Generalized Stochastic Model of End-to-End Packet-Pair Sampling
            Liu, X.; Ravindran, K.; Loguinov, D.
            Selected Areas in Communications, IEEE Journal on
            Volume 24, Issue 12, Dec. 2006 Page(s):2249 - 2262
            Digital Object Identifier 10.1109/JSAC.2006.884024
            Summary:End-to-end packet-pair probing has been used as one of the primary mechanisms to measure bottleneck capacity, cross-traffic intensity, and available bandwidth of end-to-end Internet paths. However, there has been lacking an understanding of what types of information about the path are sampled by packet-pairs and how they are encoded in the corresponding output dispersions. In this paper, we answer these questions by deriving the expression of individual output spacings (i.e., dispersions) in the context of multihop paths and general bursty cross-traffic arrivals. Based on these results, we examine stochastic properties of the sampled signals and derive the statistical mean of the output interpacket spacings as a recursive function of the input spacing. We show that the result is different from what has been obtained in prior work using fluid cross-traffic models and that this discrepancy has a significant adverse impact on the accuracy of packet-pair bandwidth
            • Bác TaoLao ơi giúp em với dowload giùm em 3 bài báo này nhé.
              Hiện giờ em rất cần để làm LVTN mong bác giúp đỡ, cám ơn bác nhiều.
              • Cho em xin tài liệu này
                Multimedia data-embedding and watermarking technologies
                link: http://ieeexplore.ieee.org/Xplore/lo...8/00687830.pdf
                Swanson, M.D.; Kobayashi, M.; Tewfik, A.H.
                Proceedings of the IEEE
                Volume 86, Issue 6, Jun 1998 Page(s):1064 - 1087
                Digital Object Identifier 10.1109/5.687830
                Summary:We review developments in transparent data embedding and watermarking for audio, image, and video. Data-embedding and watermarking algorithms embed text, binary streams, audio, image, or video in a host audio, image, or video signal. The embedded data are perceptually inaudible or invisible to maintain the quality of the source data. The embedded data can add features to the host multimedia signal, e.g., multilingual soundtracks in a movie, or provide copyright protection. We discuss the reliability of data-embedding procedures and their ability to deliver new services such as viewing a movie in a given rated version from a single multicast stream. We also discuss the issues and problems associated with copy and copyright protection and assess the viability of current watermarking algorithms as a means for protecting copyrighted data
                • Ai có thể download hộ mình link này nhé. Cảm ơn trước nhé.
                  http://ieeexplore.ieee.org/Xplore/lo...%3B+Xia+Deming
                  Summary:This paper is concerned with the hardware realization of HAVC (hybrid automatic voltage control) system. Firstly, HAVC theory is introduced briefly. Then based on this, the hardware framework of HAVC is designed, which include command, communication, execution and monitor four layers. And by using the hybrid control law which is given in this paper, the HAVC equipment for power plant is developed. Dynamic simulations have proved the validity of the HAVC hardware framework and the HAVC equipment
                  và link này nữa:
                  http://ieeexplore.ieee.org/Xplore/lo...number=4116217
                  Summary:Based on hybrid control theory, this paper introduces an integrated control strategy of voltage and reactive power in substation. This strategy adopts the hierarchical balance optimization of reactive power and improves the traditional "nine-area diagram" control method. The new hybrid control strategy not only solves the oscillating problem caused by the change of transformer taps and shunt capacitors switching, but also responses the global optimal control command of reactive power in time. The simulations have proved the validity of the HAVC strategy.
                  • Bác nào có tài khoản IEEE down giúp e với
                    1-Load balancing algorithms in MPLS traffic engineering
                    Keping Long; Zhongshan Zhang; Shiduan Cheng
                    High Performance Switching and Routing, 2001 IEEE Workshop on
                    Volume , Issue , 2001 Page(s):175 - 179
                    Digital Object Identifier 10.1109/HPSR.2001.923627
                    2-
                    • Xin lỗi các bác, có thể là do em dốt quá, nhưng mà em không search được trên IEEE để mà lên đây nhờ các bro down hộ nữa. Bác nào chỉ cho em search như thế nào với.
                      • Àh, em search được rồi. Xin nhờ down hộ em cái này:
                        http://ieeexplore.ieee.org/xpl/freea...nt=155&index=1
                        Power Electronics and Drive Systems, 2003. PEDS 2003. The Fifth International Conference on
                        Publication Date: 17-20 Nov. 2003
                        Volume: 1, On page(s): 1- 7 Vol.1
                        Abstract
                        The emergence of power semiconductor devices such as insulated-gate bipolar transistors (IGBTs) or injection-enhanced gate transistors (IEGTs) and gate-commutated turn-off (GCT) thyristors or integrated gate-commutated thyristors (IGCTs) enables power conversion systems to expand into utility and industry applications. Much attention has been paid to power switching devices based on wide-bandgap semiconductors such as silicon carbide(SiC). These devices are expected to have the following advantages over silicon devices; low switching and conduction losses, especially in power conversion systems operating as high as, or exceeding 600 V. This paper describes trends in power electronics and motor drives, including the personal views and expectations of the author.
                        Em xin cảm ơn.
                        • Xin bác giúp tiếp:
                          http://ieeexplore.ieee.org/search/fr...metadata&pos=5
                          Intelligent Control and Automation, 2002. Proceedings of the 4th World Congress on
                          Publication Date: 10-14 June 2002
                          Volume: 4
                          On page(s): 2831 - 2835 vol.4
                          Number of Pages: 4 vol. 3353
                          Abstract
                          This paper presents the mathematical model of multiphase induction machines in the synchronous reference frame by using generalized two axis real transformation, which simplifies the modeling and control of multiphase induction machines. A detailed implementation of an indirect type multiphase induction machine rotor flux field orientation control and unified PWM technique applied to the multiphase inverter are described. The control method is implemented on the floating-point DSP board TMS320C32 to verify the validity of the developed control strategy.
                          Em xin cám ơn ạ.
                          • Nguyên văn bởi jefflieu Xem bài viết
                            Can thi dua title cua ta`i lieu cho Jeff, Jeff down cho, jeff co' account nhung ko share len duoc ... mong a e thong cam ... truo`ng no' biet duoc no' duoi hoc chet
                            - Chào Jefflieu, mình cần down 1 số cuốn sách như:
                            1 - Semiconductor optical amplifiers; tác giả: Michael J. Connelly - 2002; nhà xuất bản: springer
                            2 - B. RAMAMURTHY AND B.MUKHERJEE, "Wavelength conversion in WDM Networking", IEEE Journal on Selected Areas in Communication, November 1998.
                            3 - J.M.Wiesenfeld, “Wavelength conversion techniques” in Proc. OFC’96, San Jose, CA, Feb. 1996,pp. 71-71, paper TuP 1
                            4 - S.J.B Yoo, “Wavelength conversion techologies for WDM network applications” J. Lightwave Technol., vol. 14, pp, 955-966, June 1996
                            5 - T. Durhuus et al., “All optical wavelength conversion by SOA’s in a Mach-Zender configuration” IEEE Photon. Tech. Lett., vol. 6, pp.53-55, Jan, 1994
                            6 - B. Mikkelsen et al., “Polarization insensitive wavelength conversion of 10 Gbit/s signals with SOA’s in a Michelson interferometer” Electron.Lett…., vol, 30, pp.260-261, Feb.1994
                            7 - Four wave mixing in optical fibre. Wavelength Conversion Mechanisms
                            8 - E. Mao, D. R. Yankelevich, C. C. Lin, O. Solgaard, A. Knoesen, J. S. Harris, Jr., "Wavelength-selective semiconductor in-line fibre photodetectors" Electron. Lett. 36 (6) pp. 515-516, March 2000.
                            - Bạn có thể giúp mình được không? Có lẽ mình xin hơi nhiều, nhưng mình mong rằng bạn có thể down giúp mình một số ở phía trên của list, tùy khả năng của bạn. Hãy giúp mình nha. Thanks!
                            • Xin chào anh, em đang cần tài liệu này, xin anh giúp với.
                              tài liệu: "A fast neural network learning algorithm and its application"
                              http://ieeexplore.ieee.org/Xplore/lo...number=1415001
                              và "Online self-optimizing control of coal-fired boiler combustion system"
                              http://ieeexplore.ieee.org/xpl/freea...number=1415001
                              Cám ơn anh rất nhiều.
                              levan8421 Tìm hiểu thêm về levan8421
