chay chu tieng viet tren lcd
  • chay chu tieng viet tren lcd
    mấy PRO giúp mình cái code chạy chữ tiếng việt với.mình có code hiển thị tiếng việt rồi mak` mun làm cho nó chạy từ phải sang trái mak` kko bik viết thế nào.Mong các PRO giúp đỡ
    #include <16f877A.h>
    #use delay(clock=20000000)
    #fuses hs,nowdt,noput
    #define LCD_RS PIN_B0
    #define LCD_EN PIN_B1
    #define LCD_B4 PIN_B4
    #define LCD_B5 PIN_B5
    #define LCD_B6 PIN_B6
    #define LCD_B7 PIN_B7
    byte const cgram [48] = {0x0E,0X09,0X09,0X1D,0X09,0X09,0X0E,0X00,
    0X04,0X0A,0X00,0X0E,0X0A,0X0A,0X04,0X00,
    0X04,0X08,0X16,0X01,0X12,0X12,0X1E,0X00,
    0X04,0X08,0X14,0X08,0X1C,0X14,0X1E,0X00
    void LCD_SetData (int cX )
    output_bit ( LCD_B4, cX & 0x01 );
    output_bit ( LCD_B5, cX & 0x02 );
    output_bit ( LCD_B6, cX & 0x04 );
    output_bit ( LCD_B7, cX & 0x08 );
    void LCD_PulseEnable()
    output_high ( LCD_EN );
    delay_MS ( 10 );
    output_low ( LCD_EN );
    delay_MS ( 10 );
    void LCD_PutCmd (int cX )
    output_low (LCD_RS);
    LCD_SetData ( swap ( cX ) );
    LCD_PulseEnable ();
    LCD_PulseEnable();
    void LCD_PutChar ( unsigned int cX )
    output_high ( LCD_RS );
    LCD_SetData ( swap ( cX ) ); /* send high nibble */
    LCD_PulseEnable();
    LCD_SetData ( swap ( cX ) ); /* send low nibble */
    LCD_PulseEnable();
    delay_ms(10);
    void lcd_cmd (int data)
    output_low(LCD_RS);
    output_B(data);
    LCD_PulseEnable();
    void LCD_Init ()
    delay_ms(20);
    lcd_cmd( 0x30 );
    delay_ms(10);
    lcd_cmd( 0x30 );
    delay_US(350);
    lcd_cmd( 0x30 );
    lcd_cmd(0b00101000);
    LCD_PutCmd(0b00101000);
    LCD_PutCmd (0b00001100 ); /* display ON, cursor off, no blink */
    LCD_PutCmd ( 0b00000110 ); /* entry mode set, increment & scroll left */
    LCD_PutCmd ( 0x01 ); /* clear display */
    VOID lcd_string(byte posistion,char *ptr,int delay)
    LCD_PutCmd (posistion );
    WHILE (*ptr!=0)
    LCD_PutChar (*ptr++ );
    DELAY_MS(delay);
    void main ()
    char text1 []="DH Ton Duc Thang";
    char text3 []="MSSV:081373D";
    int8 i,k;
    char *ptr;
    set_tris_b(0);
    LCD_Init ();
    LCD_PutCmd (0X40);
    for(i=0;i<48;i++)
    LCD_PutChar(cgram[i]);
    lcd_string(0x80,text1,5);
    lcd_string(0x0C0,text3,5);
    lcd_string(0x0D0,text4,5);
    LCD_PutCmd (0X80);
    LCD_PutChar(0X00);
    LCD_PutCmd (0X84);
    LCD_PutChar(0X01);
    LCD_PutCmd (0X87);
    LCD_PutChar(0X00);
    LCD_PutChar(0X02);
    LCD_PutCmd (0X8D);
    LCD_PutChar(0X03);
    ban co code chay chu ko cho minh xin voi code viet bang c cho 8051
    cam on truoc nha
    khanhtuan Tìm hiểu thêm về khanhtuan
