Mọi người giúp mình về cái chuông trình này với. chương trình VHDL chạy trên XILINX
  • Mọi người giúp mình về cái chuông trình này với. chương trình VHDL chạy trên XILINX
    library IEEE;
    use IEEE.STD_LOGIC_1164.all;
    use IEEE.STD_LOGIC_ARITH.all;
    use IEEE.STD_LOGIC_UNSIGNED.all;
    use work.CALC1_PAK.all;
    entity CNTRL_FSM is
    port ( DATA_FRAME : in MY_RECORD;
    CLK : in std_logic;
    RESET : in std_logic;
    A_IN : out std_logic_vector(3 downto 0);
    B_IN : out std_logic_vector(3 downto 0);
    C_IN : out std_logic;
    OP_CODE : out std_logic_vector(3 downto 0);
    EXP : out std_logic_vector(3 downto 0);
    ADDR : out std_logic_vector ( 2 downto 0);
    COMP_EN : out std_logic;
    MEM_EN : out std_logic;
    ALU_EN : out std_logic );
    end entity CNTRL_FSM;
    architecture RTL of CNTRL_FSM is
    type CNTRL_STATE is ( S0_INIT, S1_FETCH, S2_ALU, S3_COMP, S4_DONE );
    signal CURR_STATE, NEXT_STATE : CNTRL_STATE;
    signal ADDR_I, ADDR_Q : std_logic_vector ( 2 downto 0 ) := ( others => ‘0’ );
    begin
    ADDR <= ADDR_Q; -- used to update output port from synchronous internal signal
    SYNC : process ( CLK, RESET )
    begin
    if ( RESET = '1' ) then
    CURR_STATE <= S0_INIT;
    ADDR_Q <= ( others => '0' );
    elsif rising_edge (CLK) then
    CURR_STATE <= NEXT_STATE;
    ADDR_Q <= ADDR_I; -- update ADDR_Q with the current value of ADDR_I
    end if;
    end process SYNC;
    COMB : process ( CURR_STATE, DATA_FRAME, ADDR_Q )
    begin
    --default assignments
    A_IN <= DATA_FRAME.A_IN;
    B_IN <= DATA_FRAME.B_IN;
    C_IN <= DATA_FRAME.C_IN;
    OP_CODE <= DATA_FRAME.OP_CODE;
    EXP <= DATA_FRAME.EXP;
    ADDR_I <= ADDR_Q; -- use the registered ADDR_Q to keep ADDR fully synchronous
    case CURR_STATE is
    when S0_INIT =>
    MEM_EN <= '0';
    ALU_EN <= '0';
    COMP_EN <= '0';
    NEXT_STATE <= S1_FETCH;
    when S1_FETCH =>
    MEM_EN <= '1';
    ALU_EN <= '0';
    COMP_EN <= '0';
    NEXT_STATE <= S2_ALU;
    when S2_ALU =>
    MEM_EN <= '0';
    ALU_EN <= '1';
    COMP_EN <= '0';
    NEXT_STATE <= S3_COMP;
    when S3_COMP =>
    MEM_EN <= '0';
    ALU_EN <= '0';
    COMP_EN <= '1';
    NEXT_STATE <= S4_DONE;
    when S4_DONE =>
    if ADDR_Q = "111" then
    else
    NEXT_STATE <= S1_FETCH ;
    ADDR_I <= ADDR_Q + 1;
    end if;
    MEM_EN <= '0' ;
    ALU_EN <= '0';
    COMP_EN <= '0';
    when others =>
    NEXT_STATE <= S0_INIT;
    MEM_EN <= '0' ;
    ALU_EN <= '0';
    COMP_EN <= '0';
    end case;
    end process COMB;
    end RTL;
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use IEEE.STD_LOGIC_ARITH.ALL;
    use IEEE.STD_LOGIC_UNSIGNED.ALL;
    use work.CALC1_PAK.all;ENTITY CNTRL_FSM_TB_vhd IS
    END CNTRL_FSM_TB_vhd;
    ARCHITECTURE behavior OF CNTRL_FSM_TB_vhd IS
    COMPONENT CNTRL_FSM
    PORT(
    DATA_FRAME : IN MY_RECORD;
    CLK : IN std_logic;
    RESET : IN std_logic;
    A_OP : OUT std_logic_vector(3 downto 0);
    B_OP : OUT std_logic_vector(3 downto 0);
    C_IN : OUT std_logic;
    OP_CODE : OUT std_logic_vector(3 downto 0);
    EXP : OUT std_logic_vector(3 downto 0);
    MEM_EN : OUT std_logic;
    ALU_EN : OUT std_logic ;
    COMP_EN : OUT std_logic ;
    ADDR : OUT std_logic_vector(2 downto 0) );
    END COMPONENT;
    SIGNAL DATA_FRAME : MY_RECORD := ("0000", "0000","0000",'0',"0000");
    SIGNAL CLK : std_logic := '0';
    SIGNAL RESET : std_logic := '0';
    SIGNAL A_IN, B_IN : std_logic_vector(3 downto 0);
    SIGNAL C_IN : std_logic;
    SIGNAL OP_CODE : std_logic_vector(3 downto 0);
    SIGNAL EXP : std_logic_vector(3 downto 0);
    SIGNAL ALU_EN, MEM_EN, COMP_EN : std_logic;
    SIGNAL ADDR : std_logic_vector(2 downto 0);
    BEGIN
    uut: CNTRL_FSM PORT MAP(
    DATA_FRAME => DATA_FRAME,
    CLK => CLK,
    RESET => RESET,
    A_IN => A_IN,
    B_IN => B_IN,
    C_IN => C_IN,
    OP_CODE => OP_CODE,
    EXP => EXP,
    ALU_EN => ALU_EN, MEM_EN => MEM_EN, COMP_EN => COMP_EN ,
    ADDR => ADDR );
    CLK <= not CLK after 20 ns;
    RESET <= '1' after 10 ns, '0' after 25 ns;
    tb : PROCESS
    BEGIN
    DATA_FRAME <= ("1000", "0100","0000",'0',"0000");
    wait for 100 ns;
    DATA_FRAME <= ("1000", "0100","0101",'0',"0000");
    wait for 100 ns;
    DATA_FRAME <= ("1000", "0100","0100",'0',"0000");
    wait; -- will wait forever
    END PROCESS;
    END TEST;
thuốc lào 07 Tìm hiểu thêm về thuốc lào 07
