Nhờ các cao thủ giúp vs. chuyển sang file hex ko dc!
  • Nhờ các cao thủ giúp vs. chuyển sang file hex ko dc!
    e đang làm đồ án. đề tài inverter . mà có file c giờ chuyển sang hex mà nó báo tùm lum lỗi hết.
    có bác nào rành về vấn đề này ko??/ thì giúp e vs. trân thành cảm ơn rất nhiều. @@@@@
    chương trình nó như sau. các bác xem giúp nha
    sử dụng thạnh anh 20MH
    #define USE_OR_MASKS
    #include <p18f1320.h>
    #include "pwm.h"
    #include "timers.h"
    //-------------------Configuration setting------------------
    * Oscillator is configured as HS
    * Fail safe monitor is enabled
    * watch dog timer is disabled
    * Extended instruction mode is disabled
    * oscillator switch over is enabled
    #if defined(__18F1320) //If the selected device if PIC18F4685, then
    apply below settings else user will have to set
    #pragma config OSC=HS, FSCM=ON, WDT=OFF, IESO=ON, LVP=OFF
    #endif
    void main(void)
    char period=0x00;
    unsigned char outputconfig=0,outputmode=0,config=0;
    unsigned int duty_cycle=0;
    unsigned int timer=0;
    unsigned int i=0;
    unsigned int dutyCycle_Array[40]={0x005B, 0x0053, 0x004E, 0x0048, 0x0044,
    0x0040, 0x003D, 0x003C, 0x003D, 0X0040, 0x0044, 0x0048, 0x004E,
    0x0055, 0x005D, 0x0065, 0x006E, 0x0078, 0x0080, 0x0089, 0x0093,
    0x009B, 0x00A3, 0x00A7, 0X00AF, 0X00B2, 0X00B5, 0X00B7, 0X00B7,
    0X00B5, 0X00B4, 0X00B1, 0X00AB, 0X00A6, 0X009E, 0X0097, 0X008E,
    0X0086, 0X007E};
    OpenTimer2(T2_PS_1_4);
    //------------------Configure pwm ---------
    period = 0x3C;
    OpenPWM1(period); //Configure PWM module and
    initialize PWM period
    while(1) //observe output on CCP1 pin
    //---------------------set duty cycle---------------------------------------------------------
    for(i=0;i<40;i++)
    SetDCPWM1(dutyCycle_Array[i]); //set the duty cycle
    //-------------------set pwm output---------------------------------------------------------.
    outputconfig = FULL_OUT_FWD;
    outputmode = PWM_MODE_1;
    SetOutputPWM1( outputconfig, outputmode); //output PWM in
    respective modes
    outputconfig = FULL_OUT_REV;
    outputmode = PWM_MODE_3;
    //--------------------------close pwm----------------------------------------
    ClosePWM1();
    help me!!!!!!!!!!!!!
      nan!!!!!!!
      love_1990 Tìm hiểu thêm về love_1990
