This high-performance circuit first quickly starts (and holds) the charge at 2 amp, but as the voltage rises the current will consequently decrease.
When the current falls below 150mA, the charger automatically switches to a lower 'Float' voltage to prevent overcharging.
At the point that a full charge is reached, Q1 will bias and the LED will light.
The LM301A is a 8-pin OpAmp. Transistor Q1 is a PNP, Silicon, AF-Out type with a TO-39 metal case and can be substituted for a NTE or ECG129. Diode D1, a Si, GP Det. type, can be substituted with a NTE177 or ECG177. The LM350 (U1) needs to be cooled.
The input voltage should equal or about 18volts.
R1's function is to bleed some of the input voltage to the output and vice-versa. A 1N4002 or similar diode can be used also.
R2 and R5 are actually metal-film type resistors. To get the 3K for R2 use two 1K5 (1500 ohm) resistors in series. For R5 use two 470 ohm resistors in parallel. Or whatever combination to get to these values. For R1, 500 ohm, you can use two 1K in parallel or 470 + 33 ohms in series.
R7, the 0.2 ohm resistor, is a 5 watt wire-wound type. Do not use the standard carbon type.
C4: This (optional) 0.1uF (100nF) Ceramic capacitor needs to be mounted over the power lines and as close to the LM301 (U2) as possible. It will filter off any possible residue hf ripple, which otherwise may prevent this op-amp from working properly. Use only if you have problems with the LM301 not switching off.
S1 is a subminiature pushbutton switch, normally open. I received a couple emails in regards to this switch. I thought the diagram was pretty clear. It shows an 'open' switch with the arrow indicating a 'momentary' connection when pushed. Nothing out of the ordinary here folks and a standard symbol for electronics...
When the start switch is pushed, the output of the charger goes to 14.5 V. As the batttery approaches full charge, the charging current decreases and the output voltage is reduced form 14.5V to about 12.5V, terminating the charging process. Transistor Q1 then lights the led as a visual indication of a full charge.
Note: This circuit will both work for Gel cell and regular L.A. batteries, and is from an application note found in the National Linear 1 Databook as part of their regulator spec datasheets (#400041, Rev.1, Page 1-147).[
Thông cảm, mình cũng lười như bạn nên chơi dịch tự động!!!!
nguyên văn bởi máy dịch:
Điều này hiệu suất cao mạch đầu tiên bắt đầu một cách nhanh chóng (và các tổ chức) Chi phí tại 2 amp, nhưng điện áp tăng như hiện nay sẽ là giảm.
Khi hiện tại ngã dưới đây 150mA, với bộ sạc tự động cho một thiết bị bấm thấp 'phao' điện áp để ngăn ngừa quá mức.
Tại điểm đó, một toàn bộ chi phí được đạt tới, Q1 sẽ thiên vị và các LED sẽ sáng.
Các LM301A là một 8-pin OpAmp. Transistor Q1 là một PNP, Silicon, AF-ra với một loại TO-39 trường hợp kim loại và có thể được thay thế cho một NTE hoặc ECG129. Diode D1, một Sĩ, Dệt GP. loại, có thể được thay thế bằng một NTE177 hoặc ECG177. Các LM350 (U1) cần phải được nguội.
Các điện áp đầu vào phải bằng hoặc về 18volts.
R1 của chức năng là chảy máu một số điện áp đầu vào cho sản xuất và vice-versa. Đáp Diode 1N4002 hoặc tương tự cũng có thể được sử dụng.
R2 và R5-kim loại thực sự là loại phim resistors. Để có được 3K cho R2 sử dụng hai 1K5 (1500 om) resistors trong loạt. R5 Để sử dụng hai 470 ohm resistors song song. Hoặc bất cứ sự kết hợp để tìm những giá trị này. Đối với R1, 500 ohm, bạn có thể sử dụng song song hai 1K hoặc 470 + 33 ohms trong loạt.
R7, các 0,2 ohm resistor, là một 5-watt dây loại vết thương. Không sử dụng các tiêu chuẩn khí carbon loại.
C4: Điều này (tùy chọn) 0.1uF (100nF) Gạch Capacitor cần phải được gắn kết qua đường dây điện và càng gần với LM301 (U2) càng tốt. Nó sẽ tắt bộ lọc nào có thể residue HF Ripple, mà nếu không có thể ngăn này op-amp từ các hoạt động đúng cách. Chỉ sử dụng nếu bạn có vấn đề với LM301 không được chuyển đi.
S1 là một subminiature pushbutton chuyển, mở bình thường. Tôi nhận được một vài email trong này liên quan đến chuyển đổi. Tôi nghĩ là các sơ đồ khá rõ ràng. Nó cho thấy một 'mở' chuyển đổi với các mũi tên chỉ là một 'momentary' kết nối khi đẩy. Chẳng có gì ngoài bình thường ở đây folks và một biểu tượng tiêu chuẩn cho các điện tử ...
Khi bắt đầu chuyển đổi được đẩy, sản lượng với bộ sạc đi đến 14,5 V. batttery là phương pháp tiếp cận đầy đủ chi phí, các tính phí hiện tại và giảm điện áp đầu ra là hình thức giảm 14.5V để về 12.5V, chấm dứt việc thu phí process.Transistor Q1 sau đó đèn chiếu sáng các hãng như là một chỉ thị giác của một toàn bộ phí.
Lưu ý: mạch này sẽ làm việc cho cả hai Gel tế bào và thường xuyên VI pin, và là từ một ứng dụng lưu ý được tìm thấy trong các quốc gia Linear 1 Databook như là một phần của họ regulator spec datasheets (# 400041, Rev.1, trang 1-147).
Mình cũng làm như vậy nhưng hem hiểu gì hết trơn. Mình chỉ thắc mắc chỗ con R7, LM350T với con LM310A, chỗ con D1 nữa sao thấy nó ngược ngược làm sao đó nếu so sánh điện áp sao D1 lại mắc như vậy, mìn bó tay mong anh em giúp đỡ. Thanks nhiều !!
Có nhiều cách, nhiều phương án làm được như thế. Động cơ nào cũng làm được như thế.
Banj có thể dùng động cơ quạt thông gió cũng được. Dĩ nhiên phải lắp thêm vài linh kiện, ch tiết điều khiển cảm biến....
0903252168...
Xem làm gì.
Bây giờ nó đang bò lồm cồm, lung tung . Từ các công trường đóng gạch ,lây lan vào từng nhà máy cơ khí. Đến các xưởng sản xuất tư nhân nó cũng bò vào rồi . Và ...
Vài năm nữa thôi, nó sẽ bò vào tận giường ngủ...
Lạc hậu là nó từ trong Tâm họ mà ra, không phải từ phương tiện, điều kiện bên ngoài.
Nguwfi ta đã lạc hậu thì dù trên tay họ cầm iphon 15, kết nối mạng 456G thì họ vẫn lạc hậu thôi.
Họ lạc hậu thì dù họ vận hành cái Laptop...
