Serial_Init:
;Set timer 1 mode to 8-bit Auto-Reload
mov TMOD,#20H
;Enable reception
;Set Serial port mode to 8-bit UART
mov SCON,#50H
;Set baudrate to 9600 at 11.0592MHz
mov TH1,#0FDH
mov TL1,#0FDH
;Start Timer
setb TR1
ret
Serial_Send:
;wait for last data to be
;sent completely
jnb TI,Serial_Send
;clear the transmit interrupt flag
clr TI
;Then move the data to send in SBUF
mov SBUF,A
ret
Serial_Read:
;Wait for Receive interrupt flag
jnb RI,Serial_Read
Có phải dây là code của chương trình truyền dữ liệu từ máy tính xuống cổng Com không?? thanks.
mov TMOD,#20H
;Enable reception
mov SCON,#50H
mov TH1,#0FDH
mov TL1,#0FDH
;Start Timer
setb TR1
ret
Serial_Send:
;sent completely
jnb TI,Serial_Send
clr TI
mov SBUF,A
ret
Serial_Read:
jnb RI,Serial_Read
