Nguyên văn bởi kentsui8x
Code:
;TIME CLOCK FOR AT89C51 AND 1307 ;PROGRAMER :PCT ;PCTCOMPUTER - 0918227077 $MOD51 ;===================================== XUNG_NHAY DATA 38H ; XUNG 100ms BIEN_NHAY DATA 39H ;0 = SANG TAT CA DEN , 1 = NHAY led TUONG UNG KHI set GIAY DATA 40H PHUT DATA 41H GIO DATA 42H DONVI_GIAY DATA 47H CHUC_GIAY DATA 48H DONVI_PHUT DATA 49H CHUC_PHUT DATA 4AH DONVI_GIO DATA 4BH CHUC_GIO DATA 4CH PHAN_TRAM_GIAY DATA 4DH FLAG_SET DATA 4EH ;0 = KHONG SET , 1 = SET PHUT , 2 = SET GIO LED_GIAY BIT P2.0 LED_C_GIAY BIT P2.1 LED_PHUT BIT P2.2 LED_C_PHUT BIT P2.3 LED_GIO BIT P2.4 LED_C_GIO BIT P2.5 ;--------I2C------- SCL BIT P3.0 SDA BIT P3.1 SW_1 BIT P3.2 SW_2 BIT P3.3 SW_3 BIT P3.4 LED_DATA EQU P0 BYTE_W EQU 11010000B BYTE_R EQU 11010001B ADD_LOW EQU 62H DATA_DS EQU 63H ;===================================== ;===================================== ORG 00H LJMP MAIN ;=========================== ;=========================== ORG 0BH LJMP NGAT_TIME ;=========================== ;=========================== ORG 030H MAIN: ;reset tat ca cac bien MOV GIAY,#0 MOV PHUT,#0 MOV GIO,#0 MOV BIEN_NHAY,#0 MOV XUNG_NHAY,#0 MOV FLAG_SET,#0 MOV R0,#0 MOV IE,#10001010B MOV TMOD,#11H MOV TL0,#LOW(-9216) MOV TH0,#HIGH(-9216) SETB TR0 MOV A,#0FFH MOV LED_DATA,A MOV DPTR,#BANGSO CLR SCL CLR SDA NOP SETB SCL SETB SDA NOP MOV ADD_LOW,#00H MOV DATA_DS,#00H LCALL WRITE_BYTE ;========================================== LOOP_HIEN_THI: ; chuong trinh chinh chay tai day ;========================================== MOV A,FLAG_SET CJNE A,#0,L_HT CALL INIT_PORT L_HT: LCALL HIEN_THI LCALL SCAN_KEY SJMP LOOP_HIEN_THI ;========================================== INIT_PORT: ;==================================================READS SECONDS READ_SEC: MOV ADD_LOW,#00h LCALL READ_BYTE MOV GIAY,DATA_DS LCALL I2C_STOP ;==================================================READS MINUTES MOV ADD_LOW,#01h LCALL READ_BYTE MOV PHUT,DATA_DS LCALL I2C_STOP ;==================================================READS HOURS MOV ADD_LOW,#02h LCALL READ_BYTE MOV GIO,DATA_DS LCALL I2C_STOP RET ;================================================================================== ;=====stop I2C communication I2C_Stop: CLR SDA SETB SCL NOP SETB SDA RET ;================================================================================== ;***************************************************** ;* WRITE DATA_DS TO DS1307 1 BYTE * ;* INPUT : ADD_LOW * ;* : DATA_DS * ;***************************************************** WRITE_BYTE: CLR SDA ;start bit CLR SCL MOV A,#BYTE_W ;send control byte LCALL LOOP_BYTE SETB SDA SETB SCL JB SDA,WRITE_BYTE ;loop until busy CLR SCL MOV A,ADD_LOW ;send address low LCALL LOOP_BYTE SETB SDA SETB SCL JB SDA,WRITE_BYTE ;loop until busy CLR SCL MOV A,DATA_DS ;send DATA LCALL LOOP_BYTE SETB SDA SETB SCL JB SDA,WRITE_BYTE ;loop until busy CLR SDA CLR SCL SETB SCL ;stop bit SETB SDA RET ;****************************************************** ;* READ DATA FROM DS1307 1 BYTE * ;* INPUT : ADD_HIGH * ;* : ADD_LOW * ;* OUTPUT : DATA_DS * ;****************************************************** READ_BYTE: CLR SDA ;start bit CLR SCL MOV A,#BYTE_W ;send control byte LCALL LOOP_BYTE SETB SDA SETB SCL JB SDA,READ_BYTE ;loop until busy CLR SCL MOV A,ADD_LOW ;send address low LCALL LOOP_BYTE SETB SDA SETB SCL JB SDA,READ_BYTE ;loop until busy CLR SCL SETB SCL SETB SDA CLR SDA ;start bit CLR SCL MOV A,#BYTE_R ;send control byte LCALL LOOP_BYTE SETB SDA SETB SCL JB SDA,READ_BYTE ;loop until busy CLR SCL LCALL LOOP_READ SETB SDA SETB SCL CLR SCL SETB SCL ;stop bit SETB SDA RET ;**************************************************** ;* WRITE * ;* INPUT: ACC * ;**************************************************** LOOP_BYTE: PUSH 02H MOV R2,#08H LOOP_SEND: RLC A MOV SDA,C SETB SCL CLR SCL DJNZ R2,LOOP_SEND POP 02H RET ;***************************************************** ;* READ * ;* OUTPUT: ACC * ;***************************************************** LOOP_READ: PUSH 02H MOV R2,#08H LOOP_READ1: SETB SCL MOV C,SDA CLR SCL RLC A DJNZ R2,LOOP_READ1 MOV DATA_DS,A POP 02H RET ;========================================== TACHSO: ; tach rieng hang chuc va hang don vi bang cach chia cho 10 ;========================================== MOV A,GIAY ;Lan luot chia cac Bien: Giay, Phut, Gio cho 10 MOV B,#10H ;de tach phan Don Vi va Hang Chuc ra, de cat rieng vao cac Bien tuong ung. DIV AB ;PHAN NGUYEN trong A, PHAN DU trong B MOV CHUC_GIAY,A ;Luu lai HANG CHUC Giay MOV DONVI_GIAY,B ;luu lai DON VI Giay ;========== MOV A,PHUT MOV B,#10H DIV AB MOV CHUC_PHUT,A MOV DONVI_PHUT,B ;========== MOV A,GIO MOV B,#10H DIV AB MOV CHUC_GIO,A MOV DONVI_GIO,B RET ;======================================== HIEN_THI: ; HIEN THI LED 7 DOAN ;======================================== MOV A,FLAG_SET CJNE A,#0,CHOP_NHAY LCALL HIENTHI AJMP THOAT_HIENTHI ;======================================== CHOP_NHAY: ; KIEM TRA BIEN NHAY VA FLAG_SET DE TAO HIEU UNG NHAY LED DANG SETING ;================================= MOV A,BIEN_NHAY CJNE A,#0,CHOP_NHAY1 LCALL HIENTHI AJMP THOAT_HIENTHI CHOP_NHAY1: LCALL NHAY JMP CHOP_NHAY THOAT_HIENTHI: RET ;================================= HIENTHI: ;================================= LCALL HIENTHI_S LCALL HIENTHI_P LCALL HIENTHI_G RET ;================================= NHAY: ;================================= MOV A,FLAG_SET CJNE A,#1,KT1 LCALL HIENTHI_S LCALL HIENTHI_G KT1: MOV A,FLAG_SET CJNE A,#2,THOAT_N LCALL HIENTHI_S LCALL HIENTHI_P THOAT_N: RET ;================================= HIENTHI_S: ;================================= ;hien thi hang don vi cua Giay MOV A,DONVI_GIAY MOVC A,@A+DPTR MOV LED_DATA,A CLR LED_GIAY LCALL DL SETB LED_GIAY ;========== MOV A,CHUC_GIAY ;hien thi hang chuc cua Giay MOVC A,@A+DPTR MOV LED_DATA,A CLR LED_C_GIAY LCALL DL SETB LED_C_GIAY RET ;================================= HIENTHI_P: ;================================= MOV A,DONVI_PHUT ;hien thi hang don vi cua Phut MOVC A,@A+DPTR MOV LED_DATA,A CLR LED_PHUT LCALL DL SETB LED_PHUT ;============ MOV A,CHUC_PHUT ;hien thi hang chuc cua Phut MOVC A,@A+DPTR MOV LED_DATA,A CLR LED_C_PHUT LCALL DL SETB LED_C_PHUT RET ;================================= HIENTHI_G: ;================================= MOV A,DONVI_GIO ;hien thi hang don vi cua gio MOVC A,@A+DPTR MOV LED_DATA,A CLR LED_GIO LCALL DL SETB LED_GIO ;============ MOV A,CHUC_GIO ;hien thi hang chuc cua Gio MOVC A,@A+DPTR MOV LED_DATA,A CLR LED_C_GIO LCALL DL SETB LED_C_GIO RET ;================================= NGAT_TIME: ;================================= INC XUNG_NHAY INC PHAN_TRAM_GIAY ;DAT TIMER CHAY 1/100 GIAY MOV TL0,#LOW(-9216) MOV TH0,#HIGH(-9216) SETB TR0 ;=============== PUSH ACC PUSH PSW ;Thanh ghi trang thái chuong trình ;========== MOV A,XUNG_NHAY ;TAO XUNG NHAP NHAY = 1/4 GIAY CJNE A,#25,TIME1 MOV XUNG_NHAY,#0 INC BIEN_NHAY MOV A,BIEN_NHAY CJNE A,#3,TIME1 MOV BIEN_NHAY,#0 ;========== TIME1: MOV A,PHAN_TRAM_GIAY ;Kiem tra bien PHAN_TRAM_GIAY - Thoat khoi ngat Time0 neu khong = CJNE A,#100,THOAT_NGAT_TIME MOV PHAN_TRAM_GIAY,#0 ;Neu = 100 thì set bien nay = 0 ;=============== THOAT_NGAT_TIME: LCALL TACHSO POP PSW POP ACC RETI ;================================== SCAN_KEY: ;KIEM TRA PHIM NHAN ;================================== SW1: ;SET TIME JB SW_1,SW2 INC FLAG_SET MOV A,FLAG_SET CJNE A,#3,L_SW1 ;========== MOV ADD_LOW,#01H MOV DATA_DS,PHUT LCALL WRITE_BYTE ;========== MOV FLAG_SET,#0 L_SW1: LCALL DL1 LCALL DL1 LCALL DL1 LCALL DL1 LJMP NOKEY ;=============== SW2: ;SET_MIN JB SW_2,SW3 MOV A,FLAG_SET CJNE A,#0,SW20 LJMP NOKEY SW20: MOV A,FLAG_SET CJNE A,#1,TANG_GIO ; JB SW_2,SW3 ;=============== TANG_PHUT: INC PHUT ;Roi tang Bien phut them 1 MOV A,PHUT CJNE A,#60,L_SW2 ; MOV PHUT,#0 ;Neu = 60 thì set bien nay = 0 L_SW2: LCALL DL1 LCALL DL1 LJMP SW2 ;=============== TANG_GIO: ;SET HOUR JB SW_2,SW3 MOV A,FLAG_SET CJNE A,#2,SW3 JB SW_2,SW3 INC GIO ;Roi tang Bien Gio them 1 MOV A,GIO CJNE A,#24,L_TANG_GIO ;Bien gio = 60? - Thoat khoi ngat Time0 neu khong = MOV GIO,#0 L_TANG_GIO: LCALL DL1 LCALL DL1 LJMP TANG_GIO ;============================== SW3: ;DANG NHAN SW3? JB SW_3,NOKEY ;KHONG NHAN SW2? KIEM TRA SW3 MOV A,FLAG_SET CJNE A,#0,SW30 LJMP NOKEY SW30: MOV A,FLAG_SET ;DANG NHAN SW2. KIEM TRA CHE DO CHINH GIO HAY CHINH PHUT. CJNE A,#1,GIAM_GIO ; JB SW_3,NOKEY ;=============== GIAM_PHUT: DEC PHUT ;Roi tang Bien phut them 1 MOV A,PHUT CJNE A,#-1,L_SW3 ;Bien Phut = -1? - Thoat khoi ngat Time0 neu khong = MOV PHUT,#59 ;Neu = -1 thì set bien nay = 60 L_SW3: LCALL DL1 LCALL DL1 LJMP SW3 ;=============== GIAM_GIO: ;=============== JB SW_3,NOKEY MOV A,FLAG_SET CJNE A,#2,NOKEY LCALL HIENTHI JB SW_3,NOKEY DEC GIO ;Roi Giam Bien Gio them 1 MOV A,GIO CJNE A,#-1,L_GIAM_GIO ;Bien gio = -1? - Thoat khoi ngat Time0 neu khong = MOV GIO,#23 L_GIAM_GIO: LCALL DL1 LCALL DL1 LJMP GIAM_GIO ;=============== NOKEY: RET ;================================= DL: ;================================= MOV R7,#200 DJNZ R7,$ RET ;================== DL1: ;================== PUSH 00H PUSH 01H MOV R1,#20O DEL: LCALL HIEN_THI LCALL HIEN_THI LCALL HIEN_THI MOV R0,#250 DJNZ R0,$ DJNZ R1,DEL POP 01H POP 00H RET ;=================== DELAY_1MS: ;=================== MOV R7,#200 DL_1MS_1: MOV R6,#200 DJNZ R6,$ DJNZ R7,DL_1MS_1 RET ;==================== DELAY: ;==================== NOP NOP NOP NOP NOP NOP NOP NOP RET ;================================= BANGSO: ;================================= DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H RET END
