[QUOTE=hiepps1;622592]Anh ơi download giúp em hai bài này với ạ:
[1] IEEE Xplore - Simulation of Half Bridge Series Resonant PFC DC to DC converter
(Simulation of Half Bridge Series Resonant PFC DC to DC converter)
bài của bạn
download từ ieee
Nguyên văn bởi phamtrieu138 Xem bài viếtCác anh down ho em nốt mấy bài này nhé. em cảm ơn.
3>Self-oscillation flyback converter with lossless snubber for contactless power supply application
IEEE Xplore - Self-oscillation flyback converter with lossless snubber for contactless power supply application
4>Average and small-signal modeling of self-oscillating flyback converter with applied switching delay
IEEE Xplore - Average and small-signal modeling of self-oscillating flyback converter with applied switching delay
5>Modeling and analysis of a self-oscillating peak-current controlled flyback converter
IEEE Xplore - Modeling and analysis of a self-oscillating peak-current controlled flyback converter
Leave a comment:
[2] IEEE Xplore - Simulation and implementation of a 300 watt, cascade gama-LC resonant converter
(Simulation and implementation of a 300 watt, cascade gama-LC resonant converter)
Leave a comment:
Leave a comment:
Gửi bạn!
bài 2: https://www.dropbox.com/s/pmrx5sh1plr32t7/2.pdf
bài 10: https://www.dropbox.com/s/rdc21tqr9i3hf3k/10.pdfAttached Files
Leave a comment:
Giúp nốt em bài này với ạ thank anh:
[10] IEEE Xplore - A hybrid strategy with Simplified Optimal Trajectory Control for LLC resonant converters
(A hybrid strategy with Simplified Optimal Trajectory Control for LLC resonant converters )
Em đang cần so sánh các phương pháp điều khiển ạ.
Leave a comment:
Anh download giúp em mấy bài này với ạ.
1>Analysis of winding capacitance effects on ringing choke converters
IEEE Xplore - Analysis of winding capacitance effects on ringing choke converters
2>A Saturable Reactor Controlled Ringing Choke Converter
IEEE Xplore - A Saturable Reactor Controlled Ringing Choke Converter
Em xin cảm ơn các anh!
Leave a comment:
Gửi bạn!
good luck
Leave a comment:
Cảm ơn anh giúp em download mấy bài lần trước,em đã thiết kế đc bước đầu điều khiển LLC tuy nhiên bây giờ em muốn nâng cao chất lượng điều khiển của nó nên... Lại phiền anh download giúp em mấy bài báo này với ạ ^^!:
[7] IEEE Xplore - Multi-loop control for quasi-resonant converters
(Multi-loop control for quasi-resonant converters)
[8] IEEE Xplore - A comparative study of phase-shift, frequency, and hybrid control of the series resonant converter s...
(A comparative study of phase-shift, frequency, and hybrid control of the series resonant converter supplying the electric vehicle inductive charging interface)
[9] IEEE Xplore - A hybrid switching scheme for LLC series-resonant half-bridge dc-dc converter in a wide load range
(A hybrid switching scheme for LLC series-resonant half-bridge dc-dc converter in a wide load range)
Em xin cảm ơn trước ạ!
Leave a comment:
Leave a comment:
Nguyên văn bởi VAnhbk Xem bài viếtAnh download giúp em mấy bài này với ạ, em đang làm về mạch LLC resonant dc/dc converter mà thiếu tài liệu quá ạ:
[5] IEEE Xplore - A review and performance evaluation of control techniques in resonant converters
(A review and performance evaluation of control techniques in resonant converters)
[6] IEEE Xplore - Fixed-frequency PWM series-parallel resonant converter
(Fixed-frequency PWM series-parallel resonant converter )
[7] IEEE Xplore - Over current protection methods for LLC resonant converter
(Over current protection methods for LLC resonant converter)
[8] IEEE Xplore - 1MHz High Efficiency LLC Resonant Converters with Synchronous Rectifier
(1MHz High Efficiency LLC Resonant Converters with Synchronous Rectifier)
[9] IEEE Xplore - Using LLC Resonant Converter for Designing Wide-Range Voltage Source
(Using LLC Resonant Converter for Designing Wide-Range Voltage Source )
Leave a comment:
Leave a comment:
Leave a comment:
Nguyên văn bởi VAnhbk Xem bài viếtGiúp em down hộ bài báo này với ạ:
[4] IEEE Xplore - Envelope model for resonant converters and application in LLC converters
(Envelope model for resonant converters and application in LLC converters)
Leave a comment:
Leave a comment:
Trả lời cho Hàn chì thiếc lên nhôm.bởi vi van phamThôi uống rượu 1 mình vậy, Nhathung chắc chắn đêm nay vẫn chưa tĩnh. Bà lão phu nhân Nhathung lo sốt vó, miệng cứ lẩm bẩm : " già rồi mà cứ tưởng mình trai tơ ".
Hôm qua, 22:49 -
bởi ittc
Vâng, mà dùng cho gia đình, nên 8 đời mới sờ đến máy, chắc cũng lâu hỏng lắm bác. Hì...-
15-03-2025, 19:40 -
Trả lời cho Hàn chì thiếc lên nhôm.bởi nhathung1101Vẫn lo lắng, dặn Lão theo bí kíp lúc SÙ PHÙ nói:
- Tẩu Bả thì được.
- Nhập Hoa phải cẩn thận.
Nếu lão Nhập Hoa ở đâu, thì báo để em cho bọn đệ mang dung môi đến.-
15-03-2025, 00:11 -
Trả lời cho Hàn chì thiếc lên nhôm.bởi nhathung1101Đệ hỏi thì lão Bà nhà đệ bảo "Hàn cần gì dung môi".
Thôi thì đệ đi nghỉ, kiêm bế quan luyện công luôn.
Lão ở lại xem tình hình nhé, đứa nào láo báo em.
Thực tình là ghét bọn láo thôi mà... Nhất...-
15-03-2025, 00:05 -
Trả lời cho Hàn chì thiếc lên nhôm.bởi nhathung1101Gay thật rồi. Đại ka "tẩu bả nhập hoa" rồi. Bệnh này X Quang cũng không soi được đâu.
Để đệ gọi thần Y "Bói Toán Đi" đến giúp mới được....-
14-03-2025, 22:53 -
Trả lời cho Hàn chì thiếc lên nhôm.bởi vi van phamLão phu thức tỉnh lâu rồi.
Các hạ mãi mê múa "khẩu quyền" tranh giành chức vô địch võ lâm thì dương khí hao tổn, đèn khò hết ga, muốn hàn mấy con chip nhôm phải dùng dung môi.
Việc này lão phu không biết, hỏi bà lão phu nhân các hạ xem thế nào?...-
14-03-2025, 21:21 -
bởi nhathung1101Thực tế là tiện dụng hơn, nhưng cũng hay hỏng hơn, khó thay thế hơn....
14-03-2025, 20:34 -
bởi ittc
Bạn phân tích khá giống với 1 số bài viết trên mạng, kể ra thì loại gạt trượt và nhấn bóp có vẻ nhiều ưu điểm hơn cái anh công tắc đuôi...-
14-03-2025, 19:49 -
bởi nhathung1101Loại gạt trượt tôi thấy hay nhất, vì phù hợp với người thuận tay phải như tôi.
Khi dùng tay trái sẽ cầm phía chuôi máy, tay phải cầm trên, sẽ bật tắt hay ghì máy rất dễ. Dùng 1 tay cũng dễ.
Loại công tắc ở đuôi...-
14-03-2025, 16:10 -
Trả lời cho Hàn chì thiếc lên nhôm.bởi nhathung1101Lo ra phết. Từ hôm lão bị Bà í bắt ngủ chung đến giờ chưa thấy dậy.
Báo mộng cho em cách hàn khò lên nhôm nhé.
Nhôm dạo này bị Mỹ áp thuế nên rẻ rề. Em định hàn mấy con chip lên để hứng nắng. Kiếm tí điện đun trà.
14-03-2025, 15:42 -
Leave a comment:
