Nguyên văn bởi linhbui
download từ ieee
Nguyên văn bởi linhbui Xem bài viếtBạn ơi down giúp mình mấy tài liệu trên trang ieeeplore với. Bạn có thể gưi vào mail giúp mình nhé. mail : xuanlinhhp87@gmail.com
1. Message encoding and decoding through chaos modulation in chaotic optical communications
IEEE Xplore - Message encoding and decoding through chaos modulation in chaotic optical communications
2. Message modulation type secure communication characteristics using optical fiber ring resonator chaos
IEEE Xplore - Message modulation type secure communication characteristics using optical fiber ring resonator chao...
3. Synchronized chaotic optical communications at high bit rates
IEEE Xplore - Synchronized chaotic optical communications at high bit rates
4.Spectral synchronization in chaotic optical communication systems
IEEE Xplore - Spectral synchronization in chaotic optical communication systems
5.Cryptanalysis of chaotic masking secure communication systems using an adaptive observer
IEEE Xplore - Cryptanalysis of Chaotic Masking Secure Communication Systems Using an Adaptive Observer
6.The Capacity of Fiber-Optic Communication Systems
IEEE Xplore - The Capacity of Fiber-Optic Communication Systems
7.The channel capacity of a fiber optics communication system
IEEE Xplore - The channel capacity of a fiber optics communication system
8.Properties of fiber Raman amplifiers and their applicability to digital optical communication system
IEEE Xplore - Properties of fiber Raman amplifiers and their applicability to digital optical communication system...
9.Performance characterization of a closed-loop chaotic communication system including fiber transmistion in dispersion shifted fibers
IEEE Xplore - Performance characterization of a closed-loop chaotic communication system including fiber transmiss...
10.Role of Q factor and of time jitter in the performance evaluation of optically amplified transmission systems
IEEE Xplore - Role of Q-factor and of time jitter in the performance evaluation of optically amplified transmissio...
Leave a comment:
Leave a comment:
Nguyên văn bởi cristvn Xem bài viếtcác bác down giùm em bài này với.thankkkkk trc' nhé
Combining 2G and 3G (4G) BTS outputs sharing the same frequency band
A tool to calculate Erlang capacity of a BTS supporting 3G UMTS systemAttached Files
Leave a comment:
Leave a comment:
Nguyên văn bởi ptolemy Xem bài viếtEm nhờ mấy anh giúp em download dùm em những tài liệu sau trên IEEE. Em chân thành cảm ơn
IEEE Xplore - EMI/EMC for military aircraft and its challenges
IEEE Xplore - The past, present and future challenges of aircraft EMC
IEEE Xplore - EMC testing of high-integrity digital systems in aircraft
IEEE Xplore - EMC design of a modern fighter aircraft-a case study
IEEE Xplore - EMC modelling of drives for aircraft applications: Modelling process and optimisation of EMI filters
IEEE Xplore - EMC testing of whole aircraft
IEEE Xplore - EMC implications of using unshielded twisted pair data busses in the aircraft environment
IEEE Xplore - Aircraft EMC, the past, the present and the future: an overview
IEEE Xplore - Overview of a full-scale aircraft intersystem EMC test facility
IEEE Xplore - Electrical power and signal distribution in modern aircrafts, combines weight advantages and EMC com...
IEEE Xplore - EMC Modeling of Drives for Aircraft Applications: Modeling Process, EMI Filter Optimization and Tech...
IEEE Xplore - EMC modeling of drives for aircraft applications: Modeling process, EMI filter optimization and tech...
IEEE Xplore - EMC testing on airborne equipment
IEEE Xplore - Research progress of direct current injection technique in aircraft EMC testAttached Files- The past, present and future challenges of aircraft EMC.pdf (445.2 KB, 12 lượt xem)
- 00473704.pdf (260.0 KB, 6 lượt xem)
- EMC testing of high-integrity digital systems in aircraft.pdf (327.7 KB, 5 lượt xem)
- EMC for military aircraft and its challenges.pdf (460.2 KB, 10 lượt xem)
- 05419719.pdf (429.8 KB, 5 lượt xem)
Leave a comment:
Leave a comment:
mình đã down được rồi nhé. Các bạn k cần down hộ nữa đâu nhé. Thanks
Leave a comment:
Mạng lag nên post trùng. Tự xóa
Leave a comment:
Các bạn down hộ mình mấy bài báo này với. Cảm ơn nhiều nhé
Recognizing talking faces from acoustic Doppler reflections
Modeling and simulation on accuracy of broad band acoustic Doppler current profiler
Narrowband acoustic Doppler volume backscattering signal .II. Spectral centroid estimation
Narrowband acoustic Doppler volume backscattering signal .I. Evolutionary spectral analysis
Moored acoustic Doppler current profiler data reduction and database applications
Scattering statistics of Doppler faded acoustic signals using speckle noise models
Sensor localization using acoustic doppler shift with a mobile access point
Acoustic communication channel modeling for the Baltic Sea
Performance of Doppler estimation for acoustic sources with atmospheric scattering
On robust estimation of water current using a frequency domain approach: the Symmiktos methodLast edited by chessgenius; 10-08-2012, 11:05.
Leave a comment:
Nguyên văn bởi anh3vn Xem bài viếtThanhViendd ơi, nhờ bạn down giúp mình mấy tài liệu này được không:
1. Remote control system and its development for linear asynchronous motor
2. The asynchronous motor one-dimensional analysis
3. Innovative designs of high dynamic linear asynchronous motors
mail của mình: chunglb.ht@gmail.com
Cảm ơn vì đã giúp đỡ mọi người nhé ThanhViendd
Nhân tiện mình muốn hỏi là có bạn nào có thể download tài liệu ở trang http://www.sciencedirect.com không? ở bên này cũng nhiều tài liệu hay lắm.
https://www.sugarsync.com/pf/D435332_67913722_871039
Leave a comment:
Nguyên văn bởi dientuvie Xem bài viếtNhờ các bạn down giúp 2 bài này
1. Effects of YAG: Ce phosphor particle size on optical performance of white LEDs
IEEE Xplore - Abstract Page
2. Effect of the amount of phosphor silicone gel on optical property of white light-emitting diodes packaging
Xin cám ơn nhìu!!!
https://www.sugarsync.com/pf/D435332_67913722_871017
Leave a comment:
Nguyên văn bởi cdkhoa Xem bài viếtNhờ bạn down giúp mình tài liệu này với. Mình đang làm luận án
An Eclipse plug-in for the detection of design pattern instances through static and dynamic analysis
Mình cám ơn nhiều lắm!
https://www.sugarsync.com/pf/D435332_67913722_871072
Leave a comment:
Bạn nào có tài khoản down dùm cho các bạn đi, tài khoản mình hết hạn. Các bạn có thể xin tài liệu ở các trang khác mình thấy nhiều người giúp các bạn hơn.
Leave a comment:
Trả lời cho Hàn chì thiếc lên nhôm.bởi nhathung1101Vẫn lo lắng, dặn Lão theo bí kíp lúc SÙ PHÙ nói:
- Tẩu Bả thì được.
- Nhập Hoa phải cẩn thận.
Nếu lão Nhập Hoa ở đâu, thì báo để em cho bọn đệ mang dung môi đến.-
hôm nay, 00:11 -
Trả lời cho Hàn chì thiếc lên nhôm.bởi nhathung1101Đệ hỏi thì lão Bà nhà đệ bảo "Hàn cần gì dung môi".
Thôi thì đệ đi nghỉ, kiêm bế quan luyện công luôn.
Lão ở lại xem tình hình nhé, đứa nào láo báo em.
Thực tình là ghét bọn láo thôi mà... Nhất...-
hôm nay, 00:05 -
Trả lời cho Hàn chì thiếc lên nhôm.bởi nhathung1101Gay thật rồi. Đại ka "tẩu bả nhập hoa" rồi. Bệnh này X Quang cũng không soi được đâu.
Để đệ gọi thần Y "Bói Toán Đi" đến giúp mới được....-
Hôm qua, 22:53 -
Trả lời cho Hàn chì thiếc lên nhôm.bởi vi van phamLão phu thức tỉnh lâu rồi.
Các hạ mãi mê múa "khẩu quyền" tranh giành chức vô địch võ lâm thì dương khí hao tổn, đèn khò hết ga, muốn hàn mấy con chip nhôm phải dùng dung môi.
Việc này lão phu không biết, hỏi bà lão phu nhân các hạ xem thế nào?...-
Hôm qua, 21:21 -
bởi nhathung1101Thực tế là tiện dụng hơn, nhưng cũng hay hỏng hơn, khó thay thế hơn....
Hôm qua, 20:34 -
bởi ittc
Bạn phân tích khá giống với 1 số bài viết trên mạng, kể ra thì loại gạt trượt và nhấn bóp có vẻ nhiều ưu điểm hơn cái anh công tắc đuôi...-
Hôm qua, 19:49 -
bởi nhathung1101Loại gạt trượt tôi thấy hay nhất, vì phù hợp với người thuận tay phải như tôi.
Khi dùng tay trái sẽ cầm phía chuôi máy, tay phải cầm trên, sẽ bật tắt hay ghì máy rất dễ. Dùng 1 tay cũng dễ.
Loại công tắc ở đuôi...-
Hôm qua, 16:10 -
Trả lời cho Hàn chì thiếc lên nhôm.bởi nhathung1101Lo ra phết. Từ hôm lão bị Bà í bắt ngủ chung đến giờ chưa thấy dậy.
Báo mộng cho em cách hàn khò lên nhôm nhé.
Nhôm dạo này bị Mỹ áp thuế nên rẻ rề. Em định hàn mấy con chip lên để hứng nắng. Kiếm tí điện đun trà.
Hôm qua, 15:42 -
bởi nhathung1101Giờ mới đọc lại. Hiểu rồi. Mai sẽ khóa luồng.
Với bạn, 1 kỹ sư học 4 năm sẽ được cho qua.
Còn "công nhân" dù mới vào hay thâm niên không cần biết, là bị nhận trách nhiệm.
Tôi nghĩ, những người có lòng tự trọng sẽ không nói chuyện với bạn nữa đâu....-
Hôm qua, 15:36 -
bởi nhathung1101Vừa rồi, đến cái hãng YAMAHA còn phải triệu hồi xe ở VN. Lỗi là đục mài số máy.
Hãng giải thích do "công nhân" tự ý "sửa lại mà không hủy vỏ máy bị dập số lỗi".
Nhưng hãng phải chịu trách nhiệm...-
Hôm qua, 15:26 -
Leave a comment:
