Nguyên văn bởi se7en0502
download từ ieee
Nguyên văn bởi se7en0502 Xem bài viếtHiện mình đang cần các bài báo này để làm luận án, bạn có thể download giúp mình không ? cảm ơn rất nhiều
1. AAA protocols: authentication, authorization, and accounting for the Internet
2. AAA-based infrastructure for industrial wireless sensor networks
3. Extending AAA Operational Model for Profile-Based Access Control in Ethernet-Based Neutral Access Networks
4. IEEE Xplore Abstract - A Novel Compromise-Resilient Authentication System for Wireless Mesh Networks
5. A novel service-oriented AAA architecture
6. Efficient Authentication and Authorization of Mobile Users Based on Peer-to-Peer Network Mechanisms
7.A New Scheme for Unified-Authentication in BcN
8.A scheme for authentication and dynamic key exchange in wireless networks
9.Advanced authentication and authorization for quality of service signaling
10. Architecture & system design of Authentication, Authorization, & Accounting services
11. AAA: a survey and a policy-based architecture and framework
12. A Framework to Add AAA Functionalities in IP Multicast
13. Diameter-based AAA architecture to support small AAA client
14. A uniform AAA handling scheme for heterogeneous networking environments
15. Enhanced Authentication Mechanism for Next Generation Networks
16. AAA Architecture for Unified Configuration Management in Large-Scale Network
17. Authentication, authorization, and accounting real-time secondary market services
18. A network access control approach based on the AAA architecture and authorization attributes
19.Authentication, Authorization and Accounting Framework for Multicast Content Delivery
20. Secure Distributed AAA with Domain and User Reputation
21. New Location-Based Authentication Techniques in the Access Management
22. Analysis, Implementation and Extensions of RADIUS Protocol
23. An optimal key agreement mechanism for AAA architecture
24. Extensions of AAA for future IP networks
25. Implementing a Secure AAA System in IPv6 Network
Hiện nay mình cần bài báo này. Bác nào làm ơn down dum em với
https://ieeexplore.ieee.org/xpl/arti...ber%3A5265562)
cảm ơn rất nhiều
hôm nay, 00:35 -
Qua cổng song song LPT cổ
Hôm qua, 15:56 -
Hôm qua, 15:32 -
Channel: Vi điều khiển AVR
21-11-2024, 21:00 -
21-11-2024, 16:20 -
21-11-2024, 15:10 -
21-11-2024, 15:10 -
20-11-2024, 14:40 -
Channel: từ PIC tới dsPIC
20-11-2024, 07:20 -
19-11-2024, 22:44 -
