download từ ieee
Falleaf
chào các bác, mình đang cần 1 số tài liệu tham khảo trên IEEE để làm đề tài nhưng không có account
bác nào có thể down giúp mình 1 số tài liệu sau đây được không?
Xin trân thành cảm ơn.
1. N.Nabona, J.Castro, J.A.Gonzalez. Optimum Long-term Hydrothermal Coordination with Fuel Limit, IEEE Transaction on Power System, Vol.10, No.2. May 1995.
http://ieeexplore.ieee.org/Xplore/lo...rnumber=387951
2.A.A.F.Mcarneiro, S.Soares, P.S.Bond, Alarge scale application of an optimal deterministic hydrothermal scheduling algorithm, IEEE Transactions on Power System, Vol. 5,No.1, February 1990.
http://ieeexplore.ieee.org/xpl/freea...arnumber=49107
3.M.K.C.Marwali, S.M.Shahidehpour, Coordination between long-term and short-term generation scheduling with network constraints, IEEE Transactions on Power System, Vol.5.No.3, August 2000.
http://ieeexplore.ieee.org/xpl/freea...rnumber=871749
4.Pang, C.K, Chen,H.C. Optimal Short-Term Thermal Unit Commitment, IEEE Trans. Power system, Vol. PAS-95, No.4, pp.1336-1346, Jul./Aug. 1976.
http://ieeexplore.ieee.org/xpl/freea...number=1601830
5.Development of a profit maximisation Unit commitment program. The University of Manchester institute of Science and Technology, September 2000.
http://ieeexplore.ieee.org/Xplore/lo...146.pdf?temp=x
6.Generator bidding in oligopolistic electricity markets using optimal control: fundamentals and application
http://ieeexplore.ieee.org/Xplore/lo...number=1664938
7.Optimal dispatch under transmission contracts Fang, R.S. David, A.K.
Dept. of Electr. Eng., Hong Kong Polytech., Kowloon;
http://ieeexplore.ieee.org/xpl/freea...rnumber=761905
8.Optimal response of a thermal unit to an electricity spot market
Arroyo, J.M. Conejo, A.J.
Dept. de Ingenieria Electr. y Electron., Univ. de Castilla-La Mancha;
http://ieeexplore.ieee.org/xpl/freea...rnumber=871739
9.Power generation planning and risk management in a liberalisedmarket
Bjorkvoll, T. Fleten, S.-E. Nowak, M.P. Tomasgard, A. Wallace, S.W.
SINTEF Ind. Manage., Trondhei
http://ieeexplore.ieee.org/xpl/freea...rnumber=964636
Cam on TAOLAO nhe. May hom nay di CT, phai nho dua em vao lay ho tai lieu nen khong cam on ban dc. Nhan tien lay ho cai nay voi :
Measuring bottleneck bandwidth of targeted path segments
Harfoush, K.; Bestavros, A.; Byers, J.
INFOCOM 2003. Twenty-Second Annual Joint Conference of the IEEE Computer and Communications Societies. IEEE
Volume 3, Issue , 30 March-3 April 2003 Page(s): 2079 - 2089 vol.3
Digital Object Identifier
Summary: Accurate measurement of network bandwidth is crucial for network management applications as well as flexible Internet applications and protocols which actively manage and dynamically adapt to changing utilization of network resources. Extensive work has focused on two approaches to measuring bandwidth: measuring it hop-by-hop, and measuring it end-to-end along a path. Unfortunately, best-practice techniques for the former are inefficient, and techniques for the latter are only able to observe bottlenecks visible at end-to-end scope. In this paper, we develop end-to-end probing methods which can measure bottleneck bandwidth along arbitrary, targeted subpaths of a path in the network, including subpaths shared by a set of flows. We evaluate our technique through extensive ns simulations, then provide a comparative Internet performance evaluation against hop-by-hop techniques. We also describe a number of applications which we foresee as standing to benefit from solutions to this problem, ranging from network troubleshooting and capacity provisioning to optimizing the layout of application-level overlay networks to optimized replica placement.
Bác down giùm em bài báo này với:
Wind Generator Stabilization With Doubly-Fed Asynchronous Machine
Li Wu; Zhixin Wang
Power Electronics and Motion Control Conference, 2006. IPEMC apos;06. CES/IEEE 5th International
Volume 1, Issue , 14-16 Aug. 2006 Page(s):1 - 6
ThanksBiển học vô bờ
Nguyên văn bởi vatech Xem bài viếtchào các bác, mình đang cần 1 số tài liệu tham khảo trên IEEE để làm đề tài nhưng không có account
Xin cám ơn và hậu tạ
http://ieeexplore.ieee.org/xpl/freea...rnumber=964636Phen này ông quyết buôn băng dính,
Vừa bán vừa hm... hm... cũng đắt hàng.
Nguyên văn bởi Kekhukho Xem bài viếtBác down giùm em bài báo này với:
Li Wu; Zhixin Wang
ThanksPhen này ông quyết buôn băng dính,
Nguyên văn bởi 207.207 Xem bài viếtCam on TAOLAO nhe. May hom nay di CT, phai nho dua em vao lay ho tai lieu nen khong cam on ban dc. Nhan tien lay ho cai nay voi :
Summary: Accurate measurement of network bandwidth is crucial for network management applications as well as flexible Internet applications and protocols which actively manage and dynamically adapt to changing utilization of network resources. Extensive work has focused on two approaches to measuring bandwidth: measuring it hop-by-hop, and measuring it end-to-end along a path. Unfortunately, best-practice techniques for the former are inefficient, and techniques for the latter are only able to observe bottlenecks visible at end-to-end scope. In this paper, we develop end-to-end probing methods which can measure bottleneck bandwidth along arbitrary, targeted subpaths of a path in the network, including subpaths shared by a set of flows. We evaluate our technique through extensive ns simulations, then provide a comparative Internet performance evaluation against hop-by-hop techniques. We also describe a number of applications which we foresee as standing to benefit from solutions to this problem, ranging from network troubleshooting and capacity provisioning to optimizing the layout of application-level overlay networks to optimized replica placement.Phen này ông quyết buôn băng dính,
Available Bandwidth Measurement on any Target Link Using Prioritized Packet-Pair Probes
Wei-Xuan, Gu; Shun-Zheng, Yu
TENCON 2006. 2006 IEEE Region 10 Conference
Volume , Issue , 14-17 Nov. 2006 Page(s):1 - 4
Digital Object Identifier 10.1109/TENCON.2006.343827
Summary:Available bandwidth plays a very important role in Web and Internet applications such as route selection, load balancing and network security. This paper presents a novel technique of prioritized packet-pair probes for available bandwidth measurement. The new measurement overcomes traditional methods in that it needs no path assumptions and it works very well on any target link even under high traffic load conditions. The experiment results validate the new method and show good performances in tracking traffic variances
One way delay trend detection for available bandwidth measurement
Chobanyan, A. Mutka, M. Zhiwei Cen Ning Xi
Dept. of Comput. Sci. & Eng., Michigan State Univ., USA;
This paper appears in: Global Telecommunications Conference, 2005. GLOBECOM '05. IEEE
Publication Date: 28 Nov.-2 Dec. 2005
Volume: 2, On page(s): 5 pp.-
ISBN: 0-7803-9414-3
INSPEC Accession Number: 8946277
Digital Object Identifier: 10.1109/GLOCOM.2005.1577809
Date Published in Issue: 2006-01-23 09:15:22.0
Abstract
Available bandwidth (AB) defined as a minimum spare capacity of links constituting a network path is an important QoS characteristic of the path. We propose to improve a whole range of "probe-rate" AB measurement tools that send sequences of measurement packets (called "trains") across the network path. If transmission times of packets in the train, called one way delays (OWD), show an increasing trend as packet sequence number in the train increases, then AB is believed to be lower than the rate at which the train was sent. In contrast, an absence of a trend indicates that AB is higher than the rate of the train. We propose an algorithm for efficient OWD trend detection and compare it to widely used OWD trend detection tests.
Bác TAOLAO lấy hộ cái này nữa với.
Cảm ơn nhiều nhiều.
Nguyên văn bởi 207.207 Xem bài viếtAvailable Bandwidth Measurement on any Target Link Using Prioritized Packet-Pair Probes
ISBN: 0-7803-9414-3
Abstract
Cảm ơn nhiều nhiều.
@vatech: Bạn chỉ cần click nút "cảm ơn", ko cần hậu tạ gì đâu. Chỉ click chuột thôi mà, chẳng tốn công sức gì cả. Trước đây lúc làm LATN mình cũng nhờ 1 người bạn download dùm mấy bài ở IEEE. Bây giờ mình có điều kiện thì download dùm bạn thôi. Nếu mai này bạn có điều kiện thì bạn cũng làm như vậy là được rồi.Phen này ông quyết buôn băng dính,
Có bài này chắc sẽ giúp các bạn từ download được bài báo IEEE cho mình.
How to get access for literature by CODEEN
If you want to know about codeen, you can search in google:
The proxy of codeen is too many, you can get easily.
What I tell you is how to use the codeen proxy to get some literature,maybe some people have know about it.
1. First I you can a proxy of codeen at: http://fall.cs.princeton.edu/codeen
2. You will find a “good” proxy as pic shown. Don’t choose the proxy which port of 3124/3128/3127 is blocking, it is very important to choose proxy.
Here, I choose 198.163.152.229.
3. open http://all-nettools.com/toolbox( thanks peter02402), locat this proxy.
Result as following:
scientific institution is very good.
4. Change the proxy of our browser to 198.163.152.229, notice:the port must be fill in 3128or 3124,3127.
My browser is firefox:
5. Now, I take the sciendirect as example:
open science.adsense-seo.net, it redirect www. Sciendirect.com(198.81.200.2). don’t open www.sciendirect.com at your brower,because all proxy of codeen has hold back most all domain of literature site. You must know a domain which can redirect datebase of literature directely.I will provide some for you.
6. You can search some article:
7. I go to University of Florida Libraries and find http://www.uflib.ufl.edu/afa/
Click it and I see:
domain MY domain IP
http://www.sciencedirect.com/ science.adsense-seo.net 198.81.200.2
http://ieeexplore.ieee.org ieee.adsense-seo.net 140.98.193.112
http://www.proquest.com/ proquest.adsense-seo.net 192.195.245.135
http://gateway.ovid.com/ ovid.adsense-seo.net 192.84.75.109
http://www.springerlink.com/ spring.adsense-seo.net 203.98.210.65
NetLibrary.adsense-seo.net 216.52.36.1
Acs.adsense-seo.net 216.143.112.80
indian.adsense-seo.net 203.110.246.22
spring.adsense-seo.net springer.lib.tsinghua.edu.cn 203.98.210.65
wiley.adsense-seo.net 208.215.179.155
CRCnetbase: http://crcnetbas.ddns.usLast edited by vaiduakhu; 08-06-2008, 09:28.
Qua cổng song song LPT cổ
22-11-2024, 15:56 -
22-11-2024, 15:32 -
Channel: Vi điều khiển AVR
21-11-2024, 21:00 -
21-11-2024, 16:20 -
21-11-2024, 15:10 -
21-11-2024, 15:10 -
20-11-2024, 14:40 -
Channel: từ PIC tới dsPIC
20-11-2024, 07:20 -
19-11-2024, 22:44 -
