tư vấn orcad 9.2 capture -> layout
  • tư vấn orcad 9.2 capture -> layout
    nếu có post sai chỗ mod chỉnh lại dùm e
    em mới bắt đầu làm mạch và đang xài orcad 9.2
    cụ thể em đang làm mạch đèn báo có người đi qua bằng led hồng ngoại
    em vẽ bên capture đúng, đã gắn chân đầy đủ
    khi em check lỗi thì ko báo lỗi j , em chuyển qua file mnl
    khi qua layout em bật thì lại báo lỗi
    AutoECO Error Report
    FILE-A: C:\USERS\WIN7\DESKTOP\B3\1.MAX
    FILE-B: C:\USERS\WIN7\DESKTOP\B3\B3.MNL
    ERROR: Electrical package TR_2_IS_N_A for comp Q1 has 6 pins,
    but footprint TO92 (TRANSISTOR) has only 3 pins.
    Please assign a footprint with at least 6 pins.
    ERROR: Electrical package TR_2_IS_N_A for comp Q2 has 6 pins,
    ERROR: Electrical package LED for comp D1 has at least one pin (CATHODE)
    which has no corresponding pin on footprint LED 5 LY.
    You may create or modify a footprint, choose another,
    or press Cancel at the main dialog to skip this component.
    ERROR: Electrical package LED for comp D2 has at least one pin (CATHODE)
    ERROR: No footprint found for comp Q1
    ERROR: No footprint found for comp Q2
    ERROR: No footprint found for comp D1
    ERROR: No footprint found for comp D2
    Unable to complete ECO due to errors
    4 errors found
    AutoECO Report
    If "*EOF*" immediately follows, no changes were made
    Adding footprint DIP 8
    Adding footprint RESISTOR 1/4W
    Adding footprint TU 104 630V
    Adding footprint BUTTON SMALL
    Adding footprint TO92 (TRANSISTOR)
    Adding footprint DOMINO SMALL 2
    Adding footprint TU PI
    Adding footprint BIEN TRO XANH
    Adding footprint LED 5 LY
    Adding package IC_NE555_2
    Adding package R
    Adding package C
    Adding package E:\SOFT\ORCAD 9.2\CAPTURE\LIBRARY\OLDLIBS\PCBDEV.OLB/R
    Adding package SW_NO
    Adding package TR_2_IS_N_A
    Adding package HEADER_2
    Adding package CAPACITOR
    Adding package RESISTOR_VAR
    Adding package LED
    Adding component U1
    Adding component R5
    Adding component C1
    Adding component R2
    Adding component U2
    Adding component Q1
    Adding component R1
    Adding component R3
    Adding component JP1
    Adding component R4
    Adding component Q2
    Adding component C2
    Adding component VR1
    Adding component D1
    Adding component D2
    *EOF*
    4 errors found
    mong mọi người giúp, cảm ơn!!!
luciusmalfoy Tìm hiểu thêm về luciusmalfoy
