Cập nhật một số loại LK mới kèm số lượng và đơn giá.
This topic is closed.
  • Cập nhật một số loại LK mới kèm số lượng và đơn giá.
    Ten Mieu ta SL Don gia TT
    INA, PGA, XTR REF, ISO
    ISO122 Precision Lowest Cost Isolation Amplifier 104 180,000
    ISO124 Precision Lowest Cost Isolation Amplifier 5 120,000
    INA101 Very High Accuracy Instrumentation Amplifier 65 130,000
    PGA205
    Programmable Gain Instrumentation Amplifier 55 160,000
    XTR105 4-20mA Current Transmitter with Sensor Excitation and Linearization 30 90,000
    XTR106 4-20mA Current Transmitter with Bridge Excitation And Linearization 34 90,000
    INA103 Low Noise, Low Distortion Instrumentation Amplifier 40 80,000
    PGA204 Programmable Gain Instrumentation Amplifier 55 160,000
    VFC320 Voltage-to-Frequency and Frequency-to-Voltage Converter 50 200,000
    XTR101 Precision, Low Drift 4-20mA Two-Wire Transmitter 35 50,000
    INA114 Precision Instrumentation Amplifier 110 100,000
    XTR110 Precision Voltage-To-Current Converter/Transmitter 30 120,000
    INA110 Fast-Settling FET-Input Very High Accuracy Instrumentation Amplifier 47 150,000
    RCV420 Precision 4mA to 20mA Current Loop Receiver 80 100,000
    INA106 Precision Gain = 10 Differential Amplifier 50 80,000
    INA118 Precision, Low Power Instrumentation Amplifier 40 100,000
    PGA202 Digitally Controlled Programmable-Gain Instrumentation Amp 15 130,000
    VFC110 High Frequency Voltage-to-Frequency Converter 35 200,000
    INA128 Precision, Low Power Instrumentation Amplifiers 14 80,000
    INA105 Precision Unity Gain Differential Amplifier 10 50,000
    INA129 Precision, Low Power Instrumentation Amplifiers 10 80,000
    PGA203 Digitally Controlled Programmable-Gain Instrumentation Amp 5 130,000
    INA131 Precision G = 100 Instrumentation Amplifier 5 100,000
    PGA206 High-Speed Programmable Gain Instrumentation Amplifier 5 170,000
    PGA207
    High-Speed Programmable Gain Instrumentation Amplifier 10 200,000 2000000
    INA326EA Precision, Rail-To-Rail I/O Instrumentation Amplifier 10 40,000 400000
    PGA309 Voltage Output Programmable Sensor Conditioner 45 60,000 2700000
    REF200 Dual Current Source/Current Sink 20 50,000 1000000
    INA125 Instrumentation Amplifier with Precision Voltage Reference 5 50,000
    INA166 Low-Noise, Low-Distortion, G=2000 Instrumentation Amplifier 5 100,000 500000
    ISO150 Dual, Isolated, Bi-Directional Digital Coupler 7 130,000 910000
    UFA42
    Universal Active Filter 50 120,000 6000000
    AD Converter
    ADS7800 12-bit 333KHZ SMPL 17 550,000 9350000
    ADS1211 24-BIT DELTA-SIGMA 70 200,000 14000000
    ADS7807 16-BIT 40KHZ SMPL 46 500,000 23000000
    ADS7824 12-bit 4ch smpl 35 250,000 8750000
    ADS7825 16-BIT 4CH A/D 28DIP 48 550,000 26400000
    ADS7811 16-BIT 250KHZ A/D 28SOIC 17 550,000 9350000
    ADS7813 16-BIT A/D LP SERIAL 16DIP 19 350,000 6650000
    ADS7812 12-BIT A/D LP SERIAL 16DIP 25 200,000 5000000
    ADS1213 22-bit delta-sigma a/d 24dip 20 160,000 3200000
    ADS7806 12-BIT 10 200,000 2000000
    ADS1286 12-BIT 200KHZ UNIPOL A/D 8DIP 10 70,000 700000
    TLV2543 12-BIT 66KSPS AD 27 80,000 2160000
    ADS1210 24-BIT DELTA-SIGMA 15 180,000 2700000
    ADS7805 16-BIT 100KHZ A/D 28DIP 4 450,000 1800000
    ADS7841 12-BIT 4-CH SER A/D 16-DIP 5 50,000 250000
    ADS801U 12-BIT A/D 28SOIC 5 200,000 1000000
    ADS7804 12-BIT 10US AD 28DIP 10 320,000 3200000
    ADS8509 16BIT 250KSPS SRL 20SOIC 5 400,000 2000000
    ADS7818 12-BIT 500KHZ AD 8DIP 10 50,000 500000
    DDC101U 20-B A/D 24SOIC 1 400,000 400000
    ADS574 17 320,000 5440000
    ADS774 53 400,000 21200000
    TLC549IP 20 20,000 400000
    DA Converter
    TLV5618 DUAL 12BIT DAC 34 80,000 2720000
    DAC715 16-B DA 28SOIC 60 300,000 18000000
    DAC716 16-B DA 16SOIC 25 250,000 6250000
    DAC813 12-B DA 28SOIC 5 200,000 1000000
    DAC8831 16-B VOUT 14SOIC 10 150,000 1500000
    DAC7541 12-B DA 18DIP 40 140,000 5600000
    DAC7744 16-B DAC 48SSOP 1 500,000 500000
    DAC7724 12-BIT QUAD D/A 28PLCC 40 200,000 8000000
    TLV5610 8-CH DAC S/O 20SOIC 5 150,000 750000
    TLV5630IDW 12BIT 8CH DAC 20SOIC 5 150,000 750000
    MAX232IN 120 9,000 1080000
    ULn2803 120 15,000 1800000
    TL16C552AIFN 35 70,000 2450000
    TL16C754BFN 25 120,000 3000000
    TL16C550CN 20 35,000 700000
    PCF8575 15 25,000 375000
    TL16C750FN 10 50,000 500000
    PCF8574 10 20,000 200000
    DRV1100P 5 50,000 250000
    SN75LBC176 50 20,000 1000000
    SN65HVD05 10 25,000 250000
    SN65HVD23 5 30,000 150000
    SN65LBC174 5 40,000 200000
    RTC
    BQ2204APN
    SRAM NONVILTILE CNTRLR 16DIP 20 40,000 800000
    BQ3287EAMT RTC MOD W/242X8 NVSRAM T-MOD 2 65,000 130000
    BQ4285P-SB2 RTC W/114X8 NVSRAM 24-DIP 20 40,000 800000
    BQ48SH-28X6NSH SNAPHAT W/BATT AND CRYSTAL 20 65,000 1300000
    BQ4845P-A4 RTC W/NVSRAM CONTROL 28DIP 5 40,000 200000
    TLE2024IN OP AMP QUAD HS LP 14DIP 5 25,000 125000
    TLV2474 R-TO-R OP AMP QUAD 14DIP 15 20,000 300000
    TLC594NT LED DRV 16CH W/PWM 28DIP 5 10,000 50000
    TLC556 CMOS TIMER 5 8,000 40000
    TLC2201IP
    LN PREC R-TO-R OPAMP 8DIP 5 30,000 150000
    TLC3704IN VOLT COMPARATOR QUAD 14DIP 5 10,000 50000
    TIR1000PSR IRDA ENCODER/DECODER 8SOP 5 20,000 100000
    TLC2654AIP ADV LOW-NOISE OPAMP 8DIP 5 30,000 150000
    TLE2425ILP 2.5V PREC GRND TO92 5 20,000 100000
    THS4601IDDA OPAMP FET INPUT HS 8SOIC 5 180,000 900000
    TLC1078IP DUAL MCPWR LV OPAMP 8 DIP 5 40,000 200000
    MSP430F425IPM
    16-bit Ultra-Low-Power Microcontroller, 16KB Flash, 512B RAM, Sigma-Delta ADC, 128 Seg LCD 3 80,000 240000
    TPS71501 50-mA, Output Adj from 1.2 to 15V, High Input-Voltage (up to 24V) LDO Voltage Regulator in SC-70 5 8,000 40000
    MSC1211Y5PAGT 8051 CPU with 32kB Memory, I2C, 24-Bit ADC, and Quad 16-Bit DACs 2 350,000 700000
    MSC1210Y5PAGT Precision Analog-to-Digital Converter (ADC) with 8051 Microcontroller and 32k Flash Memory 1 200,000 200000
    MSC1210Y4 Precision Analog-to-Digital Converter (ADC) with 8051 Microcontroller and 32k Flash Memory 1 180,000 180000
    MSC1210Y2 Precision Analog-to-Digital Converter (ADC) with 8051 Microcontroller and 32k Flash Memory 1 160,000 160000
    MSC1212Y5 8051 CPU with 32kB Memory, 24-Bit ADC, and Quad 16-Bit DACs 2 350,000 700000 TUSB3410 RS232/IrDA Serial-to-USB Converter 5 40,000 200000
    UC3625N Brushless DC Motor Controller 15 80,000 1200000
    UC2637 Switched Mode Controller for DC Motor Drive 20 60,000 1200000
    UC3770 High Performance Stepper Motor Drive Circuit 10 40,000 400000
    UC3638 Advanced PWM Motor Controller 20 50,000 1000000
    UC2638 Advanced PWM Motor Controller 5 60,000 300000
    UC2610 Dual Schottky Diode Bridge 20 45,000 900000
    UC3717 Stepper Motor Drive Circuit 20 45,000 900000
    UC3637 Switched Mode Controller for DC Motor Drive 5 50,000 250000
    UC3176 Full Bridge Power Amplifier 10 100,000 1000000
    THS9000DRDT 50 MHz to 400 MHz Casadable Amplifier 5 20,000 100000
    UC3611 Quad Schottky Diode Array 5 30,000 150000
    UC5180 Low-Speed Asynchronous Octal Line Receiver 5 50,000 250000
    OPA4227 High Precision, Low Noise Operational Amplifiers 36 65,000 2340000
    OPA37 Ultra-Low Noise Precision Operational Amplifiers 25 25,000 625000
    OPA4277 High Precision Operational Amplifiers 20 60,000 1200000
    OPA2132 High Speed FET-Input Operational Amplifiers 5 80,000 400000
    OPA842ID Wideband, Low Distortion, Unity Gain Stable, Voltage Feedback Operational Amplifier 5 30,000 150000
    OPA549 High-Voltage, High-Current Op Amp, Excellent Output Swing 10 200,000 2000000 OPA4228 High Precision, Low Noise Operational Amplifiers 5 70,000 350000
    OPA27 Ultra-Low Noise Precision Operational Amplifiers 10 20,000 200000
    OPA2544 High-Voltage, High-Current Dual Operational Amplifier 30 200,000 6000000
    OPA2107 Precision Dual Difet(R) Operational Amplifier 5 120,000 600000
    OPA277 High Precision Operational Amplifiers 10 40,000 400000
    OPA602 High-Speed Precision Difet(R) Operational Amplifier 50 100,000 5000000
    OPA177 Precision Operational Amplifier 65 40,000 2600000
    OPA606 Wide-Bandwidth Difet(R) Operational Amplifier 10 55,000 550000
    OPA227 High Precision, Low Noise Operational Amplifiers 40 40,000 1600000
    OPA445AP High Voltage FET-Input Operational Amplifier 5 200,000 1000000
    OPA404 Quad High Speed Precision Difet(R) Operational Amplifier 5 120,000 600000
    OPA2277 High Precision Operational Amplifiers 10 60,000 600000 OPA544 High-Voltage, High-Current Operational Amplifier 10 120,000 1200000
    OPA4345 Low Power, Single-Supply, Rail-To-Rail Operational Amplifiers MicroAmplifier(TM) Series 5 35,000 175000
    OPA2822 SpeedPlus Dual Wideband, Low-Noise Operational Amplifier 5 25,000 125000
    OPA2111 Dual Low-Noise Difet(R) Operational Amplifie 15 130,000 1950000
    OPA2355 2.5V, 200MHz GBW, CMOS Dual Op Amp With Shutdown 5 30,000 150000
    CD74FCT245 BiCMOS FCT Interface Logic Octal Non-Inverting Bus Transceivers with 3-State Outputs 40 12,000 480000
    SN74HCT540NE4 Octal Buffers And Line Drivers With 3-State Outputs 10 5,000 50000 CD74ACT244EE4 Octal Non-Inverting Buffers/Line Drivers with 3-State Outputs 10 8,000 80000 CD74HC86EE4 High Speed CMOS Logic Quad 2-Input Exclusive-OR Gates 20 6,500 130000 CD40147BEE4 10-Line to 4-Line BCD Priority Encoder 20 15,000 300000
    CD74HC154ENE4 High Speed CMOS Logic 4-to-16 Line Decoder/Demultiplexer 10 10,000 100000 SN74F240NE4 Octal buffers and line drivers 10 7,000 70000
    SN74LS163ANE4 Synchronous 4-Bit Binary Counters 20 6,000 120000
    CD74HC147EE4 High Speed CMOS Logic 10-to-4 Line Priority Encoder 10 5,000 50000 SN754410NEE4 Quadruple Half-H Drivers 10 20,000 200000
    SN74HC266NE4 Quadruple 2-Input Exclusive-NOR Gates With Open-Drain Outputs 10 4,000 40000
    SN74ABT652ANTE4 Octal Registered Transceivers With 3-State Outputs 20 20,000 400000 CD74AC541EE4 Non-Inverting Octal Buffer/Line Drivers with 3-State Outputs 10 8,000 80000 SN74HC259NE4 8-Bit Addressable Latches 10 4,000 40000
    SN74ALS373ANE4 Octal D-Type Transparent Latches with 3-state Outputs 10 10,000 100000 SN74LS04NE4 Hex Inverters 10 5,000 50000
    SN74AHCT04NE4 Hex Inverters 10 4,000 40000
    SN74LS540NE4 Octal Buffers and Line Drivers with 3-State Outputs 10 15,000 150000 CD4033BEE4 CMOS Decade Counter/Divider with Decoded 7-Segment Display Outputs and Ripple Blanking 10 20,000 200000
    CD74HCT240EE4 High Speed CMOS Logic Inverting Octal Buffer/Line Drivers with 3-State Outputs 40 8,000 320000
    CD74HCT4351EE4 High Speed CMOS 8-Channel Analog Multiplexer/Demultiplexer with Latch 10 8,000 80000
    CD74HC32EE4 High Speed CMOS Logic Quad 2-Input OR Gates 20 5,000 100000
    CD74HC540EE4 High Speed CMOS Logic Octal Inverting Octal Buffers and Line Drivers with 3-State Outputs 10 8,000 80000
    CD74HC297 High Speed CMOS Logic Digital Phase-Locked-Loop 10 30,000 300000
    SN74LS541NE4 Octal Buffers and Line Drivers with 3-State Outputs 10 10,000 100000 SN74ALS109ANE4 Dual J-K Positive-Edge-Triggered Flip-Flops With Clear and Preset 10 10,000 100000
    SN74ALS29827NTE4 10-Bit Buffers/Drivers With 3-State Outputs 10 80,000 800000
    CD74AC138 3-Line to 8-Line Inverting Decoders/Demultiplexers 10 5,000 50000
    SN74ALS688 8-Bit Identity/Magnitude Comparators (P=Q) with Enable 10 70,000 700000 CD4521BEE4 CMOS 24-Stage Frequency Divider 10 7,000 70000
    REF102 10V Precision Voltage Reference 200 75,000 15000000
    REF02 5 Precision Voltage Reference 100 40,000 4000000
    POWER
    DCP021212DP Miniature, 2W Isolated Unregulated DC/DC Converters 12Vin-12Vout 8 110,000 880000
    PT5024a (-)12Vout 0.5A (+)5V-Input Positive To Negative ISR 1 160,000 160000
    DCP020505P Miniature, 2W Isolated Unregulated DC/DC Converters 5Vin,5Vout 6 110,000 660000 PT4503A 12V 20W 24V-Input Isolated DC-DC Converter 17 500,000 8500000
    DCV010505DP Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters 5Vin,5Vout 3 100,000 300000
    DCV012405P Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters 24Vin,5Vout 2 100,000 200000
    PT78NR212H (-)12V, 10-12W Plus to Minus Voltage ISR, 12Vin, -12Vout 7 260,000 1820000 PT6643D (-)12Vout 12V-Input 24W Adjustable Plus to Minus Voltage Converter 11 300,000 3300000
    PT4502A 20-Watt 24 V Input DC/DC Converter 5V Out 11 500,000 5500000
    PT4504 20-Watt 24 V Input DC/DC Converter 15V Out 15 500,000 7500000
    PT6654 9Vout 5A 24V-Input Adjustable ISR 1 300,000 300000
    PTB78520WAH 20-A, 18-60-V Input Auto-Track Compatible Isolated DC/DC Converter, 1.8-3.6Vout 3 1,000,000 3000000
    PT5025A (-)15Vout 0.3A (+)5V-Input Positive To Negative ISR 1 160,000 160000
    PT7751 2.5 to 5.6Vout 15Amp 24V-Input 'Big-Hammer III' Programmable ISR 2 640,000 1280000 PT78ST212V 12Vout 2Amp 24V-Input Positive Step-Down ISR 7 260,000 1820000
    PT78HT205 5Vout 2Amp Wide-Input Positive Step-Down ISR, 24vin 3 160,000 480000 PT78NR215H -15V, 10-12W Plus to Minus Voltage ISR 3 260,000 780000
    PT4583 12Vout 30W 18V to 60V Input Isolated DC-DC Converter 13 600,000 7800000 DCP021205P Miniature, 2W Isolated Unregulated DC/DC Converters 12Vin-5Vout 1 110,000 110000
    PT6886A 12Vout 4A 18-36V Input Adjustable ISR, CU Case 4 300,000 1200000
    PT4584 15Vout 30W 18V to 60V Input Isolated DC-DC Converter 12 600,000 7200000 DCP010512DBP Miniature, 1W Isolated Unregulated DC/DC Converters 5Vin-12Vout 1 100,000 100000
    PT4313C (+/-)12V 6W 48V-Input Isolated DC/DC Converter 4 300,000 1200000
    DCP022405 Miniature, 2W Isolated Unregulated DC/DC Converters 24Vin-5Vout 8 110,000 880000 PT78NR115H (-)15Vout 0.3Amp Wide-Input Plus to Minus Voltage ISR 3 150,000 450000 DCP010515DBP Miniature, 1W Isolated Unregulated DC/DC Converters 5Vin-15Vout 2 100,000 200000
    PT4313A (+/-)12V 6W 48V-Input Isolated DC/DC Converter 4 300,000 1200000
    DCP020515 Miniature, 2W Isolated Unregulated DC/DC Converters 5Vin-15Vout 2 110,000 220000
    DCP010505DP Miniature, 1W Isolated Unregulated DC/DC Converters 5Vin-5Vout 3 100,000 300000
    PT6885 15Vout 4A 18-36V Input Adjustable ISR, CU Case 2 300,000 600000
    PT4582 5Vout 30W 18V to 60V Input Isolated DC-DC Converter 8 600,000 4800000
    PT5111 10Vout 1A Wide Input Positive Step-Down ISR 1 100,000 100000
    DCR022405 Miniature, 2W Isolated Regulated DC/DC Converters 24Vin,5Vout 1 120,000 120000 PT4144C 15V, 1.3A 20W Isolated DC-DC Converter 2 500,000 1000000
    PT6645 -15V, 1.5A 24W Positive to Negative Voltage Converter 4 300,000 1200000
    PT6655 15Vout 5 Amp 24V Input Integrated Switching Regulato 1 300,000 300000
    PT5101 5Vout 1A Wide Input Positive Step-Down ISR 2 120,000 240000
    PTN78020HAH 6 A, Wide Input Non-Isolated, Wide Output Adjust Module 2 250,000 500000 PT48510CAH 3.3/2.5V/1.5V 25-A, 48-V Input Triple-Output DC/DC Converter 8 1,300,000 10400000
    DCP021515 Miniature, 2W Isolated Unregulated DC/DC Converters 15Vin-15Vout 1 110,000 110000
    PT5102 12Vout 1A Wide Input Positive Step-Down ISR 1 120,000 120000
    PT4311 (+/-)5V 6W 48V-Input Isolated DC/DC Converter 2 300,000 600000
    DCV011515DP Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters 2 100,000 200000
    PT78ST115 15Vout 1.5Amp Wide-Input Positive Step-Down ISR 1 150,000 150000
    PT5042 15Vout 0.75A 5V-Input Step-Up ISR 1 160,000 160000
    PT4244 12V 10W 24V-Input Isolated DC/DC Converter 3 420,000 1260000
    PT6304 12Vout 3A Wide Input Adjustable Step-Down ISR 3 200,000 600000
    UCC283T-5 Low Power 3 Ampere Low Dropout (LDO) Regulator 5 50,000 250000
    PT78ST112 12Vout 1.5Amp Wide-Input Positive Step-Down ISR 1 150,000 150000
    PT78NR112 (-)12Vout 0.4Amp Wide-Input Plus to Minus Voltage ISR 1 150,000 150000
    DCP011515 Miniature, 1W Isolated Unregulated DC/DC Converters 15Vin-15Vout 3 100,000 300000
    PT4314 (+/-)24V 6W, 48V-Input Isolated DC/DC Converter 1 300,000 300000
    DCP022415 Miniature, 2W Isolated Unregulated DC/DC Converters 24Vin-15Vout 1 110,000 110000
    MAX6955 2-Wire Interfaced, 2.7V to 5.5V LED Display Driver with I/O Expander and Key Scan 2 150,000 300000
    MAX186 Low-Power, 8-Channel, Serial 12-Bit ADCs 23 150,000 3450000
    MAX1457 0.1% Accurate Signal Conditioner for Piezoresistive Sensor Compensation 4 130,000 520000
    MAX1464 Low-Power, Low-Noise Multichannel Sensor Signal Processor 2 80,000 160000
    SI7661 12 30,000 360000
    DS1646-120 Nonvolatile Timekeeping RAM 2 350,000 700000
    MAX187 +5V, Low-Power, 12-Bit Serial ADCs 22 120,000 2640000
    DS4303K Electronically Programmable Voltage Reference 2 8,000 16000
    DS2016-100 2k x 8 3V/5V Operation Static RAM 2 150,000 300000
    ICM7218CIPI 8-Digit, Multiplexed, LED Decoder Driver 2 100,000 200000
    ICM7217AIPI 4-Digit, Presettable, LED Up/Down Counter 2 80,000 160000
    DS1620 Digital Thermometer and Thermostat 2 60,000 120000
    MX7535JN Microprocessor-Compatible, 14-Bit DACs 4 250,000 1000000
    MAX420 ±15V Chopper Stabilized Operational Amplifier 16 80,000 1280000
    MAX399 Precision, 8-Channel/Dual 4-Channel, Low-Voltage, CMOS Analog Multiplexers 8 40,000 320000
    MAX191 Low-Power, 12-Bit Sampling ADC with Internal Reference and Power-Down 9 160,000 1440000
    MAX7301 4-Wire-Interfaced, 2.5V to 5.5V, 20-Port and 28-Port I/O Expander 23 50,000 1150000 MAX544 +5V, Serial Input, Voltage-Output 14-Bit DACs 12 130,000 1560000
    MAX432 ±15V Chopper Stabilized Operational Amplifier 2 100,000 200000
    MAX133 9V, 3 3/4 Digit DMM Circuit 6 160,000 960000
    ICM7225 4 1/2 Digit, LCD, High-Speed Counter Decoder Driver 2 80,000 160000
    MAX195 16-Bit, 85ksps ADC with 10µA Shutdown 14 400,000 5600000
    MAX110 Low-Cost, 2-Channel, ±14-Bit Serial ADCs 8 100,000 800000
    MAX233 +5V-Powered, Multichannel RS-232 Drivers/Receivers 2 80,000 160000
    MAX132 ±18-Bit ADC with Serial Interface 24 160,000 3840000
    MAX872 10µA, Low-Dropout, Precision Voltage Reference 12 50,000 600000
    MAX3468 +5V, Fail-Safe, 40Mbps, Profibus RS-485/RS-422 Transceivers 2 50,000 100000
    MAX250 5V, Isolated, RS-232 Driver Receiver 2 60,000 120000
    MAX526 Calibrated, Quad, Voltage-Output, 12-Bit DAC 4 320,000 1280000
    MAX3100 SPI Microwire-Compatible UART in QSOP-16 4 50,000 200000
    MAX6959 2-Wire Interfaced, 3V to 5.5V, 4-Digit, 9-Segment LED Display Drivers with Keyscan 2 70,000 140000
    MAX6958 2-Wire Interfaced, 3V to 5.5V, 4-Digit, 9-Segment LED Display Drivers with Keyscan 2 90,000 180000
    MAX1044 Switched-Capacitor Voltage Converters 2 20,000 40000
    DS89C430 Ultra-High-Speed Flash Microcontrollers 2 160,000 320000
    MAX196 6-Channel, Multi-Range, 5V, 12-Bit DAS with 12-Bit Bus Interface and Fault Protection 2 160,000 320000
    MAX198 6-Channel, Multi-Range, 5V, 12-Bit DAS with 12-Bit Bus Interface and Fault Protection 2 160,000 320000
    MX574 Industry-Standard, 12-Bit ADC with Reference 2 180,000 360000
    MX674 Industry-Standard, 12-Bit ADC with Reference 2 360,000 720000
    MAX674 +10V Precision Voltage Reference 6 50,000 300000
    MAX6350 1ppm/°C, Low-Noise, +2.5V/+4.096V/+5V Voltage References 4 110,000 440000 MAX666 Dual Mode™ 5V Programmable Micropower Voltage Regulators 2 30,000 60000
    DS89C450 Ultra-High-Speed Flash Microcontrollers 4 180,000 720000
    MAX421 ±15V Chopper Stabilized Op Amps 3 80,000 240000
    MAX542 +5V, Serial-Input, Voltage-Output 16-Bit DACs 2 160,000 320000
    MAX121 308ksps ADC with DSP Interface and 78dB SINAD 2 200,000 400000
    MAX120 500ksps, Sampling, 12-Bit ADC with Track/Hold and Reference 2 250,000 500000
    MAX135 ±15-Bit, Low-Power ADC with Parallel Interface 2 140,000 280000
    MAX6954 4-Wire Interfaced, 2.7V to 5.5V LED Display Driver with I/O Expander and Key Scan 2 150,000 300000
    MAX485 Low-Power, Slew-Rate-Limited RS-485/RS-422 Transceivers 2 20,000 40000
    MAX5168 32-Channel Sample/Hold Amplifier with a Single Multiplexed Input 2 320,000 640000 ICM7218BI 8-Digit, Multiplexed, LED Decoder Driver 2 100,000 200000
    MAX1480A Complete, Isolated RS-485/RS-422 Data Interface 2 200,000 400000
    MAX222 +5V-Powered, Multichannel RS-232 Drivers/Receivers 2 50,000 100000
    MAX3480 Complete, Isolated, 3.3V RS-485/RS-422 Data Interface 2 250,000 500000 DS1647P-120 Nonvolatile Timekeeping RAM 1 800,000 800000
    MAX5165 32-Channel Sample/Hold Amplifier with a Single Multiplexed Input 2 300,000 600000 DS80C320 High-Speed/Low-Power Microcontrollers 1 150,000 150000
    MAX13504 2 100,000 200000
    492915000
    Úi trùi ui bác post thế thì anh em đọc sao được
    Em nhìn cứ là hoa cả mắt .
    Chóng mặt quá!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      kiểu này thỉ chọn được linh kiện chắc thành "thiên lý nhãn" quá!
      Cũ người mới ta!
        Nguyên văn bởi phanbobo Xem bài viết
        Toi moi sua lai roi (do copy tu excel sang) moi cac ban xem lai.
          Cập nhật thêm một số loại của INTERSIL gồm số lượng có sẵn
          CDP68HC68C1E CMOS Serial Real-Time Clock With RAM and Power Sense/Control 5 50,000
          HI7191BZ 24-Bit, High Precision, Sigma Delta A/D Converter 20 250,000
          ICM7218BIJB 8-Digit LED Microprocessor-Compatible Multiplexed Display Decoder Driver 8 100,000
          HI3-574JN-5 Complete, 12-Bit A/D Converters with Microprocessor Interface 20 260,000
          HI1-574AJD Complete, 12-Bit A/D Converters with Microprocessor Interface 20 260,000
          HI5731BIBZ 12-Bit, 100 MSPS, High Speed D/A Converter 10 260,000
          HI5812JIPZ CMOS 20 Microsecond, 12-Bit, Sampling A/D Converter with Internal Track and Hold 10 120,000
          HA1-5320-2 Microsecond Precision Sample and Hold Amplifier Amplifier 5 200,000
          HI5731BIP 12-Bit, 100 MSPS, High Speed D/A Converter 15 260,000
          ICM7243BIPL 8-Character, Microprocessor-Compatible, LED Display Decoder Driver 20 160,000
          HA1-5104-2 Dual and Quad, 8MHz and 60MHz, Low Noise Operational Amplifiers 5 260,000
          CP82C52 CMOS Serial Controller Interface 15 200,000
          CP82C54 CMOS Programmable Interval Timer 15 150,000
          CA3338E CMOS Video Speed, 8-Bit, 50 MSPS, R2R D/A Converters 5 120,000
          HI3-0549-5 Single 16 and 8, Differential 8-Channel and 4-Channel CMOS Analog MUXs with Active Overvoltage Protection 5 160,000
            chao anh LONGIMI
            ANH CO CON IR2130, IR2101, TC4469 K?
            EM DANG CAN GAP
              Bác nên xắp xếp theo họ chip cho dễ nhìn !!! và ko nên post dài !! nên có file pdf đi kèm như kiểu tờ rơi ý !!
              I will never fall in love again !!
                Bác có con EL2045 không? tui đang cần
                Website:
                Handphone:
                  Switching Power:
                  SKS-100-5 giá 250K / chiếc - 220K (số lượng >=10)
                  Mua nhanh kẻo nguội
                    Nguyên văn bởi hicuong Xem bài viết
                    chao anh LONGIMI
                    EM DANG CAN GAP
                    to vietsonxp "Bác có con EL2045 không? tui đang cần"
                    Những con này tôi không có sẵn nếu cần bạn đặt mua
                      Nguyên văn bởi hackervnbk Xem bài viết
                      Bây giờ các bạn có thể download file đính kèm mới cập nhật tháng 11/2006. Có rất nhiều linh kiện mới và "độc" dành cho các bạn.
                        Em cần tìm MM5451 hoặc MM5450 (40 pin): Điều khiển 2 LED 16CH (=34 out). Bác có không hay con nào đó tương tương cũng được mà.
                        Cám ơn bác.
                        Bác cho địa chỉ cửa hàng đi.
                          Nguyên văn bởi hoang Van Th Xem bài viết
                          Cám ơn bác.
                          Mình ở 53/259 Vọng. Bạn thử xem con TLC5490nt xem có thay được ko.
                            Nguyên văn bởi longimi Xem bài viết
                            con này có phải bác chạy cho mô tơ bước hả bác
                            mình có vài con hà.
                              HI.
                              không biết bác longimi có con MC14011BCP và S9013 không nhỉ.
                              Có con gì có thể thay thế hai con trên mà ở VN mình có không???
                              Mong hồi âm sớm.
                              Thanks
                              longimi Tìm hiểu thêm về longimi
                                hôm nay, 07:44
