xin hoi co bac nao biet cho nao ban con ads831 khong?gia bao nhieu?
can ic ADS831
Nguyên văn bởi maivu03 Xem bài viết136k/con hoi dat nhi
Manufacturer: TEXAS INSTRUMENTS
* IC, SM ADC 8-BIT
* Bits, No. of:8
* Channels, No. of:1
* Time, conversion:100µs
* Linearity error, ADC/DAC -:2LSB
* Linearity error, ADC/DAC +:2LSB
* Linearity error:2%
* Temp, op. max:85°C
* Temp, op. min:-40°C
* Pins, No. of:20
* Case style:SOIC
* A/D, D/A features:CMOS, Internal Reference, Parallel O/P, Track and Hold
* Base number:831
* Frequency, conversion:80MHz
* IC Generic number:831
* Interface type:Parallel
* Logic function number:831
* SMD:1
bac lấy đúng hàng của TI thi là 155k/1chu
Hôm qua, 14:37 -
bởi khoine9899
Em chào các anh và mọi người.
Hôm qua, 11:22 -
27-11-2024, 20:26 -
27-11-2024, 11:37 -
27-11-2024, 11:28 -
26-11-2024, 21:21 -
26-11-2024, 20:31 -
26-11-2024, 15:06 -
Sai cả li. Báo...-
26-11-2024, 00:35 -
25-11-2024, 22:31 -
