Instrumentation Amplifier, DC-DC converter, Logic,Interface,...
  • Instrumentation Amplifier, DC-DC converter, Logic,Interface,...
    INA101 7.90 Very High Accuracy Instrumentation Amplifier
    INA103 5.00 Low Noise, Low Distortion Instrumentation Amplifier
    INA110 7.00 Fast-Settling FET-Input Very High Accuracy Instrumentation Amplifier
    INA114 4.20 Precision Instrumentation Amplifier
    INA118 4.15 Precision, Low Power Instrumentation Amplifier
    INA125 2.05 Instrumentation Amplifier with Precision Voltage Reference
    INA128 3.05 Precision, Low Power Instrumentation Amplifiers
    INA129 3.05 Precision, Low Power Instrumentation Amplifiers
    INA131 3.80 Precision G = 100 Instrumentation Amplifier
    PGA202 7.75 Digitally Controlled Programmable-Gain Instrumentation Amp
    PGA203 7.75 Digitally Controlled Programmable-Gain Instrumentation Amp
    PGA204 7.25 Programmable Gain Instrumentation Amplifier
    PGA205 7.25 Programmable Gain Instrumentation Amplifier
    PGA206 10.80 High-Speed Programmable Gain Instrumentation Amplifier
    PGA207 11.85 High-Speed Programmable Gain Instrumentation Amplifier
    4-20mA Tranmitter
    RCV420 3.55 Precision 4mA to 20mA Current Loop Receiver
    XTR101 8.70 Precision, Low Drift 4-20mA Two-Wire Transmitter
    XTR105 4.00 4-20mA Current Transmitter with Sensor Excitation and Linearization
    XTR106 4.00 4-20mA Current Transmitter with Bridge Excitation And Linearization
    XTR110 7.10 Precision Voltage-To-Current Converter/Transmitter
    Active Filters
    UAF42 7.55 Universal Active Filter
    Isolation Analog Amplifiers
    ISO122 9.40 Precision Lowest Cost Isolation Amplifier
    ISO124 7.20 Precision Lowest Cost Isolation Amplifier
    ISO150 8.10 Dual, Isolated, Bi-Directional Digital Coupler
    Sensor Conditioning
    PGA309 2.95 PGA309 Voltage Output Programmable Sensor Conditioner
    XTR108 3.35 4-20mA, Two-Wire Transmitter 'Smart' Programmable with Signal Conditioning
    Series Voltage References
    REF02 4.00 +5V Precision Voltage Reference
    REF102 4.50 Precision Voltage Reference
    Current References
    REF200 2.60 Dual Current Source/Current Sink
    AD converter 12bit
    ADS1286 4.5 12-Bit Micro Power Sampling Analog-To-Digital Converter
    ADS574 40kSPS 16.05 Microprocessor-Compatible Sampling CMOS A/D Converter
    ADS774 250kSPS 20.05 Microprocessor-Compatible Sampling CMOS A/D Converter
    ADS7800 333kSPS 30.05 12-Bit 3us Sampling Analog-to-Digital Converter
    ADS7804 100kSPS 14.05 12-Bit 10us Sampling CMOS Analog-to-Digital Converter
    ADS7806 40kSPS 12.75 Low-Power 12-Bit Sampling CMOS Analog-to-Digital Converter
    ADS7812 40kSPS 11.80 Low-Power, Serial 12-Bit Sampling Analog-To-Digital Converter
    ADS7816 200kSPS 4.00 12-Bit High Speed Micro Power Sampling Analog-To-Digital Converter
    ADS7818 500kSPS 4.00 12-Bit High Speed Low Power Sampling Analog-to-Digital Converter
    ADS7822 75kSPS 4.00 12-Bit High Speed 2.7V Micro Power Sampling Analog-To-Digital Converter
    ADS7824 40kSPS 13.10 4-Channel, 12-Bit Sampling CMOS A/D Converter
    ADS7841 200kSPS 4.00 12-Bit, 4-Channel Serial Output Sampling Analog-to-Digital Converter
    TLC2543 66kSPS 6.00 12-Bit 66 kSPS ADC Ser. Out, Pgrmable MSB/LSB First, Pgrmable Power Down/Output Data Length, 11 Ch.
    AD converter 16bit
    ADS7805 100kSPS 21.80 16-Bit 10us Sampling CMOS Analog-to-Digital Converter
    ADS7807 40kSPS 27.40 Low-Power 16-Bit Sampling CMOS Analog-to-Digital Converter
    ADS7809 100kSPS 21.80 16-Bit 10us Serial CMOS Sampling Analog-to-Digital Converter
    ADS7811 250kSPS 36.15 16-Bit 250kHz Sampling CMOS Analog-to-Digital Converter
    ADS7813 40kSPS 21.30 Low-Power, Serial 16-Bit Sampling Analog-To-Digital Converter
    ADS7815 250kSPS 21.30 16-Bit 250kHz Sampling CMOS Analog-to-Digital Converter
    ADS7825 40kSPS 29.55 4 Channel, 16-Bit Sampling CMOS A/D Converter
    AD converter 22bit
    ADS1212 6.25kSPS 7.70 22-Bit Analog-to-Digital Converter
    ADS1213 6.25kSPS 9.00 22-Bit Analog-to-Digital Converter
    AD converter 24bit
    ADS1210 16kSPS 10.25 24-Bit Analog-to-Digital Converter
    ADS1211 16kSPS 10.90 24-Bit Analog-to-Digital Converter
    DA converter 12bit
    DAC7541 1msps 6.70 Low Cost 12-Bit CMOS Four-Quadrant Multiplying D/A Converter
    DAC7724 0.1msps 11.85 12-Bit Quad Voltage Output Digital-to-Analog Converter
    DAC7725 0.1msps 11.85 12-Bit Quad Voltage Output Digital-to-Analog Converter
    TLV5618A 0.093msps 5.00 12-Bit, 2.5 us Dual DAC, Serial Input, Pgrmable Settling Time, Q temp available
    DA converter 16bit
    DAC712 0.1msps 14.50 16-Bit Digital-to-Converter With 16-Bit Bus Interface
    DAC714 0.086msps 14.50 16-Bit Digital-to-Analog Converter with Serial Data Interface
    DAC715 0.1msps 15.85 16-Bit Digital-to-Analog Converter with 16-Bit Bus Interface
    DAC716 0.086 15.85 16-Bit Digital-to-Analog Converter with Serial Data Interface
    UART
    TL16C550C 40PDIP 1.75 Single UART with 16-Byte FIFOs & Auto Flow Control
    TL16C552 68PLCC 3.90 Dual UART with 16-Byte FIFOs & Parallel Port
    TL16C552A 68PLCC 3.85 Dual UART with 16-Byte FIFOs & Parallel Port
    TL16C554 68PLCC 6.05 Quad UART with 16-Byte FIFOs
    TL16C554A 68PLCC 6.00 Quad UART with 16-Byte FIFOs
    TL16C750 44PLCC 3.70 Single UART with 64-Byte Fifos, Auto Flow Control, Low-Power Modes
    TL16C754B 68PLCC 7.50 Quad UART with 64-Byte FIFO
    RS232
    Max232(xin) 1.0
    Rs485
    75176(xin) dong 1.5mA 2.0
    Voltage-to-Frequency and Frequency-to-Voltage Converter
    VFC110 14PDIP 12.65 High Frequency Voltage-to-Frequency Converter
    VFC32 14PDIP 4.80 Voltage-to-Frequency and Frequency-to-Voltage Converter
    VFC320 14PDIP 13.20 Voltage-to-Frequency and Frequency-to-Voltage Converter
    Isolated DC/DC Converters 5v out
    DCP010505B 5.35 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP010505DB 5.90 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP012405B 5.35 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP020505 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP021205 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP022405 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP022405D 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCR010505 5.95 Miniature, 1W Isolated Regulated DC/DC Converters
    DCR011205 5.95 Miniature, 1W Isolated Regulated DC/DC Converters
    DCR012405 5.95 Miniature, 1W Isolated Regulated DC/DC Converters
    DCR021205 7.30 Miniature, 2W Isolated Regulated DC/DC Converters
    DCR022405 7.30 Miniature, 2W Isolated Regulated DC/DC Converters
    DCV010505 8.50 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV010505D 9.05 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV012405 8.50 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    Isolated DC/DC Converters 12v out
    DCP010512B 5.35 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP010512DB 5.90 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP011512DB 5.90 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP021212 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP021212D 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP022412D 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCV010512 8.50 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV010512D 9.05 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV011512D 9.05 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCP010515B 5.35 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP010515DB 5.35 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP011515DB 5.90 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP012415DB 5.90 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP020515D 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP021215D 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP021515 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP022415D 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCV010515 8.50 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV010515D 9.05 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV011515D 9.05 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV012415D 9.05 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    Isolated DC/DC Converters 24V in 5v out
    PT4502 32.45 20-Watt 24 V Input DC/DC Converter
    PT4582 38.55 5Vout 30W 18V to 60V Input Isolated DC-DC Converter
    PTB78560A 25.00 30-W, 24-V/48-V Input DC/DC Converter With Auto-Track Sequencing
    Isolated DC/DC Converters 24V in 12v out
    PT4503 32.45 12V 20W 24V-Input Isolated DC-DC Converter
    PT4583 38.55 12Vout 30W 18V to 60V Input Isolated DC-DC Converter
    PTB78560C 25.00 30-W, 24-V/48-V Input DC/DC Converter With Auto-Track Sequencing
    Isolated DC/DC Converters 24V in 15v out
    PT4504 32.45 15V 20W 24V-Input Isolated DC-DC Converter
    PT4584 38.55 15Vout 30W 18V to 60V Input Isolated DC-DC Converter
    Isolated DC/DC Converters +-12V out
    PT4313 18.75 (+/-)12V 6W 48V-Input Isolated DC/DC Converter
    PTB48510B 38.00 72-W +/- 12-V, Dual Complementary-Output DC/DC Converter for DSL
    PTB48511B 38.00 72-W +/- 12-V, Dual Complementary-Output DC/DC Converter with OVP
    Isolated DC/DC Converters +-15V out
    PTB48510C 38.00 66-W +/- 15-V, Dual Complementary-Output DC/DC Converter for DSL
    Bác có con DC/DC Converters +-5V out không?
      DC/DC +- 5V out. DC input = ?.
      Bạn cần bao nhiêu con?
      Biến tần
      Máy giặt
      Lò vi sóng
      Bếp từ.
      Tủ lạnh.
      Điều hòa
        Miễn phí giao hàng trong toàn quốc qua chuyển phát. Tại HN giao hàng tận nơi, TpHCM liên hệ để biết địa điểm giao hàng. Hiện tại nguồn hàng về số lượng đang giảm vì trong thời gian qua thông qua dtvn.net bán được với số lượng đáng kể ( cám ơn ban quản trị diễn đàn). Mong các bạn ủng hộ để phát triển hơn, hiện tôi đang có kế hoạch sang TQ lấy hàng (hiện tôi hàng tháng đều có người sang đó) với cách này thì chi phí vận chuyển về VN gần như không đáng kể vì đó là hàng gửi xách tay. Các bạn hoàn toàn yên tâm về nguồn hàng lúc nào cũng có nhưng giá có thể có chênh lệch (không đáng kể) vì hiện tại nguồn hàng tại VN đang hầu hết là SAMPLE lên có thể giá rẻ hơn so với nhập.
          Có vài người mua OPAM của tôi thường chọn loại single supply vì ngại tạo nguồn đối xứng. Thực ra vấn đề để tạo nguồn đối xứng vô cùng đơn giản, dùng ICL7660 để lật nguồn sẽ có ngay nguồn - sử dụng cho OP. Hiện ICL7660 có bán trên thị trường với giá 18.000. ICL7660 là giải pháp tạo nguồn âm cho OP dual supply.
            Bay lên nào.
            Update 2.8
              Max186 Low-Power, 8-Channel, Serial 12-Bit ADCs $8.95
              Max187 +5V, Low-Power, 12-Bit Serial ADCs $7.45
              Max110 Low-Cost, 2-Channel, ±14-Bit Serial ADCs $4.80
              Max132 ±18-Bit ADC with Serial Interface $8.00
              Max195 16-Bit, 85ksps ADC with 10µA Shutdown $24.00
              Max 544 +5V, Serial Input, Voltage-Output 14-Bit DACs $7.90
              Max545 +5V, Serial Input, Voltage-Output 14-Bit DACs $7.90
              Max7301
              4-Wire-Interfaced, 2.5V to 5.5V, 20-Port and 28-Port I/O Expander $2.55
              MAX196 6-Channel, Multi-Range, 5V, 12-Bit DAS with 12-Bit Bus Interface and Fault Protection $9.90
              MAX198 6-Channel, Multi-Range, 5V, 12-Bit DAS with 12-Bit Bus Interface and Fault Protection $9.90
              MX574 Industry-Standard, 12-Bit ADC with Reference $11.97
              MX674 Industry-Standard, 12-Bit ADC with Reference $23.44
              MAX135 ±15-Bit, Low-Power ADC with Parallel Interface $8.00
              MAX6954 4-Wire Interfaced, 2.7V to 5.5V LED Display Driver with I/O Expander and Key Scan $8.69
              MX7535 Microprocessor-Compatible, 14-Bit DACs Plug-in replacements for AD7534/AD7535 $15.00
              MAX121 308ksps ADC 14bit with DSP Interface and 78dB SINAD $12.00
              MAX542 +5V, Serial-Input, Voltage-Output 16-Bit DACs $9.95
              MAX191 Low-Power, 12-Bit Sampling ADC with Internal Reference and Power-Down $9.60
              MAX120 500ksps, Sampling, 12-Bit ADC with Track/Hold and Reference $16.00
              MAX390
              ICM7225 4 1/2 Digit, LCD, High-Speed Counter Decoder Driver $4.86
              MAX133 9V, 3 3/4 Digit DMM Circuit $9.75
              MAX421 ±15V Chopper Stabilized Op Amps $4.21
              MAX420 ±15V Chopper Stabilized Op Amps $3.77
              MAX544 +5V, Serial Input, Voltage-Output 14-Bit DACs $7.90
              MAX872 10µA, Low-Dropout, Precision Voltage Reference 2.500V ±0.2% $2.12
              MAX399
              Precision, 8-Channel/Dual 4-Channel, Low-Voltage, CMOS Analog Multiplexers $1.83
              MAX1044 Switched-Capacitor Voltage Converters 20mA Charge Pump with Industry Standard Pinout $1.19
              MAX6959 2-Wire Interfaced, 3V to 5.5V, 4-Digit, 9-Segment LED Display Drivers with Keyscan $4.40
              MAX6958 -Wire Interfaced, 3V to 5.5V, 4-Digit, 9-Segment LED Display Drivers with Keyscan $4.40
              MAX526 Calibrated, Quad, Voltage-Output, 12-Bit DAC $19.44
              MAX3100 SPI Microwire-Compatible UART $2.79
              MAX6350 1ppm/°C, Low-Noise, +5V Voltage References $6.70
              MAX660 CMOS Monolithic Voltage Converter +5VDC -> -5VDC 0.1A $2.95
              longimi Tìm hiểu thêm về longimi
              • mansion123
                bởi mansion123
                hôm nay, 16:08
                hôm nay, 07:44
