sau cuoc gap Tam nhin dien tu
. Cac hang da hop mat va qd giam gia mot so chu IC sau.
Lien he: tindientu@gmail.com
hoac nick Yahoo Messenger: dientubk
Microchip
Loai Gia/dvi
PIC18F4510-I/PT 4.02
PIC18F4510-I/ML 4.02
PIC18LF4510-I/PT 4.02
PIC18LF4510-I/P 4.02
PIC16LF870-I/SP 2.23
PIC16F870-I/SP 2.23
RFPIC12F675K-ISS 1.83
PIC18F6585-I/PT 6.25
PIC18F248-I/ML 4.30
PIC18LF6722-I/PT 7.07
PIC18F8722-I/PT 7.41
PIC16F877A-I/P 3.71
TC850CPL 13.19 CMOS analog to digital converter with resolution of 15 bits plus sign
TC534CPL 8.18 Serial analog data acquisition subsystems ideal for high precision measurements up to 17 bits plus sign
TC9401CPD 6.47 Chuyen doi dien ap - tan so
TC7129CPL 7.02 4 1/2 Digit Analog to Digital Coverters with On Chip LCD Drivers
PIC18F4550-I/P 5.05 ho tro USB
PIC18F2455-I/SP 4.10 ho tro USB
PIC18LF2455-I/SP 4.10 ho tro USB
PIC18LF4455-I/P 4.54 ho tro USB
PIC18F2585-I/SP 5.11
PIC18LF4525-I/P 5.01
PIC18F4580-I/P 5.18
DSPIC30F4011-20I/P 5.25
DSPIC30F4011-30I/P 5.25
DSPIC30F6011A-30I/PF 7.73
DSPIC30F6014A-30I/PF 8.31
DSPIC30F3014A-30I/PF 4.89
DSPIC30F6014A-30I/PT
Dallas MAXIM
Loai Gia
ICM7217AIPI+ 18.9 4 digit timer/counter DIP 28
MAX13481EETE 0.8 "16/TQNF, 15 kV ESD Protected USB transceivers"
MAX335CNG 9 "DIL24, Serial Controlled 8 channel SPST analog switch"
ICM7217BIPI+ 4.67 "PDIP, 4 digit, presettable, LED Up/down counter"
MAX335ENG 2.84 "PDIP, Serial Controlled 8 Channel SPST Switch"
MAX562EAI 8.4 "SSOP, Complete 230 kbps, 2.7 to 5.25 V Serial Interface for Notebook "
MAX280CPA 3.99 "PDIP, 5 order, zero error, butterworth, switched capacitor lowpass filter"
MAX295CPA 2.85 "PDIP, 8 th order, lowpass, switched capacitor filters"
Texas Instrument
Loai Gia/dvi
INA114AP 4.19 Khuyech dai thiet bi
XTR110KU 7.1 Ap dong 4-20 mA
LM139DR 0.57 "4 Channel, Quad, General Purpose Diff Comparator"
MPC506AU 5.7 16 Channel Single Ended Input Analog Multiplexer
ISO721MD 1.65 3.3 V/5 V High- Speed Digital Isolator
BQ3285EP 2.09 Real time Clock (RTC) with 114x8 NVSRAM
UAF42AP 7.55 "Universal Active Filter, PDIP"
"ISO122JU,JP" 9.39 Precision Lowest Cost Isolation Amplifier
MPY634KU 13.15 Wide Bandwidth Precision analog multiplier
TLC339ID 0.48 "Quad, Micropower, LinCMOS Comparator"
INA114BP 5.7 Khuyech dai thiet bi
CD4541BM 0.24 CMOS Programmable timer
SN74AHC08DRE4 0.15 Quadruple 2 Input Positive NOR Gates
ISO122P 11.7 Precision Lowest Cost Isolation Amplifier
TS5A63157DBVRE4 0.25 15 Ohm SPDT Analog Swith 5 V/3.3 V Single Channel 2:1 Multiplexer/Demultiplexer
MPC506AP 5.7 16 Channel Single Ended Input Analog Multiplexer
DAC5675AIPHP 25 14 bit 400 MSPS Digital to Analog Converter
DAC1221E 5.25 16 bit Low power Digital to Analog Converter
ADS5500IPAP 49 14 bit 125 MSPS Analog to Digital Converter
XTR110KP 7.1 Ap dong 4-20 mA
XTR101AP 8.7 Ap dong 4-20 mA
ISO124P 7.2 Precision Lowest Cost Isolation Amplifier
MPY634KP 11.75 Wide Bandwidth Precision analog multiplier
INA101HP 7.9 Khuyech dai thiet bi
TLV0838INE4 1.55 "8 bit 37.8 kSPS ADC Serital, 8 Channel"
TMP175AIDR 0.85 Digital Temperature Sensor with 2 Wire Interface
UC2610N 2.8 Dual Schottky Diode Bridge
XTR114U 5.6 4-20 mA Current Transmitters with Sensor Excitation and Linearization
INA105KP 2.8 Precision Unity Gain Diff Amplifier
INA114BU 5.7 Khuyech dai thiet bi
ADS1100A4IDBVT 1.8 Self Calibrating 16 bit Analog to Digital Converter
DDC112U 12.1 Dual Current Input 20 bit Analog To Digital Converter
OPA3355UA 1.9 CMOS Operational Amplifier with Shutdown
OPA380AIDGKT 2.95 "Precision, High Speed Transimpedance Amplifier"
ADS5522IPAP 16.7 "12 bit, 80 MSPS Analog to Digital Converter"
ADS7811U 36.15 16 bit 250 kHz Sampling CMOS Analog to Digital
ADS8411IBPFBT 31.7 "16 bit, 2 MSPS ADC with P8/P16 Parallel Output, Internal Clock & Internal Reference"
TMS320LF2406APZA 8.35
TMS320LF2407APGEA 8.85
TMS320LF2407APGES 9.75
Analog Device
Loai Gia/dvi
AD7400YRWZ 4 "16 Id SOIC, Isolated Sigma Delta Modulator"
AD676AD 10.33 "16 bit, DIP 28"
AD620AN 3.14 Instrument Amplifier (khuyech dai thiet bi)
AD620BN 3.14 Instrument Amplifier (khuyech dai thiet bi)
AD676KN 4.88 12 bit ADC
AD621BN 5.74 Instrument Amplifier (khuyech dai thiet bi)
AD621AN 3.82 Instrument Amplifier (khuyech dai thiet bi)
AD621ANZ 3.82 Instrument Amplifier (khuyech dai thiet bi)
AD7328 (TSSOP) 6.25 "8 channel, 12 bit"
AD7656 (64 Id LQFP) 18 "6 channel, Simult Sampling, 16 bit ADC"
AD7612 4 16b
AD7266 7.55 "Diff Input, 12 bit, 3 channel"
AD7610 4 16b
National
Loai Gia
ADC0801LCN 6.46 8 bit MDIP
LM77CIMM-3 0.8 "SOIC, 9 bit + Sign Digital Temperature Sensor and Thermal Window Comparator with Two Wire Interface"
Intersil
Loai Gia/dvi
EL8171IS 1.6 "8 Ld SOIC, Micropower Single Supply Rail to Rail Input to Output Instrumentation Amplifier"
HI3-574AJN-5 16.24 "28 Ld PDIP, 12 bit, ADC with Microprocessor Interface"
HI5762/6IN 15.11 "Dual 10 bit, 60 MSPS ADC with Internal Voltage Reference"
CA3338AE 9.73 "16 Ld PDIP, CMOS Video Speed, 8 bit, 50 MSPS, R2R DAC"
CA3338E 7.32 "16 Ld PDIP, CMOS Video Speed, 8 bit, 50 MSPS, R2R DAC"
HI5731BIP 16.71 "28 Ld PDIP, 12 bit, 100 MSPS, High Speed DAC "
HI1-574AJD-5 13.3 "12 bit ADC with mP interface, 28 Ld SBDIP"
ICL7107CPL 1.77 "40 Ld PDIP, 3 1/2 Digit, LCD/LED Display, ADC
Microchip
Loai Gia/dvi
PIC16F870-I/SP 2.23
PIC18F248-I/ML 4.30
PIC16F877A-I/P 3.71
PIC18F4580-I/P 5.18
Dallas MAXIM
Loai Gia
Texas Instrument
Loai Gia/dvi
Analog Device
Loai Gia/dvi
AD7612 4 16b
AD7610 4 16b
National
Loai Gia
Intersil
Loai Gia/dvi
