Linh kiện tổng hợp.
  • Linh kiện tổng hợp.
    MAXIM
    Max186 Low-Power, 8-Channel, Serial 12-Bit ADCs $8.95
    Max187 +5V, Low-Power, 12-Bit Serial ADCs $7.45
    Max110 Low-Cost, 2-Channel, ±14-Bit Serial ADCs $4.80
    Max132 ±18-Bit ADC with Serial Interface $8.00
    Max195 16-Bit, 85ksps ADC with 10µA Shutdown $24.00
    Max 544 +5V, Serial Input, Voltage-Output 14-Bit DACs $7.90
    Max545 +5V, Serial Input, Voltage-Output 14-Bit DACs $7.90
    Max7301
    4-Wire-Interfaced, 2.5V to 5.5V, 20-Port and 28-Port I/O Expander $2.55
    MAX196 6-Channel, Multi-Range, 5V, 12-Bit DAS with 12-Bit Bus Interface and Fault Protection $9.90
    MAX198 6-Channel, Multi-Range, 5V, 12-Bit DAS with 12-Bit Bus Interface and Fault Protection $9.90
    MX574 Industry-Standard, 12-Bit ADC with Reference $11.97
    MX674 Industry-Standard, 12-Bit ADC with Reference $23.44
    MAX135 ±15-Bit, Low-Power ADC with Parallel Interface $8.00
    MAX6954 4-Wire Interfaced, 2.7V to 5.5V LED Display Driver with I/O Expander and Key Scan $8.69
    MX7535 Microprocessor-Compatible, 14-Bit DACs Plug-in replacements for AD7534/AD7535 $15.00
    MAX121 308ksps ADC 14bit with DSP Interface and 78dB SINAD $12.00
    MAX542 +5V, Serial-Input, Voltage-Output 16-Bit DACs $9.95
    MAX191 Low-Power, 12-Bit Sampling ADC with Internal Reference and Power-Down $9.60
    MAX120 500ksps, Sampling, 12-Bit ADC with Track/Hold and Reference $16.00
    MAX390
    ICM7225 4 1/2 Digit, LCD, High-Speed Counter Decoder Driver $4.86
    MAX133 9V, 3 3/4 Digit DMM Circuit $9.75
    MAX421 ±15V Chopper Stabilized Op Amps $4.21
    MAX420 ±15V Chopper Stabilized Op Amps $3.77
    MAX544 +5V, Serial Input, Voltage-Output 14-Bit DACs $7.90
    MAX872 10µA, Low-Dropout, Precision Voltage Reference 2.500V ±0.2% $2.12
    MAX399
    Precision, 8-Channel/Dual 4-Channel, Low-Voltage, CMOS Analog Multiplexers $1.83
    MAX1044 Switched-Capacitor Voltage Converters 20mA Charge Pump with Industry Standard Pinout $1.19
    MAX6959 2-Wire Interfaced, 3V to 5.5V, 4-Digit, 9-Segment LED Display Drivers with Keyscan $4.40
    MAX6958 -Wire Interfaced, 3V to 5.5V, 4-Digit, 9-Segment LED Display Drivers with Keyscan $4.40
    MAX526 Calibrated, Quad, Voltage-Output, 12-Bit DAC $19.44
    MAX3100 SPI Microwire-Compatible UART $2.79
    MAX6350 1ppm/°C, Low-Noise, +5V Voltage References $6.70
    MAX660 CMOS Monolithic Voltage Converter +5VDC -> -5VDC 0.1A $2.95
    TI
    Instrumentation Amplifier
    INA101 7.90 Very High Accuracy Instrumentation Amplifier
    INA103 5.00 Low Noise, Low Distortion Instrumentation Amplifier
    INA110 7.00 Fast-Settling FET-Input Very High Accuracy Instrumentation Amplifier
    INA114 4.20 Precision Instrumentation Amplifier
    INA118 4.15 Precision, Low Power Instrumentation Amplifier
    INA125 2.05 Instrumentation Amplifier with Precision Voltage Reference
    INA128 3.05 Precision, Low Power Instrumentation Amplifiers
    INA129 3.05 Precision, Low Power Instrumentation Amplifiers
    INA131 3.80 Precision G = 100 Instrumentation Amplifier
    PGA202 7.75 Digitally Controlled Programmable-Gain Instrumentation Amp
    PGA203 7.75 Digitally Controlled Programmable-Gain Instrumentation Amp
    PGA204 7.25 Programmable Gain Instrumentation Amplifier
    PGA205 7.25 Programmable Gain Instrumentation Amplifier
    PGA206 10.80 High-Speed Programmable Gain Instrumentation Amplifier
    PGA207 11.85 High-Speed Programmable Gain Instrumentation Amplifier
    4-20mA Tranmitter
    RCV420 3.55 Precision 4mA to 20mA Current Loop Receiver
    XTR101 8.70 Precision, Low Drift 4-20mA Two-Wire Transmitter
    XTR105 4.00 4-20mA Current Transmitter with Sensor Excitation and Linearization
    XTR106 4.00 4-20mA Current Transmitter with Bridge Excitation And Linearization
    XTR110 7.10 Precision Voltage-To-Current Converter/Transmitter
    Active Filters
    UAF42 7.55 Universal Active Filter
    Isolation Analog Amplifiers
    ISO122 9.40 Precision Lowest Cost Isolation Amplifier
    ISO124 7.20 Precision Lowest Cost Isolation Amplifier
    ISO150 8.10 Dual, Isolated, Bi-Directional Digital Coupler
    Sensor Conditioning
    PGA309 2.95 PGA309 Voltage Output Programmable Sensor Conditioner
    XTR108 3.35 4-20mA, Two-Wire Transmitter 'Smart' Programmable with Signal Conditioning
    Series Voltage References
    REF02 4.00 +5V Precision Voltage Reference
    REF102 4.50 Precision Voltage Reference
    Current References
    REF200 2.60 Dual Current Source/Current Sink
    AD converter 12bit
    ADS1286 4.5 12-Bit Micro Power Sampling Analog-To-Digital Converter
    ADS574 40kSPS 16.05 Microprocessor-Compatible Sampling CMOS A/D Converter
    ADS774 250kSPS 20.05 Microprocessor-Compatible Sampling CMOS A/D Converter
    ADS7800 333kSPS 30.05 12-Bit 3us Sampling Analog-to-Digital Converter
    ADS7804 100kSPS 14.05 12-Bit 10us Sampling CMOS Analog-to-Digital Converter
    ADS7806 40kSPS 12.75 Low-Power 12-Bit Sampling CMOS Analog-to-Digital Converter
    ADS7812 40kSPS 11.80 Low-Power, Serial 12-Bit Sampling Analog-To-Digital Converter
    ADS7816 200kSPS 4.00 12-Bit High Speed Micro Power Sampling Analog-To-Digital Converter
    ADS7818 500kSPS 4.00 12-Bit High Speed Low Power Sampling Analog-to-Digital Converter
    ADS7822 75kSPS 4.00 12-Bit High Speed 2.7V Micro Power Sampling Analog-To-Digital Converter
    ADS7824 40kSPS 13.10 4-Channel, 12-Bit Sampling CMOS A/D Converter
    ADS7841 200kSPS 4.00 12-Bit, 4-Channel Serial Output Sampling Analog-to-Digital Converter
    TLC2543 66kSPS 6.00 12-Bit 66 kSPS ADC Ser. Out, Pgrmable MSB/LSB First, Pgrmable Power Down/Output Data Length, 11 Ch.
    AD converter 16bit
    ADS7805 100kSPS 21.80 16-Bit 10us Sampling CMOS Analog-to-Digital Converter
    ADS7807 40kSPS 27.40 Low-Power 16-Bit Sampling CMOS Analog-to-Digital Converter
    ADS7809 100kSPS 21.80 16-Bit 10us Serial CMOS Sampling Analog-to-Digital Converter
    ADS7811 250kSPS 36.15 16-Bit 250kHz Sampling CMOS Analog-to-Digital Converter
    ADS7813 40kSPS 21.30 Low-Power, Serial 16-Bit Sampling Analog-To-Digital Converter
    ADS7815 250kSPS 21.30 16-Bit 250kHz Sampling CMOS Analog-to-Digital Converter
    ADS7825 40kSPS 29.55 4 Channel, 16-Bit Sampling CMOS A/D Converter
    AD converter 22bit
    ADS1212 6.25kSPS 7.70 22-Bit Analog-to-Digital Converter
    ADS1213 6.25kSPS 9.00 22-Bit Analog-to-Digital Converter
    AD converter 24bit
    ADS1210 16kSPS 10.25 24-Bit Analog-to-Digital Converter
    ADS1211 16kSPS 10.90 24-Bit Analog-to-Digital Converter
    DA converter 12bit
    DAC7541 1msps 6.70 Low Cost 12-Bit CMOS Four-Quadrant Multiplying D/A Converter
    DAC7724 0.1msps 11.85 12-Bit Quad Voltage Output Digital-to-Analog Converter
    DAC7725 0.1msps 11.85 12-Bit Quad Voltage Output Digital-to-Analog Converter
    TLV5618A 0.093msps 5.00 12-Bit, 2.5 us Dual DAC, Serial Input, Pgrmable Settling Time, Q temp available
    DA converter 16bit
    DAC712 0.1msps 14.50 16-Bit Digital-to-Converter With 16-Bit Bus Interface
    DAC714 0.086msps 14.50 16-Bit Digital-to-Analog Converter with Serial Data Interface
    DAC715 0.1msps 15.85 16-Bit Digital-to-Analog Converter with 16-Bit Bus Interface
    DAC716 0.086 15.85 16-Bit Digital-to-Analog Converter with Serial Data Interface
    UART
    TL16C550C 40PDIP 1.75 Single UART with 16-Byte FIFOs & Auto Flow Control
    TL16C552 68PLCC 3.90 Dual UART with 16-Byte FIFOs & Parallel Port
    TL16C552A 68PLCC 3.85 Dual UART with 16-Byte FIFOs & Parallel Port
    TL16C554 68PLCC 6.05 Quad UART with 16-Byte FIFOs
    TL16C554A 68PLCC 6.00 Quad UART with 16-Byte FIFOs
    TL16C750 44PLCC 3.70 Single UART with 64-Byte Fifos, Auto Flow Control, Low-Power Modes
    TL16C754B 68PLCC 7.50 Quad UART with 64-Byte FIFO
    RS232
    Max232(xin) 1.0
    Rs485
    75176(xin) dong 1.5mA 2.0
    Voltage-to-Frequency and Frequency-to-Voltage Converter
    VFC110 14PDIP 12.65 High Frequency Voltage-to-Frequency Converter
    VFC32 14PDIP 4.80 Voltage-to-Frequency and Frequency-to-Voltage Converter
    VFC320 14PDIP 13.20 Voltage-to-Frequency and Frequency-to-Voltage Converter
    Isolated DC/DC Converters 5v out
    DCP010505B 5.35 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP010505DB 5.90 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP012405B 5.35 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP020505 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP021205 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP022405 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP022405D 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCR010505 5.95 Miniature, 1W Isolated Regulated DC/DC Converters
    DCR011205 5.95 Miniature, 1W Isolated Regulated DC/DC Converters
    DCR012405 5.95 Miniature, 1W Isolated Regulated DC/DC Converters
    DCR021205 7.30 Miniature, 2W Isolated Regulated DC/DC Converters
    DCR022405 7.30 Miniature, 2W Isolated Regulated DC/DC Converters
    DCV010505 8.50 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV010505D 9.05 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV012405 8.50 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    Isolated DC/DC Converters 12v out
    DCP010512B 5.35 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP010512DB 5.90 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP011512DB 5.90 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP021212 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP021212D 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP022412D 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCV010512 8.50 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV010512D 9.05 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV011512D 9.05 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCP010515B 5.35 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP010515DB 5.35 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP011515DB 5.90 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP012415DB 5.90 Miniature, 1W Isolated Unregulated DC/DC Converters
    DCP020515D 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP021215D 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP021515 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCP022415D 6.95 Miniature, 2W Isolated Unregulated DC/DC Converters
    DCV010515 8.50 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV010515D 9.05 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV011515D 9.05 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    DCV012415D 9.05 Miniature, 1W, 1500Vrms Isolated Unregulated DC/DC Converters
    Isolated DC/DC Converters 24V in 5v out
    PT4502 32.45 20-Watt 24 V Input DC/DC Converter
    PT4582 38.55 5Vout 30W 18V to 60V Input Isolated DC-DC Converter
    PTB78560A 25.00 30-W, 24-V/48-V Input DC/DC Converter With Auto-Track Sequencing
    Isolated DC/DC Converters 24V in 12v out
    PT4503 32.45 12V 20W 24V-Input Isolated DC-DC Converter
    PT4583 38.55 12Vout 30W 18V to 60V Input Isolated DC-DC Converter
    PTB78560C 25.00 30-W, 24-V/48-V Input DC/DC Converter With Auto-Track Sequencing
    Isolated DC/DC Converters 24V in 15v out
    PT4504 32.45 15V 20W 24V-Input Isolated DC-DC Converter
    PT4584 38.55 15Vout 30W 18V to 60V Input Isolated DC-DC Converter
    Isolated DC/DC Converters +-12V out
    PT4313 18.75 (+/-)12V 6W 48V-Input Isolated DC/DC Converter
    PTB48510B 38.00 72-W +/- 12-V, Dual Complementary-Output DC/DC Converter for DSL
    PTB48511B 38.00 72-W +/- 12-V, Dual Complementary-Output DC/DC Converter with OVP
    Isolated DC/DC Converters +-15V out
    PTB48510C 38.00 66-W +/- 15-V, Dual Complementary-Output DC/DC Converter for DSL
    MOTOR DRIVER
    UC2637 ACTIVE Switched Mode Controller for DC Motor Drive PDIP18 3.55
    UC3637 ACTIVE Switched Mode Controller for DC Motor Drive PDIP18 3.20
    UC3625 ACTIVE Brushless DC Motor Controller PDIP28 5.00
    UC3638 ACTIVE Advanced PWM Motor Controller PDIP20 3.30
    UC3176 ACTIVE Full Bridge Power Amplifier PLCC28 6.35
    UC3717A ACTIVE Stepper Motor Drive Circuit PDIP16 3.30
    UC3770A ACTIVE High Performance Stepper Motor Drive Circuit PDIP16 2.60
    LOGIC
    SN74HC259 ACTIVE 8-Bit Addressable Latches 0.24
    SN74ABT652 ACTIVE Octal Bus Transceivers And Registers With 3-State Outputs 1.03
    SN74LS163A ACTIVE Synchronous 4-Bit Binary Counters 0.42
    SN74HC32 ACTIVE Quadruple 2-Input Positive-OR Gates 0.23
    SN74HC540 ACTIVE Octal Buffers And Line Drivers With 3-State Outputs 0.34
    CD40147B ACTIVE 10-Line to 4-Line BCD Priority Encoder 0.84
    SN74ALS373A ACTIVE Octal D-Type Transparent Latches with 3-state Outputs 0.62
    SN74HC240 ACTIVE Octal Buffers And Line Drivers With 3-State Outputs 0.36
    SN74HC245 ACTIVE Octal Bus Transceivers With 3-State Outputs 0.36
    SN74LS04 ACTIVE Hex inverters 0.29
    CD74HC154 ACTIVE High Speed CMOS Logic 4-to-16 Line Decoder/Demultiplexer 0.66
    SN74ACT244 ACTIVE Octal Buffers/Drivers With 3-State Outputs 0.44
    CD74HCT147 ACTIVE High Speed CMOS Logic 10-to-4 Line Priority Encoder 0.33
    CD74AC138 ACTIVE 3-Line to 8-Line Inverting Decoders/Demultiplexers 0.37
    CD74HCT4351 ACTIVE High Speed CMOS 8-Channel Analog Multiplexer/Demultiplexer with Latch 0.42
    SN74HC86 ACTIVE Quadruple 2-Input Exclusive-OR Gates 0.23
    CD74AC541 ACTIVE Non-Inverting Octal Buffer/Line Drivers with 3-State Outputs 0.44
    CD4033B ACTIVE CMOS Decade Counter/Divider with Decoded 7-Segment Display Outputs and Ripple Blanking 1.21
    CD4521B ACTIVE CMOS 24-Stage Frequency Divider 0.42
    CD74HC297 ACTIVE High Speed CMOS Logic Digital Phase-Locked-Loop 1.91
    SN74ALS688 ACTIVE 8-Bit Identity Comparators 4.29
    SN74HC266 ACTIVE Quadruple 2-Input Exclusive-NOR Gates With Open-Drain Outputs 0.24
    SN74ALS109A ACTIVE Dual J-K Positive-Edge-Triggered Flip-Flops With Clear and Preset 0.51
    INTERFACE
    UC5180C ACTIVE PLCC 28 Low-Speed Asynchronous Octal Line Receiver 3.00
    SN65HVD05 ACTIVE PDIP 8 High-Output RS-485 Transceiver 1.6
    SN65LBC176 ACTIVE PDIP 8 Differential Bus Transceiver 1.0
    SN75LBC176 ACTIVE PDIP 8 Differential Bus Transceiver 1.0
    MAX232 ACTIVE PDIP,SOIC 16
    Dual EIA-232 Driver/Receiver 0.5
    TL16C754B ACTIVE PLCC 68
    Quad UART with 64-Byte FIFO 7.5
    TL16C750 ACTIVE PLCC 44
    Single UART with 64-Byte Fifos, Auto Flow Control, Low-Power 3.7
    TL16C550C ACTIVE PDIP 40
    Single UART with 16-Byte FIFOs & Auto Flow Control 1.75
    TL16C552 ACTIVE PLCC 68
    Dual UART with 16-Byte FIFOs & Parallel Port 3.90
    PCF8575 ACTIVE SOIC 24
    Remote 16-Bit I2C and SMBus I/O Expander with Interrupt 2.0
    PCF8574 ACTIVE PDIP Remote 8-Bit I/O Expander for I2C-Bus 1.2
    SN65LBC174 ACTIVE PDIP 16 Quadruple Low-Power Differential Line Driver 2.0
    SN754410 ACTIVE PDIP 16 Quadruple Half-H Drivers 1.35
    INTERSIL
    HI1-547
    ICM7218C
    HI5731
    CP82C54
    CP82C52
    CDP68HC68
    HA1-5104-2
    HI7191
    ICM7243B
    ICM7218B
    HI5812
    HI3-549-5
    HI15320
    CA3330
    Lên trên nào. Hãy liên hệ vơi tôi ngay để được giá tốt nhất
      Giá của huynh đệ quá cao cho SV, hàng sample mà, nhè nhẹ tay cho các huynh đệ khác nhờ với.
      Troi ko so dat ko so chi so minh ko biet so
        Nguyên văn bởi Kesitinh
        Gia tren chi de tham khao. Can gi lien he truc tiep voi toi de dc gia tot nhat.
          Thêm vào danh sách các loại linh kiện microcontroller.
          MSP430
          MCS12XX (8051)
          ADuC8xx (8051)
          ADuC7xx (ARM7)
          DS89Cxx (8051)
          Do trong quá trình làm thấy mấy con này hay quá giư lại dùng được một số lên số lượng hiện còn chỉ khoảng 10 con mỗi loại. Chán dùng họ 8bit giơ chuyển sang 32bit thử chơi. Nên cho các em trên đi ở cho thị trường thêm phong phú bạn nào muốn dùng thử các con trên vui lòng xin liên hê.
            Nguyên văn bởi longimi
            MSP430
            MCS12XX (8051)
            ADuC8xx (8051)
            ADuC7xx (ARM7)
            DS89Cxx (8051)
            Lâu nay vắng bóng các bác sampler làm E nhớ các bác quá, híc híc híc íc Chẳng thấy bác update cho cái freeweb của các gì cả, buồn quá. . . . . e
            Hởi bác khí không phải chứ bác đã đóng tiền quảng cáo chưa thế,
            Nếu chưa thì E bày cách cho các bác nhé,. . . . . .
              tìm mua hoặc trao đổi một số loại lk
              D = GF1M/DO214
              D = BZX84/SOT23, 9V1
              D = BZX84/SOT23, 4V7
              D = BAW56/SOT23
              T1 = BC857B
              IC = MAX810 SOT23
              IC = 78L05/SO8
              IC = 74HC14ADT/TSSOP14
              Bạn nào có cung cấp hay trao đổi số với bất kỳ loại lk nào của tôi.
                Anh em cho tui hỏi, ai đang có hoặc có thể tìm được cho tui những linh kiện này được không: MC44603 và Diode ổn áp 200v, 5w, xin hồi âm nhanh
                nhé
                  hi
                  the bac do con ic nao ho tro bien doi ac sang dc chinh xac khong vay. em dang can de lam thiet bi do dong dien ac lay sup ap tren sunh chi vai chuc milivolt den 1 volt ac
                  neu khong thi bac chi giup con gi hay mach gi cung duoc
                  cam on nhieu
                  rat mong hoi am: tuongthetien@yahoo.com
                    Có bác nào có con 5SCR1.5S15-M của SECON không, hoặc datasheet nữa thì càng tốt.
                      Nguyên văn bởi longimi Xem bài viết
                      MSP430
                      MCS12XX (8051)
                      ADuC8xx (8051)
                      ADuC7xx (ARM7)
                      DS89Cxx (8051)
                      Bác có MSP430F1232 ko? Mình muốn khoảng 10-20 con để thí nghiệm, nếu có vui lòng contact với dc bên dưới chữ kí (mình đang cần gấp).
                      Thanks.
                        bac co con 3102, ca3049 khong toi rat can
                          ca 3102 nhe
                            Nguyên văn bởi cuteolenpho Xem bài viết
                            Thanks.
                            Mình ko có con đó. Chỉ có con MSP430F425IPM thôi.
                            longimi Tìm hiểu thêm về longimi
