Với phương châm phục vụ "CHẤT LƯỢNG TỐT, GIÁ CẢ HỢP LÝ".
Hiện tôi đang có một số lượng lớn linh kiện điện tử của một số hãng tên tuổi như TI, Cypress, Maxim, MicroChip... Trước là dùng cho công việc của bản thân, sau muốn cung cấp những linh kiện tốt cho anh em làm điện tử gần xa. Dưới đây là danh sách linh kiện.
1. Maxim-Dallas Semiconductor:
Ultra-High-Speed Flash Microcontroller
- DS89C450 - DIP40, PLCC44 (64K Flash, 1KRAM, 2UART...etc)
- DS89C430 - DIP40, PLCC44
- DS89C420 - DIP40, PLCC44
- DS1307 - DIP8, SOIC8
- MAX6962 TQFP32
(4-Wire Serially Interfaced 8 x 8 Matrix Graphic LED Drivers, The MAX6960–MAX6963 are compact cathode-row display drivers that interface microprocessors to 8 x 8 dot-matrix red, green, and yellow (R,G,Y) LED displays through a high-speed 4-wire serial interface.
The MAX6960–MAX6963 drive two monocolor 8 x 8 matrix displays, or a single RGY 8 x 8 matrix display with no external components. The driver can also be used with external pass transistors to control red, green, blue (RGB) and other displays at higher currents and voltages.)
2. Cypress semiconductor:
PSoC mix-signal- CY8C29466 DIP28,SOIC 28
- CY8C27443 DIP28,SOIC28
- CY8C27243 DIP28,SOIC28
- CY8C27143 DIP28,SOIC28
- CY8C24994 QFN
- CY8C24423 DIP,SOIC
- CY8C24223 DIP,SOIC
- CY8C24123 DIP8,SOIC8
USB High-Speed Peripherals Product
- CY7C68013 TSSOP56,TQFP100
- CY7C68013A TSSOP56,TQFP100
- CY7C68014 TSSOP56,TQFP100
USB Low-Speed Peripherals Product
- CY7C63813 DIP,SOIC
- CY7C63001 DIP,SOIC
WirelessUSB Modules- CYWM3695
Features
The CYWM6935 LR(TM) 2.4-GHz DSSS Radio SoC Module includes radio (CYWUSB6935) , antenna, and all external components
Complete Radio Module with Dual PCB Trace Antennas
Operates in the unlicensed Industrial, Scientific, and Medical (ISM) band (2.4 GHz-2.483 GHz)
-95-dBm receive sensitivity
Up to 0-dBm output power
Range of up to 50 meters or more
Data throughput of up to 62.5 kbits/sec
SPI microcontroller interface (up to 2 MHz data rate)
Operating voltage from 2.7V to 3.6V
For more, see Pdf
3. TI
Some ADC and Power (high current) Module... sẽ cập nhật sau
4. MicroChip
- PIC18F2550 DIP, ,SOIC
- PIC18F4550 DIP
- PIC16F917 DIP
- ENC28J60 DIP,SOIC (Serial Ethernet)
Xin vui lòng liên hệ:
Nguyễn Chí Linh
Mobile: 0988006696
Email: linhnc308@gmail.com
YM: linhnc308
DC: Nhà 9 - Nghách 49/30 - Ngõ 49 - Phố Trần Cung - Hoàng Quốc Việt - HN
- Miễn phí vận chuyển trong nội thành HN khi mua với số lượng nhiều (>= 5)Các trường hợp mua lẻ, xin vui lòng đến theo địa chỉ trên hoặc điện thoại để hẹn địa điểm giao hàng (Tôi hiện làm việc tại tòa nhà Viglacera Tower, đối diện siêu thị BigC). Các bạn ở tỉnh xa sẽ nhận hàng theo hình thức chuyển phát nhanh, phí chuyển phát sẽ được cộng vào khi thanh toán.
- Hình thức thành toán có thể thông qua chuyển khoản ngân hàng hay chuyển tiền mặt.
Tài khoản Vietcombank:
Chủ tài khoản: Nguyễn Chí Linh
Số tài khoản : 0021001328130
Cập nhật ngày 05-09-2007
![67](http://dientuvietnam.net/forums/images/smilies/67.gif)
- MAX6962 TQFP32
- CY8C24994 QFN
Features
For more, see Pdf
3. TI
4. MicroChip
- PIC18F4550 DIP
- PIC16F917 DIP
Nguyễn Chí Linh
Mobile: 0988006696
YM: linhnc308
