● Control Method
● Serial Communication
● Encoder Interface
● IO connection
● Power Supply
● Other features
● Applications
- Advanced PID control method
- Feed Forward control to eliminate noises in industrial environment
- Industrial Pulse/Dir Mode, up to 150Khz pulse rate.
- Position Command Mode though serial interface.
- OverCurrent protection
- Modbus Protocol Stack
- RS-485 Half or Full Duplex Interface
- Serial Command to adjust PID and other parameters
- Fix Baud rate speed at 115200 bps
- Address select switch
● Encoder Interface
- 5V power supply for encoder module up to 200mA
- X2 or X4 encoder interface mode
- Encoder pulse rate supported up to 4Mhz (type DCSDTL-P) and 500Khz (type DCSDTL-A)
● IO connection
- Pulse/Dir insolated opto up to 1Mhz
- Drive Enable, Drive Error isolated opto
● Power Supply
- Motor power supply 12V-200VDC
- Controller power supply 12V-15VDC
● Other features
- Power Run, Error, Over Current indicator led
- Built in a Potentiometer for current prevention adjust
- Built up to 21 Ampere DC motor can be stand
● Applications
- Prcise position control in Automation, CNC, Robot…etc.e
