PID DC SERVO Driver
  • PID DC SERVO Driver
    ● Control Method
    • Advanced PID control method
    • Feed Forward control to eliminate noises in industrial environment
    • Industrial Pulse/Dir Mode, up to 150Khz pulse rate.
    • Position Command Mode though serial interface.
    • OverCurrent protection
    ● Serial Communication
    • Modbus Protocol Stack
    • RS-485 Half or Full Duplex Interface
    • Serial Command to adjust PID and other parameters
    • Fix Baud rate speed at 115200 bps
    • Address select switch
    ● Encoder Interface
    • 5V power supply for encoder module up to 200mA
    • X2 or X4 encoder interface mode
    • Encoder pulse rate supported up to 4Mhz (type DCSDTL-P) and 500Khz (type DCSDTL-A)
    ● IO connection
    • Pulse/Dir insolated opto up to 1Mhz
    • Drive Enable, Drive Error isolated opto
    ● Power Supply
    • Motor power supply 12V-200VDC
    • Controller power supply 12V-15VDC
    ● Other features
    • Power Run, Error, Over Current indicator led
    • Built in a Potentiometer for current prevention adjust
    • Built up to 21 Ampere DC motor can be stand
    ● Applications
    • Prcise position control in Automation, CNC, Robot…etc.e
    DC servo driver
    download manual link
    http://www.lyvatech.com/index.php?cid=newproduct&sub=11
      Lien Lac
      Xin liên hệ theo số địa chỉ sau:
      Ly Van Thuan
      tel: 098.8435.009
      Email: lvthuan27@yahoo.com
      Inocent Tìm hiểu thêm về Inocent
