PLC-ANALYZER pro is a software tool for logic analysis and registration of measured values
on facilities operated with a PLC (Programmable Logic Controller). It easily makes possible
acquisition, display, and evaluation of PLC signals of all types. Among others, these signals
include inputs, outputs, flags, timers, counters, and data words.
Equipped with the capabilities of a traditional logic analyzer, PLC-ANALYZER pro normally
requires no software or hardware modification of the PLC for capturing signal data. This is a
result of using the existing PLC protocol for data acquisition, whereby PLC-ANALYZER pro
simply uses the typical hookup of programming units via serial connection or automation
network. The programming unit (a PC) connected to the PLC can be used directly for data acquisition
without further modification.
With PLC-ANALYZER pro the user can record all internal PLC signals, for example flags or
timers, which are normally not accessible outside the PLC.
By using our special measurement interface AD_USB-Box® external voltage and current signals,
which are not available in the PLC, can be recorded also.
In this manual the MPI/PPI/PROFIBUS driver for Siemens SIMATIC S7 was selected in order
to demonstrate program operation. The essential facts apply also to all other available PLC drivers,
e.g. the ETHERNET driver for Siemens SIMATIC S7 or the AS511 driver for Siemens
SIMATIC S5. You will find specific comments on the particularities of other PLC drivers in the
corresponding driver appendix. It is important that you read the appropriate driver appendix
before using a PLC driver. Please pay attention to the highlighted warnings on the possible dangers
associated with the use of PLC-ANALYZER pro.
Code:
http://rapidshare.com/files/9174233/plc-analyzer5.zip Zip Password: www.kontrolkalemi.com
