Hỏi về giao tiếp RC522 với at89!
  • Hỏi về giao tiếp RC522 với at89!
    Minh giao tiếp RC522 với 8051 qua UART
    mô phỏng thì ok còn thực tế thì ko như ý muốn
    mong ae giúp đỡ.
    #include <REGX51.H>
    unsigned char x;
    #define LCD_D4 P0_4
    #define LCD_D5 P0_5
    #define LCD_D6 P0_6
    #define LCD_D7 P0_7
    #define LINE_1 0x80
    #define LINE_2 0xC0
    #define CLEAR_LCD 0x01
    #define LCD_RS P2_0
    #define LCD_RW P2_1
    #define LCD_E P2_2
    unsigned char card_id[12];
    unsigned char current_byte = 0;
    //unsigned int a[12];
    void delay_ms(unsigned int Time)
    unsigned int i,j,t;
    t=Time;
    for(i=0;i<t;i++)
    for(j=0;j<125;j++);
    void delay_us(unsigned int Time)
    unsigned int i,j;
    for(i=0;i<Time;i++)
    for(j=0;j<2;j++);
    void delay(unsigned int count) //if count = 1000 --> delay 1s (milisecond)
    int i,j;
    for(i=0;i<count;i++)
    for(j=0;j<1275;j++);
    void lcd1602_enable(void)
    LCD_E=1;
    delay_us(3);
    LCD_E=0;
    delay_us(5);
    // Ham Gui 4 Bit Du Lieu Ra LCD
    void lcd1602_send_4bit_data ( unsigned char cX )
    LCD_D4 = cX & 0x01;
    LCD_D5 = (cX>>1)&1;
    LCD_D6 = (cX>>2)&1;
    LCD_D7 = (cX>>3)&1;
    // Ham Gui 1 Lenh Cho LCD
    void lcd1602_send_command (unsigned char cX )
    lcd1602_send_4bit_data ( cX >>4 ); // send 4 bit high
    lcd1602_enable() ;
    lcd1602_send_4bit_data ( cX ); // send 4 bit low
    lcd1602_enable() ;
    // Ham Khoi Tao LCD
    void lcd1602_init ( void )
    lcd1602_send_4bit_data ( 0x00 );
    delay_ms(200);
    LCD_RS=0;
    LCD_RW=0;
    LCD_E=0; // che do gui lenh
    lcd1602_send_4bit_data ( 0x03 ); // ket noi 8 bit
    lcd1602_enable() ;
    lcd1602_enable () ;
    lcd1602_enable () ;
    lcd1602_send_4bit_data ( 0x02 ); // ket noi 4 bit
    lcd1602_enable() ;
    lcd1602_send_command( 0x2C ); // giao thuc 4 bit, hien thi 2 hang, ki tu 5x8
    lcd1602_send_command( 0x80);
    lcd1602_send_command( 0x0C); // cho phep hien thi man hinh
    lcd1602_send_command( 0x06 ); // tang ID, khong dich khung hinh
    lcd1602_send_command( CLEAR_LCD ); // xoa toan bo khung hinh
    // Ham Thiet Lap Vi Tri Con Tro
    void lcd1602_gotoxy(unsigned char x, unsigned char y)
    unsigned char address;
    if(!y)
    address = (LINE_1+x);
    else
    address = (LINE_2+x);
    delay_ms(3);
    lcd1602_send_command(address);
    delay_ms(1);
    // Ham Xoa Man Hinh LCD
    void lcd1602_clear(void)
    //delay_us(300);
    // Ham Gui 1 Ky Tu Len LCD
    void lcd1602_putchar ( unsigned int cX )
    LCD_RS=1;
    lcd1602_send_command( cX );
    LCD_RS=0;
    // Ham Gui 1 Chuoi Ky Tu Len LCD
    void lcd1602_puts(char *s)
    while (*s)
    lcd1602_putchar(*s);
    s++;
    void recieve() interrupt 4 // ngat truyen thông
    card_id[current_byte]=SBUF;
    RI=0; // reset co RI
    current_byte++;
    void main()
    P2_7 = 0;
    TMOD=0x20; //Enable Timer 1
    TH1=0XFD;
    SCON=0x50;
    TR1=1;
    EA=1;
    ES=1;
    P1 = 0;
    lcd1602_init();
    lcd1602_clear();
    lcd1602_gotoxy(0,0);
    lcd1602_puts("Card ID:");
    lcd1602_gotoxy(0,1);
    while(1)
    if(current_byte==12)
    P2_7=1;
    for(x=0;x<12;x++)
    lcd1602_putchar(card_id[x]);
    P1 = card_id[x];
    delay_ms(500);
    break;
    https://www.youtube.com/watch?v=Tb3YgvCbBxA
    Nguyên văn bởi quangminh Xem bài viết
    mong ae giúp đỡ.
    Không như ý muốn như thế nào ? Bác nói thế ai mà biết "thực tế" là thế nào.
    Chia cái "không như ý muốn" ra từng phần nhỏ rồi sửa từng phần nhỏ đó.
    Nếu chưa rành lập trình, thì cho chớp từng cái đèn một thôi. Sau đó hãy cho chớp hết.
      chào bác. không như ý muốn:
      1. phải cắm vào rút ra chân Tx mấy lần thì mới thấy xuất dữ liệu
      2. cùng 1 thẻ nhưng xuất dữ liệu ra khác nhau.
      mong bác giúp đỡ
        Bạn mua card chuyển RC522 sang Uart về để làm nha. Chứ bản thân giao tiếp RC522 qua chuẩn SpI rất rờm rà.
        http://dientuungdung.com/mach-chuyen...2-sang-uart
        Tel: 0983.497.310
        quangminh Tìm hiểu thêm về quangminh
