Xử lý hiển thị ký tự lên màn hình CRT thông qua VGA
  • Xử lý hiển thị ký tự lên màn hình CRT thông qua VGA
    Em đang làm đồ án tốt nghiệp mà mắc đoạn code này quá. Khônh hiểu người ta sử dụng như thế nào.
    Code:
      -- first BlockRAM
       RAMB4_S8_inst2 : RAMB4_S8
    generic map (
               --      03       0      02       0       01      0      00       0
    INIT_00 => X"FF80808080808080FF0101010101010180808080808080FF0000000000000000",
               --      07       0      06       0       05      0      04       0
    INIT_01 => X"80808080808080800101010101010101FF0000000000000000000000000000FF",
               --      0B       0      0A       0       09      0      08       0
    INIT_02 => X"0000000000000000000000000000000000000000000000000000000000000000",
               --      0F       0      0E       0       0D      0      0C       0
    INIT_03 => X"0000000000000000000000000000000000000000000000000000000000000000",
               --      13       0      12       0       11      0      10       0
    INIT_04 => X"0000000000000000000000000000000000000000000000000000000000000000",
               --      17       0      16       0       15      0      14       0
    INIT_05 => X"0000000000000000003810101010301000344854444444380000000000000000",
               --      1B       0      1A       0       19      0      18       0
    INIT_06 => X"007804043840403C007C40201008047C00000000000000000000000000000000",
               --      1F       0      1E       0       1D      0      1C       0
    INIT_07 => X"0000000000000000003C20100804443800285454544444440044447C44444438",
               --      23       0      22       0       21      0      20       0
    INIT_08 => X"0070484444444870004444281028444400384440404044380000000000000000",
               --      27       0      26       0       25      0      24       0
    INIT_09 => X"0000000000000000003844040810083C0008087C48281808007C40407840407C",
               --      2B       0      2A       0       29      0      28       0
    INIT_0A => X"004040407840407C001028444444444400000000000000000000000000000000",
               --      2F       0      2E       0       2D      0      2C       0
    INIT_0B => X"0000000000000000003844040478407C0044485078444478001010101010107C",
               --      33       0      32       0       31      0      30       0
    INIT_0C => X"004444447C44444400784444784444780000444C546444440000000000000000",
               --      37       0      36       0       35      0      34       0
    INIT_0D => X"000000000000000000384444784020180010101028444444003844445C404438",
               --      3B       0      3A       0       39      0      38       0
    INIT_0E => X"003028080808081C0044444444546C4400000000000000000000000000000000",
               --      3F       0      3E       0       3D      0      3C       0
    INIT_0F => X"00000000000000000038444438444438002020201008047C0038444444444444")
       port map (
          DO => cp0,     -- 8-bit data output
          ADDR => ADDR, -- 9-bit address input
          CLK => clkd,   -- Clock input
          DI => "00000000",     -- 8-bit data input
          EN =>'1',     -- RAM enable input
          RST => '0',   -- Synchronous reset input
          WE => '0'      -- RAM write enable input
      -- second BlockRAM
      RAMB4_S8_inst1 : RAMB4_S8
    generic map (
               --      43       0      42       0       41      0      40       0
    INIT_00 => X"0038101010101038004448506050484400000000000000000000000000000000",
               --      47       0      46       0       45      0      44       0
    INIT_01 => X"0000000000000000003008043844443800384464544C44380038444444444438",
               --      4B       0      4A       0       49      0      48       0
    INIT_02 => X"007C404040404040000000000000000000000000000000000000000000000000",
               --      4F       0      4E       0       4D      0      4C       0
    INIT_03 => X"0000000000000000000000007C00000000404040784444780000000000000000",
               --      53       0      52       0       51      0      50       0
               --      57       0      56       0       55      0      54       0
    INIT_05 => X"0000000000000000000000000000000000000000000000000000000000000000",
               --      5B       0      5A       0       59      0      58       0
    INIT_06 => X"0000000000000000000000000000000000000000000000000000000000000000",
               --      5F       0      5E       0       5D      0      5C       0
    INIT_07 => X"0000000000000000000000000000000000000000000000000000000000000000",
               --      63       0      62       0       61      0      60       0
    INIT_08 => X"0000000000000000000000000000000000000000000000000000000000000000",
               --      67       0      66       0       65      0      64       0
    INIT_09 => X"0000000000000000000000000000000000000000000000000000000000000000",
               --      6B       0      6A       0       69      0      68       0
    INIT_0A => X"0000000000000000000000000000000000000000000000000000000000000000",
               --      6F       0      6E       0       6D      0      6C       0
    INIT_0B => X"0000000000000000000000000000000000000000000000000000000000000000",
               --      73       0      72       0       71      0      70       0
    INIT_0C => X"0000000000000000000000000000000000000000000000000000000000000000",
               --      77       0      76       0       75      0      74       0
    INIT_0D => X"0000000000000000000000000000000000000000000000000000000000000000",
               --      7B       0      7A       0       79      0      78       0
    INIT_0E => X"0000000000000000000000000000000000000000000000000000000000000000",
               --      7F       0      7E       0       7D      0      7C       0
    INIT_0F => X"0000000000000000000000000000000000000000000000000000000000000000")
       port map (
          DO => cp1,     -- 8-bit data output
    còn đây là một đoạn nữa họ hiển thị mấy chữ như: F1-Stop Game, F2 - NEW GAME, A - MOVE LEFT, D - MOVE RIGHT, SPACE - ROTATE...
    Code:
     RAMB4_S4_S4_inst : RAMB4_S4_S4
    generic map (
              --                                1                               0
    INIT_00 => X"0000000000000000000000000000000000000000000000000000000000000000",
              --                                3                               2
    INIT_01 => X"0000000000000000000000000000000000000000000000000000000000000000",
              --                                5                               4
              --                                7                               6
    INIT_03 => X"00000000000000000000000000EEEC00000000000000000000000000000CCCCC",
              --                                9                               8
    INIT_04 => X"0000000000000000000000000AEEEC0000000000000000000000000AAAAAEC00",
              --                               11                              10
    INIT_05 => X"0000000000000000000000000AEEE0DD0000000000000000000000000A00EC00",
              --                               13                              12
    INIT_06 => X"0000000000000000000000F0000F00DD0000000000000000000000000A000D0D",
              --                               15                              14
    INIT_07 => X"00000000000000000000000F0F09D00D0000000000000000000000F000F90D0D",
              --                               17                              16
    INIT_08 => X"00000000000000000000000F0F090000000000000000000000000000F0090000",
              --                               19                              18
    INIT_09 => X"0000000000000000000000F0000F00000000000000000000000000F000F90000",
       port map (
          DOA => DOA,     -- Port A 4-bit data output
          DOB => DOB,     -- Port B 4-bit data output
          ADDRA => ADDRA, -- Port A 10-bit address input
          ADDRB => ADDRB, -- Port B 10-bit address input
          CLKA => mclk,   -- Port A clock input
          CLKB => mclk,   -- Port B clock input
          DIA => DIA,  -- Port A 4-bit data input
          DIB => "0000",     -- Port B 4-bit data input
          ENA => '1',     -- Port A RAM enable input
          ENB => '1',     -- Port B RAM enable input
          RSTA => '0',   -- Port A Synchronous reset input
          RSTB => '0',   -- Port B Synchronous reset input
          WEA => WEA,     -- Port A RAM write enable input
          WEB => '0'      -- Port B RAM write enable input
        --textbox's BlockRAM
        RAMB4_S8_S8_inst : RAMB4_S8_S8
    generic map (
    INIT_00 => X"0007040404040404040404040404040404040404040404040404040404040401",
    --   F1 - STOP GAME
    INIT_01 => X"0007000000000000000000000000000000243A1C34004D442C1B004E00162B07",
    -- F2 - NEW GAME
    INIT_02 => X"000700000000000000000000000000000000243A1C34001D2431004E001E2B07",
    -- A - MOVE LEFT
    INIT_03 => X"0007000000000000000000000000000000002C2B244B00242A443A004E001C07",
    -- D - MOVE RIGHT
    INIT_04 => X"00070000000000000000000000000000002C3334432D00242A443A004E002307",
    -- SPACE - ROTATE
    INIT_05 => X"0007000000000000000000000000000000242C1C2C442D004E0024211C4D1B07",
    --  S - SPEED
    INIT_06 => X"000700000000000000000000000000000000000000002324244D1B004E001B07",
    -- TOP SCORE
    INIT_07 => X"00070000000000000000000000000000000000000000242D44211B004D442C07",
    -- YOUR SCORE
    INIT_08 => X"000700000000000000000000000000000000000000242D44211B002D3C443507",
    INIT_09 => X"0007000000000000000000000000000000000000000000000000000000000007",
    INIT_0A => X"0007000000000000000000000000000000000000000000000000000000000007",
    INIT_0B => X"0007000000000000000000000000000000000000000000000000000000000007",
    INIT_0C => X"0007000000000000000000000000000000000000000000000000000000000007",
    INIT_0D => X"0007000000000000000000000000000000000000000000000000000000000007",
    INIT_0E => X"0007000000000000000000000000000000000000000000000000000000000007",
    INIT_0F => X"0007050505050505050505050505050505050505050505050505050505050503")
       port map (
          DOA => DOAt,     -- Port A 8-bit data output
          DOB => DOBt,     -- Port B 8-bit data output
          ADDRA => ADDRAt, -- Port A 9-bit address input
          ADDRB => ADDRBt, -- Port B 9-bit address input
          CLKB => clkdiv,   -- Port B clock input
          DIA => DIAt, -- Port A 8-bit data input
          DIB => "00000000",     -- Port B 8-bit data input
          WEA => WEAt,     -- Port A RAM write enable input
    Ai hiểu đoạn code này thì chỉ bảo giùm em nhé. Giải thích rõ ràng một chút nhe.
    Giải thích cho em vì sao nó lại có những con số này và ý nghĩa của nó
    Liên hê email: nguyentrongvinh79@gmail.com
    Em cảm ơn nhiều
vinhtk73 Tìm hiểu thêm về vinhtk73
