Help!!! Lỗi trong tạo FSM 1Hz từ clock 50Mhz trong VHDL
  • Help!!! Lỗi trong tạo FSM 1Hz từ clock 50Mhz trong VHDL
    Code em viết phía dưới các bác giúp em cái:
    Sao nó cứ báo warning không?
    Code:
    WARNING:Xst:647 - Input <Ck_50Mhz> is never used. This port will be preserved and left unconnected if it belongs to a top-level block or it belongs to a sub-block and the hierarchy of this sub-block is preserved.
    WARNING:Xst:1305 - Output <Ck_1Hz> is never assigned. Tied to value 0.
    WARNING:Xst:1293 - FF/Latch <FFd1> has a constant value of 0 in block <FSM>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1293 - FF/Latch <FFd2> has a constant value of 0 in block <FSM>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1293 - FF/Latch <FFd3> has a constant value of 0 in block <FSM>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1293 - FF/Latch <FFd4> has a constant value of 0 in block <FSM>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1290 - Hierarchical block <khoi_xung> is unconnected in block <fsm_bcd_1hz>. It will be removed from the design.
    WARNING:Xst:1293 - FF/Latch <FSM_FFd4> has a constant value of 0 in block <FSM_0-parent>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1896 - Due to other FF/Latch trimming, FF/Latch <FSM_FFd3> has a constant value of 0 in block <FSM_0-parent>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1896 - Due to other FF/Latch trimming, FF/Latch <FSM_FFd2> has a constant value of 0 in block <FSM_0-parent>. This FF/Latch will be trimmed during the optimization process.
    WARNING:Xst:1896 - Due to other FF/Latch trimming, FF/Latch <FSM_FFd1> has a constant value of 0 in block <FSM_0-parent>. This FF/Latch will be trimmed during the optimization process.
    Dưới đây là bài em làm:
    --Ck_50Mhz_1Hz:
    Code:
    library    IEEE;
        use IEEE.STD_LOGIC_1164.ALL;
    entity Ck_50Mhz_1Hz is
        port
        (    Ck_50Mhz    : in std_logic;
            Ck_1Hz        : out std_logic
    end Ck_50Mhz_1Hz;
    architecture behavioral of Ck_50Mhz_1Hz is
        begin
            process (Ck_50Mhz)
            variable count : integer  range 0 to 25000000;
            variable tg : std_logic:='0';
                begin
                        count :=0;
                        if rising_edge (Ck_50Mhz) then
                        if  count = 25000000 then
                                    count := 0;
                                    tg := not(tg);
                                    Ck_1Hz <= tg;
                        else         count := count +1;
                        end if;
                end if;
            end process;
    end behavioral;
    --FSM_BCD:
    Code:
    library IEEE;
        use ieee.std_logic_1164.all;
    entity FSM_BCD is
        port
        (    clk : in std_logic;
            res : in std_logic;
            out_cnt : out std_logic_vector (3 downto 0)
    end FSM_BCD;
    architecture beh of FSM_BCD IS
        type state_fsm is (     state0, state1, state2, state3,
                                    state4, state5, state6, state7,
                                    state8, state9, state10, state11,
                                    state12, state13, state14, state15);
        signal pr_state, nx_state: state_fsm;
        begin --beh;
            sync : process (clk, res)
                        begin
                            if(res='1') then pr_state <= state0;
                            elsif rising_edge(clk) then
                                pr_state <= nx_state;
                            end if;
                        end process sync;
            comb : process (pr_state)
                        begin
                            case (pr_state) is
                                when state0 =>  nx_state <= state1;
                                                out_cnt <= B"0000";
                                when state1 =>     nx_state <= state2;
                                                out_cnt <= B"0001";
                                when state2 =>     nx_state <= state3;
                                                out_cnt <= B"0010";
                                when state3 =>     nx_state <= state4;
                                                out_cnt <= B"0011";
                                when state4 =>     nx_state <= state5;
                                                out_cnt <= B"0100";
                                when state5 =>     nx_state <= state6;
                                                out_cnt <= B"0101";
                                when state6 =>     nx_state <= state7;
                                                out_cnt <= B"0110";
                                when state7 =>     nx_state <= state8;
                                                out_cnt <= B"0111";
                                when state8 =>     nx_state <= state9;
                                                out_cnt <= B"1000";
                                when state9 =>     nx_state <= state10;
                                                out_cnt <= B"1001";
                                when state10 => nx_state <= state11;
                                                out_cnt <= B"1010";
                                when state11 => nx_state <= state12;
                                                out_cnt <= B"1011";
                                when state12 => nx_state <= state13;
                                                out_cnt <= B"1100";
                                when state13 => nx_state <= state14;
                                                out_cnt <= B"1101";
                                when state14 => nx_state <= state15;
                                                out_cnt <= B"1110";
                                when state15 => nx_state <= state0;
                                                out_cnt <= B"1111";
                                when others    =>null;
                                end case;
                        end process comb;
        end beh;
    --FSM_BCD_1Hz:
    Code:
    library IEEE;
        use IEEE.STD_LOGIC_1164.all;
    entity fsm_bcd_1hz is
        port
        (    clk_50Mhz : in std_logic;
            reset : in std_logic;
            outs :out std_logic_vector (3 downto 0)
        end fsm_bcd_1hz;
    architecture beha of fsm_bcd_1hz is
        component FSM_BCD
        port
            res : in std_logic;
        end component;
    component Ck_50Mhz_1Hz
        port
        end component;
        signal clks :std_logic;
            BEGIN
            khoi_xung: Ck_50Mhz_1Hz
                            port map
                            (     Ck_50Mhz => clk_50Mhz,
                                Ck_1Hz => clks
            khoi_fsms : FSM_BCD
                            port map
                            (    clk => clks,
                                res =>reset,
                                out_cnt => outs
        end beha;
    Các bác giúp dùm e nha.
    Bạn dùng isim mô phỏng đi bạn.
    Chưa biết bò mà lo học ... đá banh!
    petdmdang Tìm hiểu thêm về petdmdang
