Nhờ các cao thủ VHDL giúp!
  • Nhờ các cao thủ VHDL giúp!
    Em có đoàn code VHDL sau, khi biên dịch file keysched thi no báo lỗi lạ quá, mong các anh chỉ giúp
    file keysched.vhd
    library ieee;
    use ieee.std_logic_1164.all;
    entity keysched is port
    key : in std_logic_vector(1 to 64);
    k1x,k2x,k3x,k4x,k5x,k6x,k7x,k8x,k9x,k10x,k11x,k12x ,k13x,k14x,k15x,k16x : out std_logic_vector(1 to 48)
    end keysched;
    architecture behaviour of keysched is
    signal
    c0x,c1x,c2x,c3x,c4x,c5x,c6x,c7x,c8x,c9x,c10x,c11x, c12x,c13x,c14x,c15x,c16x :
    std_logic_vector(1 to 28);
    signal
    d0x,d1x,d2x,d3x,d4x,d5x,d6x,d7x,d8x,d9x,d10x,d11x, d12x,d13x,d14x,d15x,d16x :
    component pc1
    port (
    c0x,d0x : out std_logic_vector(1 to 28)
    end component;
    component pc2
    port (
    c,d : in std_logic_vector(1 TO 28);
    k : out std_logic_vector(1 TO 48)
    end component;
    begin
    pc_1: pc1 port map ( key=>key, c0x=>c0x, d0x=>d0x );
    c1x<=To_StdLogicVector(to_bitvector(c0x) rol 1);
    d1x<=To_StdLogicVector(to_bitvector(d0x) rol 1);
    c2x<=To_StdLogicVector(to_bitvector(c1x) rol 1);
    d2x<=To_StdLogicVector(to_bitvector(d1x) rol 1);
    c3x<=To_StdLogicVector(to_bitvector(c2x) rol 2);
    d3x<=To_StdLogicVector(to_bitvector(d2x) rol 2);
    c4x<=To_StdLogicVector(to_bitvector(c3x) rol 2);
    d4x<=To_StdLogicVector(to_bitvector(d3x) rol 2);
    c5x<=To_StdLogicVector(to_bitvector(c4x) rol 2);
    d5x<=To_StdLogicVector(to_bitvector(d4x) rol 2);
    c6x<=To_StdLogicVector(to_bitvector(c5x) rol 2);
    d6x<=To_StdLogicVector(to_bitvector(d5x) rol 2);
    c7x<=To_StdLogicVector(to_bitvector(c6x) rol 2);
    d7x<=To_StdLogicVector(to_bitvector(d6x) rol 2);
    c8x<=To_StdLogicVector(to_bitvector(c7x) rol 2);
    d8x<=To_StdLogicVector(to_bitvector(d7x) rol 2);
    c9x<=To_StdLogicVector(to_bitvector(c8x) rol 1);
    d9x<=To_StdLogicVector(to_bitvector(d8x) rol 1);
    c10x<=To_StdLogicVector(to_bitvector(c9x) rol 2);
    d10x<=To_StdLogicVector(to_bitvector(d9x) rol 2);
    c11x<=To_StdLogicVector(to_bitvector(c10x) rol 2);
    d11x<=To_StdLogicVector(to_bitvector(d10x) rol 2);
    c12x<=To_StdLogicVector(to_bitvector(c11x) rol 2);
    d12x<=To_StdLogicVector(to_bitvector(d11x) rol 2);
    c13x<=To_StdLogicVector(to_bitvector(c12x) rol 2);
    d13x<=To_StdLogicVector(to_bitvector(d12x) rol 2);
    c14x<=To_StdLogicVector(to_bitvector(c13x) rol 2);
    d14x<=To_StdLogicVector(to_bitvector(d13x) rol 2);
    c15x<=To_StdLogicVector(to_bitvector(c14x) rol 2);
    d15x<=To_StdLogicVector(to_bitvector(d14x) rol 2);
    c16x<=To_StdLogicVector(to_bitvector(c15x) rol 1);
    d16x<=To_StdLogicVector(to_bitvector(d15x) rol 1);
    pc2x1: pc2 port map ( c=>c1x, d=>d1x, k=>k1x );
    pc2x2: pc2 port map ( c=>c2x, d=>d2x, k=>k2x );
    pc2x3: pc2 port map ( c=>c3x, d=>d3x, k=>k3x );
    pc2x4: pc2 port map ( c=>c4x, d=>d4x, k=>k4x );
    pc2x5: pc2 port map ( c=>c5x, d=>d5x, k=>k5x );
    pc2x6: pc2 port map ( c=>c6x, d=>d6x, k=>k6x );
    pc2x7: pc2 port map ( c=>c7x, d=>d7x, k=>k7x );
    pc2x8: pc2 port map ( c=>c8x, d=>d8x, k=>k8x );
    pc2x9: pc2 port map ( c=>c9x, d=>d9x, k=>k9x );
    pc2x10: pc2 port map ( c=>c10x, d=>d10x, k=>k10x );
    pc2x11: pc2 port map ( c=>c11x, d=>d11x, k=>k11x );
    pc2x12: pc2 port map ( c=>c12x, d=>d12x, k=>k12x );
    pc2x13: pc2 port map ( c=>c13x, d=>d13x, k=>k13x );
    pc2x14: pc2 port map ( c=>c14x, d=>d14x, k=>k14x );
    pc2x15: pc2 port map ( c=>c15x, d=>d15x, k=>k15x );
    pc2x16: pc2 port map ( c=>c16x, d=>d16x, k=>k16x );
    end behaviour;
    file pc1.vhd
    library ieee;
    entity pc1 is port
    key : in std_logic_vector(1 TO 64);
    c0x,d0x : out std_logic_vector(1 TO 28)
    end pc1;
    architecture behavior of pc1 is
    signal XX : std_logic_vector(1 to 56);
    begin
    XX(1)<=key(57); XX(2)<=key(49); XX(3)<=key(41);
    XX(4)<=key(33); XX(5)<=key(25); XX(6)<=key(17);
    XX(7)<=key(9);
    XX(8)<=key(1); XX(9)<=key(58); XX(10)<=key(50);
    XX(11)<=key(42); XX(12)<=key(34); XX(13)<=key(26); XX(14)<=key(18);
    XX(15)<=key(10); XX(16)<=key(2); XX(17)<=key(59);
    XX(18)<=key(51); XX(19)<=key(43); XX(20)<=key(35); XX(21)<=key(27);
    XX(22)<=key(19); XX(23)<=key(11); XX(24)<=key(3);
    XX(25)<=key(60); XX(26)<=key(52); XX(27)<=key(44); XX(28)<=key(36);
    XX(29)<=key(63); XX(30)<=key(55); XX(31)<=key(47); XX(32)<=key(39);
    XX(33)<=key(31); XX(34)<=key(23); XX(35)<=key(15);
    XX(36)<=key(7); XX(37)<=key(62); XX(38)<=key(54);
    XX(39)<=key(46); XX(40)<=key(38); XX(41)<=key(30); XX(42)<=key(22);
    XX(43)<=key(14); XX(44)<=key(6); XX(45)<=key(61);
    XX(46)<=key(53); XX(47)<=key(45); XX(48)<=key(37); XX(49)<=key(29);
    XX(50)<=key(21); XX(51)<=key(13); XX(52)<=key(5);
    XX(53)<=key(28); XX(54)<=key(20); XX(55)<=key(12); XX(56)<=key(4);
    c0x<=XX(1 to 28); d0x<=XX(29 to 56);
    end behavior;
    file pc2.vhd
    library ieee;
    entity pc2 is port
    end pc2;
    architecture behavior of pc2 is
    signal YY : std_logic_vector(1 to 56);
    begin
    YY(1 to 28)<=c; YY(29 to 56)<=d;
    k(1)<=YY(14); k(2)<=YY(17); k(3)<=YY(11); k(4)<=YY(24); k(5)<=YY(1);
    k(6)<=YY(5);
    k(7)<=YY(3); k(8)<=YY(28); k(9)<=YY(15); k(10)<=YY(6); k(11)<=YY(21);
    k(12)<=YY(10);
    k(13)<=YY(23); k(14)<=YY(19); k(15)<=YY(12); k(16)<=YY(4);
    k(17)<=YY(26); k(18)<=YY(8);
    k(19)<=YY(16); k(20)<=YY(7); k(21)<=YY(27); k(22)<=YY(20);
    k(23)<=YY(13); k(24)<=YY(2);
    k(25)<=YY(41); k(26)<=YY(52); k(27)<=YY(31); k(28)<=YY(37);
    k(29)<=YY(47); k(30)<=YY(55);
    k(31)<=YY(30); k(32)<=YY(40); k(33)<=YY(51); k(34)<=YY(45);
    k(35)<=YY(33); k(36)<=YY(48);
    k(37)<=YY(44); k(38)<=YY(49); k(39)<=YY(39); k(40)<=YY(56);
    k(41)<=YY(34); k(42)<=YY(53);
    k(43)<=YY(46); k(44)<=YY(42); k(45)<=YY(50); k(46)<=YY(36);
    k(47)<=YY(29); k(48)<=YY(32);
    end behavior;
    Lỗi gì bạn cứ post lên mình xem cho. Còn code bạn viết trong tag code cho dễ nhìn chứ nhìn đống code đó ai mà hình dung nổi nhỉ ?
    Technical sale at WT Microelectronics S'pore
      Cảm ơn anh, em đã tìm ra được lỗi rùi!
      Luôn tiện cho em hỏi 1 lỗi khác: khi em viết chương trình mà có lẽ nó đoạn code nó dài quá hay nói cách khác là no xử lý nhiều lệnh, thì nó báo lỗi thế này anh:
      Error: No fif found, grenerating Report File
      Error:Project requires too many(3462/512) logic cells
      Error: Project requires too many(2266/512) shareable expanders
      Trường hợp này thì em bó tay rùi.Anh co thể giúp em được không?
        Nguyên văn bởi gacon_hihi Xem bài viết
        Bạn đã dùng quá nhiều cell, expander so với tài nguyên có sẵn, bạn xem lại phần lập trình nhé, lối như vậy nghĩa là bạn đang sử dụng nhiều hơn tài nguyên cho phép đó
          gacon_hihi Tìm hiểu thêm về gacon_hihi
            hôm nay, 07:44
