Các bác xem cho e lỗi nó báo thế này là như thế nào. e mới beginer FPGA nên ko hiểu
Code:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use work.shaft; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity MAIN is Port ( CLK : in STD_LOGIC; KEEP_GOING : in STD_LOGIC; START : in STD_LOGIC; STOP_HERE : in STD_LOGIC; F : in STD_LOGIC_VECTOR(4 DOWNTO 0); HERE : in STD_LOGIC; STB : in STD_LOGIC; FLR : out STD_LOGIC_VECTOR(4 DOWNTO 0); BRAKE : out STD_LOGIC; DN : out STD_LOGIC; UP : out STD_LOGIC; RUN : out STD_LOGIC; SLOW : out STD_LOGIC); end MAIN; architecture elevator_main of MAIN is SIGNAL sreg : std_logic_vector (2 downto 0); SIGNAL next_sreg : std_logic_vector (2 downto 0); CONSTANT CONT_DN : std_logic_vector (2 downto 0):="010"; CONSTANT CONT_UP : std_logic_vector (2 downto 0):="110"; CONSTANT DN_FULL : std_logic_vector (2 downto 0):="011"; CONSTANT DN_SLOW : std_logic_vector (2 downto 0):="001"; CONSTANT STOP_DN : std_logic_vector (2 downto 0):="000"; CONSTANT STOP_UP : std_logic_vector (2 downto 0):="100"; CONSTANT UP_FULL : std_logic_vector (2 downto 0):="111"; CONSTANT UP_SLOW : std_logic_vector (2 downto 0):="101"; SIGNAL NR_FLR,AT_FLR : std_logic; begin FRONTEND: shaft PORT MAP (F,HERE,STB,CLK,FLR,AT_FLR,NR_FLR); PROCESS (CLK, next_sreg) Begin if CLK='1' ANd CLK'event Then sreg<= next_sreg; end if; end process; PROCESS (sreg,AT_FLR,KEEP_GOING,NR_FLR,START,STOP_HERE) begin BRAKE<= '0' ; DN<= '0' ; RUN<= '0'; UP<= '0'; next_sreg <= CONT_DN; CASE sreg IS when CONT_DN => UP <= '0'; SLOW <= '0'; BRAKE <= '0'; RUN <= '1'; DN <= '1'; if (NR_FLR='0') Then next_sreg<=DN_FULL; else next_sreg<=CONT_DN; end if; when CONT_UP => SLOW<='0'; DN<='0'; BRAKE<='0'; RUN<='1'; UP<='1'; if (NR_FLR='0') then next_sreg<=UP_FULL; else next_sreg<=CONT_UP; end if; when DN_FULL=> up<='0'; SLOW<='0'; BRAKE<='0'; RUN<='1'; DN<='1'; if (NR_FLR='0') then next_sreg<=DN_FULL; end if; if (KEEP_GOING='0' AND nR_FLR='1') OR (STOP_HERE='1' AND NR_FLR='1') then next_sreg<=DN_SLOW; end if; IF (NR_FLR='1' AND STOP_HERE='0' AND KEEP_GOING='1') then next_sreg<=CONT_DN; end if; When DN_SLOW=> UP<='0'; BRAKE<='0'; RUN<='1'; DN<='1'; SLOW<='1'; IF (AT_FLR='1') THEN NEXT_SREG<=STOP_DN; ELSE next_sreg<=DN_SLOW; end if; when STOP_DN => UP<='0'; SLOW<='0'; RUN<='0'; BRAKE<='1'; DN<='1'; if (START='0') then next_sreg<=STOP_DN; end if; IF (START='1' AND KEEP_GOING='1') then next_sreg<=CONT_DN; end if; IF (START='1' and KEEP_GOING='0') then next_sreg<=STOP_UP; end if; When STOP_UP => SLOW<='0'; RUN<='0'; DN<='0'; BRAKE<='1'; UP<='1'; if (START='0') then next_sreg<=STOP_UP; end if; IF (START='1' And KEEP_GOING='0') then next_sreg<=STOP_DN; end if; When UP_FULL => SLOW<='0'; DN<='0'; BRAKE<='0'; RUN<='1'; UP<='1'; if (NR_FLR='0') then next_sreg<=UP_FULL; end if; IF (KEEP_GOING='0' And NR_FLR='1') or (STOP_HERE='1' and NR_FLR='1') then next_sreg<=UP_SLOW; end if; IF (NR_FLR='1' And STOP_HERE='0' and KEEP_GOING='1') then next_sreg<=CONT_UP; end if; When UP_SLOW => DN<='0'; BRAKE<='0'; RUN<='1'; UP<='1'; SLOW<='1'; if (AT_FLR='1') then next_sreg<=stop_UP; ELSE next_sreg<=UP_SLOW; end if; WHEN OTHERS => END CASE; end process; end elevator_main;
Code:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity shaft is Port ( f : in STD_LOGIC_VECTOR(4 DOWNTO 0); here : in STD_LOGIC; stb : in STD_LOGIC; clk : in STD_LOGIC; flr : out STD_LOGIC_VECTOR(4 DOWNTO 0); at_flr : out STD_LOGIC; nr_flr : out STD_LOGIC); end shaft; architecture shaft_logic of shaft is Begin PROCESS (f,stb,clk,here) begin if (stb'event and stb='0') then flr<=f; end if; if (clk'event and clk='1') then at_flr<=here; if stb='0' then nr_flr<='1'; elsif here='1' then nr_flr<='0'; --else here<=here; end if; end if; end process; end shaft_logic;
