Có ai biết cách Biên dịch 1 nhân uClinux trên ubuntu thì giúp tôi với
Biên dịch nhân uClinux
Làm theo hướng dẫn sau:
Building uClinux on Ubuntu
The article describes how to build uClinux on your Linux, i.g. Ubuntu…
For cross compile, we should install some cross toolchain…
$ wget http://www.uclinux.org/pub/uClinux/a...ls-20030314.sh
$ ./arm-elf-tools-20030314.sh
But it will pop up an error: tail: cannot open `+43′ for reading: No such file or directory
[FIX]:
$ sed ‘s/^tail /tail -n/’ arm-elf-tools-20030314.sh > arm-elf-tools-20030314.sh.tmp
$ chmod +x arm-elf-tools-20030314.sh.tmp
$ sudo ./arm-elf-tools-20030314.sh.tmp
Download uClinux source, and unzip it
$ wget http://www.uclinux.org/pub/uClinux/d...0040408.tar.gz
$ tar -zxvf uClinux-dist-20040408.tar.gz
To compile uClinux source, you have to install some library
$ sudo apt-get install ncurses-dev tcl tk
Change to the root of uClinux-dist, and enter those command to build it
$ make xconfig
$ make dep
$ make
Good idear to run image on skyeye if you donot have any board on hand.
Install skyeye as this:
$ sudo apt-get install skyeye
Also, skyeye needs an configure file: skyeye.conf, create it, and its content should be:
#skyeye config file sample
cpu: arm7tdmi
mach: at91
mem_bank: map=M, type=RW, addr=0×00000000, size=0×00004000
mem_bank: map=M, type=RW, addr=0×01000000, size=0×00400000
mem_bank: map=M, type=R, addr=0×01400000, size=0×00400000, file=./boot.rom
mem_bank: map=M, type=RW, addr=0×02000000, size=0×00400000
mem_bank: map=M, type=RW, addr=0×02400000, size=0×00008000
mem_bank: map=M, type=RW, addr=0×04000000, size=0×00400000
mem_bank: map=I, type=RW, addr=0xf0000000, size=0×10000000
What’s the file: boot.rom, create an link from images/romfs.img in the root directory of uClinux-dist
$ ln -s images/romfs.img boot.rom
And now, you could skyeye it as this:
$ skyeye -e linux-2.4.x/linux
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ | | | | / /
| |_| | |__| || | | | | |_| |/
| _______|_||_|_| |_|____|_/_/
|_|
GDB/ARMulator support by <davidm@snapgear.com>
For further information check:
uClinux
Execution Finished, Exiting
Sash command shell (version 1.1.1)
Từ chối trách nhiệm:
bởi halan99Zalo là ứng dụng được sử dụng phổ biến nhất Việt Nam hiện nay với khoảng 100 triệu người dùng và trở thành một trong các kênh marketing, bán hàng tiềm năng nhất tại Việt Nam. Bán hàng trên Zalo yêu cầu bạn phải thực sự am hiểu về...
Channel: Tin học ứng dụng
hôm nay, 14:12 -
16-12-2024, 11:26 -
Răn cưa vuông đây
15-12-2024, 23:36 -
15-12-2024, 18:24 -
14-12-2024, 22:02 -
14-12-2024, 19:58 -
14-12-2024, 18:51 -
bởi namlangnhoXin chào mọi người. E có sử dụng 1 cục nguồn tổ ong 12v-30A chạy đèn led xe trà sữa. Mà thợ thi công bị rò điện nên điện rò ra khung xe. E dùng đồng hồ đo điện ở khung xe và cả output thì thấy có dòng điện xoay chiều hơn 100v. Nên chạm...
14-12-2024, 00:12 -
bởi Manh.n.trCác bác cho em hỏi cách điều chế xung răng cưa sang xung vuông với ạ. Em đang thấy khó ạ...
13-12-2024, 20:46 -
Trả lời cho hỏi về thiết kế mạch tuần tự trên proteusbởi Hatruong1309
12-12-2024, 00:33 -
