[Hỏi] Cảm biến siêu âm srf05 dùng stm32f4 bị tràn timer
  • [Hỏi] Cảm biến siêu âm srf05 dùng stm32f4 bị tràn timer
    mình đang làm đo khoảng cách bằng cảm biến siêu âm srf05 nhưng bị tràn timer nên chỉ đếm đc tới 65535 thôi... ae nào rành giúp mình đi... hjxhjx
    main.c
    PHP Code:
    #include "stm32f4_discovery.h"
    TIM_ICInitTypeDef  TIM_ICInitStructure;
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    void TIM_Config(void);
    void Delay(__IO uint32_t time)
    /*Delay is in milliseconds*/
    time=time*80000;
      while(
    time--)
    int main(void)
    /* TIM Configuration */
    TIM_Config();
    /* TIM4 configuration: PWM Input mode ------------------------
         The external signal is connected to TIM4 CH2 pin (PB.07),
         The Rising edge is used as active edge,
         The TIM4 CCR2 is used to compute the frequency value
         The TIM4 CCR1 is used to compute the duty cycle value
    TIM_ICInitStructure.TIM_Channel TIM_Channel_2;
    TIM_ICInitStructure.TIM_ICPolarity TIM_ICPolarity_Rising;
    TIM_ICInitStructure.TIM_ICSelection TIM_ICSelection_DirectTI;
    TIM_ICInitStructure.TIM_ICPrescaler TIM_ICPSC_DIV1;
    TIM_ICInitStructure.TIM_ICFilter 0x0;
    TIM_PWMIConfig(TIM4, &TIM_ICInitStructure);
    /* Select the TIM4 Input Trigger: TI2FP2 */
    TIM_SelectInputTrigger(TIM4TIM_TS_TI2FP2);
    /* Select the slave Mode: Reset Mode */
    TIM_SelectSlaveMode(TIM4TIM_SlaveMode_Reset);
    TIM_SelectMasterSlaveMode(TIM4,TIM_MasterSlaveMode_Enable);
    /* Enable the CC2 Interrupt Request */
    TIM_ITConfig(TIM4TIM_IT_CC2ENABLE);
    STM_EVAL_LEDInit(LED3);
    STM_EVAL_LEDInit(LED4);
    GPIO_InitTypeDef GPIO_InitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    /* TIM4 clock enable */
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4ENABLE);
    /* GPIOB clock enable */
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOBENABLE);
    /* TIM4 chennel2 configuration : PB.07 */
    GPIO_InitStructure.GPIO_Pin   GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Mode  GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_Speed GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_OType GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd  GPIO_PuPd_UP ;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    TIM_TimeBaseStructure.TIM_Period 4200 1;
    /* Connect TIM pin to AF2 */
    GPIO_PinAFConfig(GPIOBGPIO_PinSource7GPIO_AF_TIM4);
    /* Enable the TIM4 global Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel TIM4_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority 1;
    NVIC_InitStructure.NVIC_IRQChannelCmd ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    TIM_TimeBaseStructure.TIM_Period 4;
    TIM_TimeBaseStructure.TIM_Prescaler 360;
    TIM_TimeBaseStructure.TIM_ClockDivision TIM_CKD_DIV1;
    TIM_TimeBaseStructure.TIM_CounterMode TIM_CounterMode_Up
    TIM_Cmd(TIM4DISABLE);
    #ifdef  USE_FULL_ASSERT
    void assert_failed(uint8_tfileuint32_t line)
      while (
    1)
    #endif
    stm32f4xx_it.c
    PHP Code:
    #include "stm32f4xx_it.h"
    __IO uint16_t IC2Value 0;
    __IO uint16_t DutyCycle 0;
    __IO uint32_t Frequency 0;
    __IO uint16_t range;
    uint16_t cm;
    uint16_t time=0;
    void NMI_Handler(void)
    void HardFault_Handler(void)
      while (
    1)
    void MemManage_Handler(void)
      while (
    1)
    void BusFault_Handler(void)
      while (
    1)
    void UsageFault_Handler(void)
      while (
    1)
    void DebugMon_Handler(void)
    void SVC_Handler(void)
    void PendSV_Handler(void)
    void SysTick_Handler(void)
    uint16_t TIMERANGE1=100;
    uint16_t TIMERANGE=100;
    void TIM4_IRQHandler(void)
    RCC_ClocksTypeDef RCC_Clocks;
    RCC_GetClocksFreq(&RCC_Clocks);
    /* Clear TIM4 Capture compare interrupt pending bit */
    TIM_ClearITPendingBit(TIM4TIM_IT_CC2);
    STM_EVAL_LEDOn(LED3);
      while (
    1)
    STM_EVAL_LEDOn(LED4);
    Delay(5);
    STM_EVAL_LEDOff(LED4);
                while (!
    GPIO_ReadInputDataBit(GPIOBGPIO_Pin_7));
    TIM_Cmd(TIM4ENABLE);
                while (
    time++;
    range TIM_GetCounter(TIM4);
    time TIM4->CNT;
    range;
    cm range/47;
    TIM_SetCounter(TIM40);
    Delay(50);
    time 0;
    Nguyên văn bởi locthanh3005 Xem bài viết
    main.c
    PHP Code:
    time=time*80000;
      while(
    time--)
    int main(void)
    TIM_Config();
      while (
    1)
    #endif
    stm32f4xx_it.c
    PHP Code:
    uint16_t cm;
    uint16_t time=0;
      while (
    1)
      while (
    1)
      while (
    1)
      while (
    1)
      while (
    1)
    Delay(5);
                while (!
                while (
    time++;
    time TIM4->CNT;
    range;
    cm range/47;
    Delay(50);
    time 0;
    Mình không biết cậu đo bị tràn khi khoảng cách là bao nhiêu.nếu mạch hoạt động đúng thì tăng prescaler lên và sửa lại công thức tính khoảng cách chắc là ok.
      mình chỉ đo đang ở giới hạn là 14cm ak... mình mới học làm nên gà lắm
        thế là ok nhé. Lí do là tại cái bàn và mode nạp không chuẩn lắm+code viết không đúng chỗ. Thích dùng ngắt thì đó là ngắt ngoài nhé không phải ngắt của timer4 đâu.Nạp lại Prescaler cho nó chuẩn là ok rồi
          tks bạn nha... mà giờ thì có vấn đề xẩy ra rồi nè... lúc chân echo không nhận đc tính hiệu về thì chương trình nó chạy mãi mãi luôn... hjx
            thêm phần time out.đơn giản thôi mà.Có thể thêm một biến nữa để check time out hoặc kiểm tra luôn CNT của timer4 nếu vượt quá giá trị nào đó(giá trị này >CNT max lúc không gặp vật cản )để dừng vòng while
              srf05 tốt nhất cứ test trên oscilloscop đã, mấy module này sai số nhiều lăm
              locthanh3005 Tìm hiểu thêm về locthanh3005
                hôm nay, 07:44
