TFT 2.4' Với STM32F103VET6 MikroC ARM
  • TFT 2.4' Với STM32F103VET6 MikroC ARM
    Mình mới mua cái boad STM32F103VET6 mình thử lập trình TFT mãi mà không được. Mong có cao thủ nào làm được giúp với.
    PHP Code:
    sfr unsigned int  CUSTOM_TFT_DATAPORT;
    sbit  DATA0_TFT_DATAPORT at GPIOD_ODR.B14;
    sbit  DATA1_TFT_DATAPORT at GPIOD_ODR.B15;
    sbit  DATA2_TFT_DATAPORT at GPIOD_ODR.B0;
    sbit  DATA3_TFT_DATAPORT at GPIOD_ODR.B1;
    sbit  DATA4_TFT_DATAPORT at GPIOE_ODR.B7;
    sbit  DATA5_TFT_DATAPORT at GPIOE_ODR.B8;
    sbit  DATA6_TFT_DATAPORT at GPIOE_ODR.B9;
    sbit  DATA7_TFT_DATAPORT at GPIOE_ODR.B10;
    sbit  DATA8_TFT_DATAPORT at GPIOE_ODR.B11;
    sbit  DATA9_TFT_DATAPORT at GPIOE_ODR.B12;
    sbit  DATA10_TFT_DATAPORT at GPIOE_ODR.B13;
    sbit  DATA11_TFT_DATAPORT at GPIOE_ODR.B14;
    sbit  DATA12_TFT_DATAPORT at GPIOE_ODR.B15;
    sbit  DATA13_TFT_DATAPORT at GPIOD_ODR.B8;
    sbit  DATA14_TFT_DATAPORT at GPIOD_ODR.B9;
    sbit  DATA15_TFT_DATAPORT at GPIOD_ODR.B10;
    sfr unsigned int TFT_DATAPORT at CUSTOM_TFT_DATAPORT;
    //unsigned int TFT_DataPort= {GPIOD_ODR.B14,GPIOD_ODR.B15,GPIOD_ODR.B0,GPIOD_ODR.B1,GPIOE_ODR.B7,GPIOE_ODR.B8,GPIOE_ODR.B9,GPIOE_ODR.B10,GPIOE_ODR.B11,GPIOE_ODR.B12,GPIOE_ODR.B13,GPIOE_ODR.B14,GPIOE_ODR.B15,GPIOD_ODR.B8,GPIOD_ODR.B9,GPIOD_ODR.B10};
    sbit TFT_RST at GPIOE_ODR.B1;
    sbit TFT_RS at GPIOD_ODR.B11;
    sbit TFT_CS at GPIOD_ODR.B7;
    sbit TFT_RD at GPIOD_ODR.B4;
    sbit TFT_WR at GPIOD_ODR.B5;
    sbit TFT_BLED at GPIOD_ODR.B13;
    /////End Config TFT
    //sbit TFT_BLED at GPIOA_ODR.B9;
    void TFT_Set_Index_Custom(unsigned short index) {
    unsigned int temp;
    TFT_RS 0;
    // Write to port
    temp TFT_DataPort;
    temp &= 0xFF00;
    TFT_DataPort index temp;
    // Strobe
    TFT_WR 0;
    asm nop;
    TFT_WR 1;
    void TFT_Write_Command_Custom(unsigned short cmd) {
    unsigned int temp;
    TFT_RS 1;
    // Write to port
    temp TFT_DataPort;
    temp &= 0xFF00;
    TFT_DataPort cmd temp;
    // Strobe
    TFT_WR 0;
    asm nop;
    TFT_WR 1;
    void TFT_Write_Data_16bit_Custom(unsigned int _data) {
    TFT_RS 1;
    // Write to 16-bit port
    TFT_DataPort _data;
    // Strobe
    TFT_WR 0;
    asm nop;
    TFT_WR 1;
    void main() {
    TFT_BLED 1;
    TFT_Init_ILI9340(240320);
    TFT_Set_Active(&TFT_Set_Index_Custom, &TFT_Write_Command_Custom, &TFT_Write_Data_16bit_Custom);
    TFT_Fill_Screen(CL_RED);
    TFT_Dot(5050CL_BLACK);
    TFT_Write_Text("MENU MACHINE SETUP"110100);
    delay_ms(1000) ;
    while(
    1)
    Bạn dùng MikroC for ARM thì cho mình hỏi chút : Bạn đã thử hiển thị kí tự lên LCD 1602 chưa. Mình dùng code và mạch giống hệt trong Help mà ko dc, Lcd dùng loại 3v3
    gaby_boy Tìm hiểu thêm về gaby_boy
      hôm nay, 14:51
      hôm nay, 14:39
      hôm nay, 14:28
      Hôm qua, 20:26
      Hôm qua, 12:32
      20-02-2025, 11:52
      Cái khó bó cái...
      19-02-2025, 23:05
      19-02-2025, 21:27
