Chảo 4rum!
Em đang loay hoay giao tiếp giữa con MSP430FE425 và con SPI EEPROM 93LC86, đọc mãi datasheet--> viết code mà vẫn chưa đựoc, không tìm thấy điểm sai đâu cả. Con 93LC86 mạch cứng cấu hình chế độ x16.
Đây là code của e, xin mọi ng chỉ giúp:
E cảm ơn!
//Chuong trinh giao tiep USART_SPI giua msp430fe425 vs 93LC86
//19.12.2011
#include <msp430xe42x.h>
unsigned char LCD_num[11]={0x5F,0x50,0x3D,0x79,0x72,0x6B,0x6F,0x51,0x7F,0x7 B,0x80};//ma LCD SEQ0280
// 0 1 2 3 4 5 6 7 8 9 DOT'
//ma code cua 93LC86 mode x16
//_______funtion____SB+Opcode____A9A8_______
#define READ_code 0x18 // 00
#define WRITE_code 0x14 // 00
#define ERASE_code 0x1C // 00
#define EWEN_code 0x13 // 11
#define EWDS_code 0x10 // 00
unsigned char get_data[2]={0,0};
unsigned int get_data1;
unsigned char get_data1_high, get_data1_low;
void CLK_init(void)
// Xtal=32768Hz
SCFQCTL=SCFQ_4M;//0x7F--> N=1127,fDCO=(127+1)*32768=4.19Mhz
SCFI0= FN_4;// 0x10;range 3.2-25Mhz,/1
SCFI1=0x00;//tu dong chon va sua doi bang FLL+
FLL_CTL0=XCAP10PF;//0x10;DCO out devided, LFXT1=low,XCAP=10PF,cac dao dong ko loi
FLL_CTL1=FLL_DIV_1 ;//0x00;crystal input,SMCLK on,XT2 off,MCLK tu DCOCLK,SMCLK tu DCO,ACLK/1
void LCD_init(void)
LCDCTL=LCDSG0_3 + LCD4MUX+LCDON;//chon S0-->S23,4-MUX,ON
BTCTL=BT_fCLK2_ACLK_DIV256+BT_fLCD_512+BT_fCLK2_DI V128 ;
void LCD_clear(void)
LCDM1=LCDM2=LCDM3=LCDM4=LCDM5=LCDM6=LCDM7=LCDM8=LC DM9=LCDM10=LCDM11=LCDM12=0x00;
void delay(void)
int i;
for(i=0;i<=13000;i++);
//SPI
//chuong trinh cai dat SPI0
void SPI_init(void)
U0CTL=CHAR+SYNC+MM+SWRST;//8bit,SPI mode,master,reset
U0TCTL=SSEL1+SSEL0+STC+TXEPT;//canh len cua CLK, SMCLK4M,3pin mode,TX epmty
U0BR0=0x04;//baudrate=UCLK/U0BR=SMCLK/U0BR=4Mhz/4=1Mhz
U0BR1=0x00;
U0MCTL=0x00;
ME1 |=USPIE0;
U0CTL &=~SWRST;//disable softwear reset
P1SEL |=BIT6+BIT7;//SIMO0, SOMI0 selected
P1DIR |=BIT1+BIT3+BIT6;//P1.1 CS2,P1.3 SS(rf) P1.6 Master out
P1DIR &=~BIT7;//Master in
P2SEL |=BIT1;//P2.1 UCLK master out
P2DIR |=BIT1;
//SPI read/write
unsigned char SPI_rw(unsigned char data)
IFG1 &=~URXIFG0;//xoa flag RX
U0TXBUF=data; //write
while(!(IFG1 & URXIFG0));// && (--limit_time > 0));//doi RX flag hoac limit_time=0
return U0RXBUF;//read
void EEPROM_ewen(void)//erase & write enable
P1OUT |=BIT1; //CS2=1
SPI_rw(EWEN_code);//0x13
SPI_rw(0x00);//
P1OUT &=~BIT1;//CS2=0
void EEPROM_ewds(void)//erase & write disable
P1OUT|=BIT1;
SPI_rw(EWDS_code);//0x10
SPI_rw(0x00);//low
P1OUT &=~BIT1;
void EEPROM_read(unsigned char add, unsigned char buff[2])
int i=0;
P1OUT |=BIT1;
SPI_rw(READ_code);//0x18
SPI_rw(add);
while((P1IN & 0x80)!=0);//wait bit7 SOMI=0
for(i=0;i<2;i++)//2 byte
buff[i]=SPI_rw(0);
P1OUT &=~BIT1;
void EEPROM_read(unsigned char add, unsigned int get_dt)
unsigned char byte1,byte2,byte3;
get_dt=0;
P1OUT |=BIT1;
SPI_rw(add);
byte1=SPI_rw(0);
byte2=SPI_rw(0);
byte3=SPI_rw(0);
P1OUT &=~BIT1;
get_dt |unsigned int)byte1)<<9 | ((unsigned int)byte2)<<1 | ((unsigned int)byte3)>>7;
void EEPROM_write(unsigned char add,unsigned int data)//2 byte data
unsigned char data_high, data_low;
data_high=(unsigned char)(data >>8);
data_low =(unsigned char)(data & 0x00FF);
P1OUT |=BIT1;
SPI_rw(WRITE_code);//0x14
SPI_rw(add);
SPI_rw(data_high);
SPI_rw(data_low);
SPI_rw(0x0);
//delay();
while((P1IN & 0x80)==0);//ready
delay();
P1OUT &=~BIT1;
LCDM9=LCD_num[data_high];
LCDM10=LCD_num[data_low];
void EEPROM_erase(int add)
P1OUT |=BIT1;
SPI_rw(ERASE_code);//0x1C
SPI_rw(add);
SPI_rw(0x0);
delay();
P1OUT &=~BIT1;
void main(void)
WDTCTL=WDTPW+WDTHOLD;
CLK_init();
LCD_init();
SPI_init();
P1OUT |=BIT3;//unselect RF modul
EEPROM_ewen();
EEPROM_erase(0xA2);
LCD_clear();
LCDM5=LCD_num[5];
delay();
EEPROM_write(0xA2,0x05);
LCDM6=LCD_num[6];
delay();
//test result on LCD
EEPROM_read(0xA2,get_data1);
get_data1_high=(unsigned char)(get_data1>>8);
get_data1_low=(unsigned char)(get_data1 & 0x00FF);
LCDM7=LCD_num[get_data1_high];
LCDM8=LCD_num[get_data1_low];
EEPROM_read(0xAA, get_data);
LCDM7=LCD_num[get_data[0]];
LCDM8=LCD_num[get_data[1]];
while(1);
//19.12.2011
void CLK_init(void)
// Xtal=32768Hz
void LCD_init(void)
void delay(void)
int i;
//SPI
void SPI_init(void)
U0BR1=0x00;
U0MCTL=0x00;
ME1 |=USPIE0;
P2DIR |=BIT1;
//SPI read/write
SPI_rw(0x00);//
P1OUT|=BIT1;
SPI_rw(0x00);//low
P1OUT &=~BIT1;
int i=0;
P1OUT |=BIT1;
SPI_rw(add);
buff[i]=SPI_rw(0);
P1OUT &=~BIT1;
get_dt=0;
P1OUT |=BIT1;
SPI_rw(add);
byte1=SPI_rw(0);
byte2=SPI_rw(0);
byte3=SPI_rw(0);
P1OUT &=~BIT1;
P1OUT |=BIT1;
SPI_rw(add);
SPI_rw(data_high);
SPI_rw(data_low);
SPI_rw(0x0);
//delay();
delay();
P1OUT &=~BIT1;
P1OUT |=BIT1;
SPI_rw(add);
SPI_rw(0x0);
delay();
P1OUT &=~BIT1;
void main(void)
CLK_init();
LCD_init();
SPI_init();
EEPROM_ewen();
EEPROM_erase(0xA2);
LCD_clear();
LCDM5=LCD_num[5];
delay();
LCDM6=LCD_num[6];
delay();
while(1);
