Nguyên văn bởi Elenor
ITX đã làm trước các vấn đề đó.
Ngay trong post #42 của ITX đã viết rõ và nêu cả nguồn dẫn chứng đáng tin cậy CANBus.pl - Magistrala CAN ( Controller Area Network )
Nguồn đáng tin cậy nữa là wikipedia
CAN bus - Wikipedia, the free encyclopedia
Trích lại một đoạn.
Physical layer
CAN bus electrical sample topology with terminator resistors
CAN bus (ISO 11898-1:2003) originally specified the link layer protocol with only abstract requirements for the physical layer, e.g., asserting the use of a medium with multiple-access at the bit level through the use of dominant and recessive states. The electrical aspects of the physical layer (voltage, current, number of conductors) were specified in ISO 11898-2:2003, which is now widely accepted. However, the mechanical aspects of the physical layer (connector type and number, colors, labels, pin-outs) have yet to be formally specified. As a result, an automotive ECU will typically have a particular—often custom—connector with various sorts of cables, of which two are the CAN bus lines. Nonetheless, several de facto standards for mechanical implementation have emerged, the most common being the 9-pin D-sub type male connector with the following pin-out:
pin 2: CAN-Low (CAN-)
pin 3: GND (Ground)
pin 7: CAN-High (CAN+)
pin 9: CAN V+ (Power)
This de facto mechanical standard for CAN could be implemented with the node having both male and female 9-pin D-sub connectors electrically wired to each other in parallel within the node. Bus power is fed to a node's male connector and the bus draws power from the node's female connector. This follows the electrical engineering convention that power sources are terminated at female connectors. Adoption of this standard avoids the need to fabricate custom splitters to connect two sets of bus wires to a single D connector at each node. Such nonstandard (custom) wire harnesses (splitters) that join conductors outside the node reduce bus reliability, eliminate cable interchangeability, reduce compatibility of wiring harnesses, and increase cost.
The absence of a complete physical layer specification (mechanical in addition to electrical) freed the CAN bus specification from the constraints and complexity of physical implementation. However it left CAN bus implementations open to inter-interoperability issues due to mechanical incompatibility.
Noise immunity on ISO 11898-2:2003 is achieved by maintaining the differential impedance of the bus at a low level with low-value resistors (120 ohms) at each end of the bus. However, when dormant, a low-impedance bus such as CAN draws more current (and power) than other voltage-based signaling busses. On CAN bus systems, balanced line operation, where current in one signal line is exactly balanced by current in the opposite direction in the other signal provides an independent, stable 0 V reference for the receivers. Best practice determines that CAN bus balanced pair signals be carried in twisted pair wires in a shielded cable to minimize RF emission and reduce interference susceptibility in the already noisy RF environment of an automobile.
ISO 11898-2 provides some immunity to common mode voltage between transmitter and receiver by having a 0 V rail running along the bus to maintain a high degree of voltage association between the nodes. Also, in the de facto mechanical configuration mentioned above, a supply rail is included to distribute power to each of the transceiver nodes. The design provides a common supply for all the transceivers. The actual voltage to be applied by the bus and which nodes apply to it are application-specific and not formally specified. Common practice node design provides each node with transceivers which are optically isolated from their node host and derive a 5 V linearly regulated supply voltage for the transceivers from the universal supply rail provided by the bus. This usually allows operating margin on the supply rail sufficient to allow interoperability across many node types. Typical values of supply voltage on such networks are 7 to 30 V. However, the lack of a formal standard means that system designers are responsible for supply rail compatibility.
ISO 11898-2 describes the electrical implementation formed from a multi-dropped single-ended balanced line configuration with resistor termination at each end of the bus. In this configuration a dominant state is asserted by one or more transmitters switching the CAN- to supply 0 V and (simultaneously) switching CAN+ to the +5 V bus voltage thereby forming a current path through the resistors that terminate the bus. As such the terminating resistors form an essential component of the signalling system and are included not just to limit wave reflection at high frequency.
During a recessive state the signal lines and resistor(s) remain in a high impedances state with respect to both rails. Voltages on both CAN+ and CAN- tend (weakly) towards ½ rail voltage. A recessive state is only present on the bus when none of the transmitters on the bus is asserting a dominant state.
During a dominant state the signal lines and resistor(s) move to a low impedance state with respect to the rails so that current flows through the resistor. CAN+ voltage tends to +5 V and CAN- tends to 0 V.
Irrespective of signal state the signals lines are always in low impedance state with respect to one another by virtue of the terminating resistors at the end of the bus.
This signalling strategy differs significantly from other balanced line transmission technologies such as RS-422/3, RS-485, etc. which employ differential line drivers/ receivers and use a signalling system based on the differential mode voltage of the balanced line crossing a notional 0 V. Multiple access on such systems normally relies on the media supporting three states (active high, active low and inactive tri-state) and is dealt with in the time domain. Multiple access on CAN bus is achieved by the electrical logic of the system supporting just two states that are conceptually analogous to a ‘wired OR’ network.
pin 3: GND (Ground)
ITX tạm tóm tắt ý chính: ISO không chỉ quy định mức điện áp, họ còn quy định cả khả năng chống nhiễu, tốc độ, chịu lỗi và rất nhiều quy định khác, chính những quy định khắt khe này mà hiện nay không có bất kỳ một CAN 3v3 nào đạt ISO cả.
Cậu biết từ "conformance" nghĩa là gì không
conformance
sự phù hợp
sự tương hợp
sự tương thích
sự phù hợp
sự tương hợp
sự tương thích
compatible
Tính từ
Hợp nhau, tương hợp
they are never bosom friends, because they are never compatible
họ chẳng bao giờ là bạn thân của nhau, vì họ chẳng bao giờ hợp nhau
(tin học) tương thích
these dot-matrix printers are compatible with new generation PCs
các máy in kim này tương thích với các loại PC đời mới
Tính từ
Hợp nhau, tương hợp
"Nói chung không nên chơi chữ bạn ạ"
Tuy nhiên cái quan trọng nhất và thiết thực nhất.
Cậu hãy tìm được một con CAN 3v3 nào đạt chuẩn ISO 11898 hãy nêu ra
