Mạch khóa số PIC16F84
  • Mạch khóa số PIC16F84
    piccodelock_PIC16F84
    Code:
    '*  Name    : CodeLock.bas                                      *
    '*  Author  : LonelyCatSoft                                     *
    '*  Date    : 30.03.2012                                        *
    '*  Version : 1.0                                               *
    '*  Notes   : Programable Code Lock with the PIC-16F84          *
    'Ma khoa duoc nhap tu ban phim ma tran 4x3.
    'Mat khau mac dinh la: 1234
    'De thay doi mat khau hien tai, vi du la 1961, ta an: 1234*1961#1961#
    @ device  xt_osc, wdt_off, pwrt_on, protect_off
    RL1_ON_time con 1000 * 3  'sec. Relay ON time
    TrisA = 0  ' PORTA, all outputs
    PortA = 16 ' turn off Buzer
    OPTION_REG.7 = 0   ' PORTB Pullups.
    TrisB = 0000  ' PORTB.0-3 outputs, 4-7 inputs
    PortB = 0
    LD1 var PortA.2
    RL1 var PortA.3
    BUZ var portA.4
    cnt var byte
    key  var byte
    col  var byte
    row  var byte
    keycnt var byte
    pwOK var bit
    keybuf var byte[15]
    pwbuf var byte[4]
    EEPROM 0,[1,2,3,4] 'Default password 1,2,3,4 programmed at EEprom location 0..3
    Read 0, pwbuf[0]   'Copy password from EEprom address 0..3 in to pwbuf[0..3]
    Read 1, pwbuf[1]
    Read 2, pwbuf[2]
    Read 3, pwbuf[3]
    pwOK = 0
    keycnt = 0
    Main:
       high ld1
       gosub Chk_KEYPAD
       pause 1
    goto Main
    Chk_KEYPAD:
       for row = 0 to 3
          PORTB = (dcd row) ^ $f
          pause 1
          col = PORTB >> 4
          if (col <> $f) then  'key pressed
             key = (row * 3) + (ncd (col ^ $f))
             gosub Got_KEY
             key = 255
          endif
       next
    return
    Beep:
       low ld1
       low buz
       pause 40
       high buz
    return
    Got_KEY:
       gosub Beep
       while (PORTB >> 4) <> $f
          pause 1
       wend
       if key = 11 then key = 0
       keybuf[keycnt] = key
       gosub Chk_keycnt
    return
    Chk_PwOK:
       PwOK = 0
       if (keybuf[0] = pwbuf[0]) and (keybuf[1] = pwbuf[1]) and (keybuf[2] = pwbuf[2]) and (keybuf[3] = pwbuf[3]) then pwok = 1
    return
    Chk_NewPwOK:
       PwOK = 0
       if (keybuf[5] = keybuf[10]) and (keybuf[6] = keybuf[11]) and (keybuf[7] = keybuf[12]) and (keybuf[8] = keybuf[13]) then pwok = 1
    return
    Pw_Change:
       pwbuf[0] =  keybuf[5]
       pwbuf[1] =  keybuf[6]
       pwbuf[2] =  keybuf[7]
       pwbuf[3] =  keybuf[8]
       Write 0, pwbuf[0] 'Store new password to EEprom location 0..3
       Write 1, pwbuf[1]
       Write 2, pwbuf[2]
       Write 3, pwbuf[3]
    return
    Chk_keycnt:
       select case keycnt
          case 4
             gosub Chk_PwOK
             if pwOK then
                if keybuf[keycnt] = 12 then Access_OK
                if keybuf[keycnt] <> 10 then Clr_keybuf
                gosub Beep
             else
                goto Clr_keybuf
             endif
          case 9
             if keybuf[keycnt] <> 12 then Clr_keybuf
             gosub Beep
          case 14
             gosub Beep
             gosub Chk_NewPwOK
             if pwOK then
                gosub Beep
                gosub Pw_Change
                gosub Beep
                goto Clr_keybuf
             else
                goto Clr_keybuf
             endif
          case else
             if keybuf[keycnt] = 12 then Clr_keybuf
       end select
       keycnt = keycnt + 1
    return
    Access_OK:
       High RL1
       pause RL1_ON_time
       low RL1
    Clr_keybuf:
       for cnt = 0 to 14
          keybuf[cnt] = cnt
       next
       keycnt = 0
    goto Main
    end
    DOWNLOAD:
    piccodelock_PIC16F84.rar
    Nick yahoo: nguyenphuocho
    Mail:
    Web:
    PICKIT2
    Trên thực tế bạn nên dùng LED 7seg hoặc dùng LCD để hiển thị thông tin số nhập, và các số cần được mã hoá bằng phím * chẳng hạn, như vậy mới đúng là mạch khoá!
      Cái này là một cách khác, chứ làm giống mấy cái kia thì có gì khác đâu. Thích dùng mạch nào cũng được
      Mail:
      Web:
      PICKIT2
        Nhưng mình thấy nó không thực tế lắm, làm mà không có thực tế thì làm làm j chứ? Càng đơn giản mà hiệu quả bao giờ cũng là tiêu chí hàng đầu!
        lonelycat Tìm hiểu thêm về lonelycat
