em có đoạn code, mong các bác giúp đỡ
  • em có đoạn code, mong các bác giúp đỡ
    trinh dich MikroC
    #include"built_in.h"
    //Khai bao cac bien
    unsigned short cnt;
    unsigned short T_dat;
    unsigned short T_do;
    unsigned short Hang_chuc;
    unsigned short Hang_dv;
    unsigned short t2;
    unsigned int temp;
    unsigned int T;
    char *txt;
    float t1;
    //Cac tham so cua bo dieu khien
    float a0;
    float a1;
    float a2;
    float b1;
    float b2;
    //Cac bien qua trinh
    float ek;
    float rk;
    float rk_1;
    float rk_2;
    float uk;
    float M1;
    float M2;
    //Ham tinh dau ra
    float Caculate_PID(){
    ek = T_dat - T_do;
    rk = ek + M1;
    uk = a0*rk + M2;
    rk_2 = rk_1;
    rk_1 = rk;
    M1 = (-1)*(b1*rk_1 + b2*rk_2);
    M2 = a1*rk_1 + a2*rk_2;
    t2=0;
    return uk;
    //Ham phuc vu ngat timer1
    void interrupt() {
    cnt++ ;
    PIR1.TMR1IF = 0; // clear TMR1IF
    T = T + Adc_Read(0);
    if (cnt==20) {
    temp = T/20;
    T_do = temp*100/614;
    T = 0;
    temp = 0;
    cnt = 0;
    t2 = 1;
    //Nap lai so dem
    TMR1H = 0x3C;
    TMR1L = 0xB0;
    void init_Timer1() {
    //dat thoi gian tre cho timer
    TMR1H = 0x3C;
    TMR1L = 0xB0;
    TRISB = 0;
    T1CON = 1;
    PIE1 = 1; // enable interrupts
    void init_LCD(){
    Lcd8_Config(&PORTD,&PORTB,0,2,1,7,6,5,4,3,2,1,0);
    txt = "T_dat:";
    Lcd8_Cmd(LCD_CURSOR_OFF); // Turn off cursor
    Lcd8_Out(1, 1, txt); // Print text on LCD
    txt = "T_do:";
    Lcd8_Out(2,1,txt);
    void update_LCD(){
    //update T_dat
    Hang_chuc = T_dat/10;
    Lcd8_Chr(1,8,48+Hang_chuc);
    Hang_dv = T_dat - Hang_chuc*10;
    Lcd8_Chr(1,9,48+Hang_dv);
    //update T_do
    Hang_chuc = T_do/10;
    Lcd8_Chr(2,8,48+Hang_chuc);
    Hang_dv = T_do - Hang_chuc*10;
    Lcd8_Chr(2,9,48+Hang_dv);
    void main() {
    ADCON1 = 0x80; // Configure analog inputs and Vref
    TRISA = 0xFF; // PORTA is input
    INTCON = 0xC0;
    PORTB = 0xF0;
    //Khoi tao gia tri ban dau cho cac bien
    cnt=0;
    T_dat=60;
    //khoi tao timer1
    init_Timer1();
    //Khoi tao LCD
    init_LCD();
    //Khoi tao PWM
    Pwm_Init(1000); // Initialize PWM module
    Pwm_Start(); // Start PWM
    while (1) {
    update_LCD();
    if (t2) {
    t1 = Caculate_PID()/220;
    Pwm_Change_Duty(t1*255); // set new duty ratio,
    Các bac thông dịch hộ em! Đang cần gấp
    Nguyên văn bởi dovanhiep Xem bài viết
    CT này bạn viết hay Copy-Paste mà nhờ thông dịch hộ???
    Tìm hiểu, chỗ nào ko hiểu thì hãy hỏi!
    Không TÔI là kẻ phàm phu
    Cái TÔI quá lớn làm ngu muội mình!
    - 0983.886.113
    dovanhiep Tìm hiểu thêm về dovanhiep
