adc pic 16f887
    hiih, ổn rồi bác ợ, thank bác nhiều nhé
      Khi ổn rồi thì lên post toàn bộ code mẫu lên để người đi sau ko gặp phải.
      Đó cũng là cách trả ơn những người đã giúp mình.
        ok, em mới tham gia nên bác chỉ bảo cho
          #include "16f887.h"
          #device 16F877*16ADC=8
          #fuses NOWDT,HS,NOPUT,NOPROTECT,BROWNOUT,LVP,NOCPD,NOWRT
          #define W 0
          #define F 1
          // register files
          #byte INDF =0x00
          #byte TMR0 =0x01
          #byte PCL =0x02
          #byte STATUS =0x03
          #byte FSR =0x04
          #byte PORTA =0x05
          #byte PORTB =0x06
          #byte PORTC =0x07
          #byte PORTD =0x08
          #byte PORTE =0x09
          #byte EEDATA =0x10C
          #byte EEADR =0x10D
          #byte EEDATH =0x10E
          #byte EEADRH =0x10F
          #byte ADCON0 =0x1F
          #byte ADCON1 =0x9F
          #byte ADRESH =0x9F
          #byte ADSESL =0x9F
          #byte PCLATH =0x0a
          #byte INTCON =0x0b
          #byte PIR1 =0x0c
          #byte PIR2 =0x0d
          #byte PIE1 =0x8c
          #byte PIE2 =0x8d
          #byte OPTION_REG =0x81
          #byte TRISA =0x85
          #byte TRISB =0x86
          #byte TRISC =0x87
          #byte TRISD =0x88
          #byte TRISE =0x89
          #byte EECON1 =0x18C
          #byte EECON2 =0x18D
          //DINH NGHIA BIT
          #bit ra5 =0x05.5
          #bit ra4 =0x05.4
          #bit ra3 =0x05.3
          #bit ra2 =0x05.2
          #bit ra1 =0x05.1
          #bit ra0 =0x05.0
          #bit rb7 =0x06.7
          #bit rb6 =0x06.6
          #bit rb5 =0x06.5
          #bit rb4 =0x06.4
          #bit rb3 =0x06.3
          #bit rb2 =0x06.2
          #bit rb1 =0x06.1
          #bit rb0 =0x06.0
          #bit rC7 =0x07.7
          #bit rC6 =0x07.6
          #bit rC5 =0x07.5
          #bit rC4 =0x07.4
          #bit rC3 =0x07.3
          #bit rC2 =0x07.2
          #bit rC1 =0x07.1
          #bit rC0 =0x07.0
          #bit rD7 =0x08.7
          #bit rD6 =0x08.6
          #bit rD5 =0x08.5
          #bit rD4 =0x08.4
          #bit rD3 =0x08.3
          #bit rD2 =0x08.2
          #bit rD1 =0x08.1
          #bit rD0 =0x08.0
          #bit rE2 =0x09.2
          #bit rE1 =0x09.1
          #bit rE0 =0x09.0
          #bit trisa5 =0x85.5
          #bit trisa4 =0x85.4
          #bit trisa3 =0x85.3
          #bit trisa2 =0x85.2
          #bit trisa1 =0x85.1
          #bit trisa0 =0x85.0
          #bit trisb7 =0x86.7
          #bit trisb6 =0x86.6
          #bit trisb5 =0x86.5
          #bit trisb4 =0x86.4
          #bit trisb3 =0x86.3
          #bit trisb2 =0x86.2
          #bit trisb1 =0x86.1
          #bit trisb0 =0x86.0
          #bit trisc7 =0x87.7
          #bit trisc6 =0x87.6
          #bit trisc5 =0x87.5
          #bit trisc4 =0x87.4
          #bit trisc3 =0x87.3
          #bit trisc2 =0x87.2
          #bit trisc1 =0x87.1
          #bit trisc0 =0x87.0
          #bit trisd7 =0x88.7
          #bit trisd6 =0x88.6
          #bit trisd5 =0x88.5
          #bit trisd4 =0x88.4
          #bit trisd3 =0x88.3
          #bit trisd2 =0x88.2
          #bit trisd1 =0x88.1
          #bit trisd0 =0x88.0
          #bit trise2 =0x89.2
          #bit trise1 =0x89.1
          #bit trise0 =0x89.0
          // INTCON Bits for C
          #bit gie = 0x0b.7
          #bit peie = 0x0b.6
          #bit tmr0ie = 0x0b.5
          #bit int0ie = 0x0b.4
          #bit rbie = 0x0b.3
          #bit tmr0if = 0x0b.2
          #bit int0if = 0x0b.1
          #bit rbif = 0x0b.0
          // PIR1 for C
          #bit pspif = 0x0c.7
          #bit adif = 0x0c.6
          #bit rcif = 0x0c.5
          #bit txif = 0x0c.4
          #bit sspif = 0x0c.3
          #bit ccp1if = 0x0c.2
          #bit tmr2if = 0x0c.1
          #bit tmr1if = 0x0c.0
          //PIR2 for C
          #bit cmif = 0x0d.6
          #bit eeif = 0x0d.4
          #bit bclif = 0x0d.3
          #bit ccp2if = 0x0d.0
          // PIE1 for C
          #bit adie = 0x8c.6
          #bit rcie = 0x8c.5
          #bit txie = 0x8c.4
          #bit sspie = 0x8c.3
          #bit ccp1ie = 0x8c.2
          #bit tmr2ie = 0x8c.1
          #bit tmr1ie = 0x8c.0
          //PIE2 for C
          #bit osfie = 0x8d.7
          #bit cmie = 0x8d.6
          #bit eeie = 0x8d.4
          // OPTION Bits
          #bit not_rbpu = 0x81.7
          #bit intedg = 0x81.6
          #bit t0cs = 0x81.5
          #bit t0se = 0x81.4
          #bit psa = 0x81.3
          #bit ps2 = 0x81.2
          #bit ps1 = 0x81.1
          #bit ps0 = 0x81.0
          // EECON1 Bits
          #bit eepgd = 0x18c.7
          #bit free = 0x18C.4
          #bit wrerr = 0x18C.3
          #bit wren = 0x18C.2
          #bit wr = 0x18C.1
          #bit rd = 0x18C.0
          //ADCON0
          #bit CHS0 =0x1F.3
          #bit CHS1 =0x1F.4
          #bit CHS2 =0x1F.5
          #use delay(Clock = 4000000)
          int8 temp = 0;
          int8 adc;
          #int_TIMER1
          void TIMER1_isr(void)
          temp++;
          if(temp == 4) //400us = 40% muc cao.
          output_high(PIN_D0);
          else if(temp == 6)
          output_low(PIN_D0); //600us = 60% muc thap.
          temp = 0;
          set_timer1(65335);
          void adc_read(void)
          setup_adc(ADC_CLOCK_DIV_2);
          setup_adc_ports(sAN0);
          set_ADC_channel(0);
          delay_us(10);
          while(true)
          adc==read_adc();
          output_B(adc);
          if( adc>128)
          { output_low(PIN_D1);}
          void main()
          //Khoi tao T1 va ngat.
          setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); //T1 dem xung noi, ti le chia 1
          enable_interrupts(INT_TIMER1);
          enable_interrupts(GLOBAL);
          set_timer1(65335); //Thach anh 8 MHz => CK may = 4/8 = 0,5us
          //100us ngat 1 lan = 200xung = 65535 - 65335
          //Thiet lap cac pin xuat nhap
          set_tris_d(0x00);
          set_tris_b(0xff);
          adc_read();//PORTD xuat du lieu.
          while(true);
            anh cho em hỏi những lệnh này hiểu thế nào ạ :
            và trong lệnh này : set_ADC_channel(0);
            giá trị của channel mình có thể chọn tùy mình phải không ạ hay bị ràng buộc gì không ạ .
            Và cho em hỏi đoạn này luôn ạ :
            - Cách để mình tính toán các giá trị nhập cho timer nha anh.
            Cảm ơn các anh.
              cái này hình như chưa đúng ạ :
              #include "16f887.h"
              - đang dùng thư viện pic 887 sao lại khai báo device 16F877 ạ.
              - cho em hỏi luôn giá trị đặt cho timer1 là 65335 là vì :
              16 bit là 65536-1 , trừ cho giá trị xung timer là ra giá trị đặt cho timer . Hiểu vậy đúng ko ạ
                - Cho em hỏi là trong CCS khi cần dùng chân nào đó làm ngõ ra/vào là analog hay digital thì có cần khai báo thanh ghi ANSEL và ANSELH hay không ạ
                  setup_adc(ADC_clock_div_2) là lệnh chọn xung clock , rồi chia cho 2 , tùy vào ứng dụng mà bạn muốn chia nhỏ tần số,
                  set_ADC_channel(0)là lệnh chọn kênh adc mà bạn muốn, kênh nào cũng được
                    Nguyên văn bởi langtu_711 Xem bài viết
                    anh cho em hỏi là :
                    - lập trình pic 887 dùng CCS thì có cần set các thanh ghi ANSEL và ANSEL hay không ạ ? hay cách khác ạ . Vì nếu dùng HTC thì phải set 2 thanh ghi này lên 1 thì là chân analog và 0 là digital anh ạ . Cảm ơn anh .
                      k cần bạn ạ, dùng htc mới cần
                      langtu_711 Tìm hiểu thêm về langtu_711
