hiih, ổn rồi bác ợ, thank bác nhiều nhé
adc pic 16f887
#include "16f887.h"
#device 16F877*16ADC=8
#fuses NOWDT,HS,NOPUT,NOPROTECT,BROWNOUT,LVP,NOCPD,NOWRT
#define W 0
#define F 1
// register files
#byte INDF =0x00
#byte TMR0 =0x01
#byte PCL =0x02
#byte STATUS =0x03
#byte FSR =0x04
#byte PORTA =0x05
#byte PORTB =0x06
#byte PORTC =0x07
#byte PORTD =0x08
#byte PORTE =0x09
#byte EEDATA =0x10C
#byte EEADR =0x10D
#byte EEDATH =0x10E
#byte EEADRH =0x10F
#byte ADCON0 =0x1F
#byte ADCON1 =0x9F
#byte ADRESH =0x9F
#byte ADSESL =0x9F
#byte PCLATH =0x0a
#byte INTCON =0x0b
#byte PIR1 =0x0c
#byte PIR2 =0x0d
#byte PIE1 =0x8c
#byte PIE2 =0x8d
#byte OPTION_REG =0x81
#byte TRISA =0x85
#byte TRISB =0x86
#byte TRISC =0x87
#byte TRISD =0x88
#byte TRISE =0x89
#byte EECON1 =0x18C
#byte EECON2 =0x18D
//DINH NGHIA BIT
#bit ra5 =0x05.5
#bit ra4 =0x05.4
#bit ra3 =0x05.3
#bit ra2 =0x05.2
#bit ra1 =0x05.1
#bit ra0 =0x05.0
#bit rb7 =0x06.7
#bit rb6 =0x06.6
#bit rb5 =0x06.5
#bit rb4 =0x06.4
#bit rb3 =0x06.3
#bit rb2 =0x06.2
#bit rb1 =0x06.1
#bit rb0 =0x06.0
#bit rC7 =0x07.7
#bit rC6 =0x07.6
#bit rC5 =0x07.5
#bit rC4 =0x07.4
#bit rC3 =0x07.3
#bit rC2 =0x07.2
#bit rC1 =0x07.1
#bit rC0 =0x07.0
#bit rD7 =0x08.7
#bit rD6 =0x08.6
#bit rD5 =0x08.5
#bit rD4 =0x08.4
#bit rD3 =0x08.3
#bit rD2 =0x08.2
#bit rD1 =0x08.1
#bit rD0 =0x08.0
#bit rE2 =0x09.2
#bit rE1 =0x09.1
#bit rE0 =0x09.0
#bit trisa5 =0x85.5
#bit trisa4 =0x85.4
#bit trisa3 =0x85.3
#bit trisa2 =0x85.2
#bit trisa1 =0x85.1
#bit trisa0 =0x85.0
#bit trisb7 =0x86.7
#bit trisb6 =0x86.6
#bit trisb5 =0x86.5
#bit trisb4 =0x86.4
#bit trisb3 =0x86.3
#bit trisb2 =0x86.2
#bit trisb1 =0x86.1
#bit trisb0 =0x86.0
#bit trisc7 =0x87.7
#bit trisc6 =0x87.6
#bit trisc5 =0x87.5
#bit trisc4 =0x87.4
#bit trisc3 =0x87.3
#bit trisc2 =0x87.2
#bit trisc1 =0x87.1
#bit trisc0 =0x87.0
#bit trisd7 =0x88.7
#bit trisd6 =0x88.6
#bit trisd5 =0x88.5
#bit trisd4 =0x88.4
#bit trisd3 =0x88.3
#bit trisd2 =0x88.2
#bit trisd1 =0x88.1
#bit trisd0 =0x88.0
#bit trise2 =0x89.2
#bit trise1 =0x89.1
#bit trise0 =0x89.0
// INTCON Bits for C
#bit gie = 0x0b.7
#bit peie = 0x0b.6
#bit tmr0ie = 0x0b.5
#bit int0ie = 0x0b.4
#bit rbie = 0x0b.3
#bit tmr0if = 0x0b.2
#bit int0if = 0x0b.1
#bit rbif = 0x0b.0
// PIR1 for C
#bit pspif = 0x0c.7
#bit adif = 0x0c.6
#bit rcif = 0x0c.5
#bit txif = 0x0c.4
#bit sspif = 0x0c.3
#bit ccp1if = 0x0c.2
#bit tmr2if = 0x0c.1
#bit tmr1if = 0x0c.0
//PIR2 for C
#bit cmif = 0x0d.6
#bit eeif = 0x0d.4
#bit bclif = 0x0d.3
#bit ccp2if = 0x0d.0
// PIE1 for C
#bit adie = 0x8c.6
#bit rcie = 0x8c.5
#bit txie = 0x8c.4
#bit sspie = 0x8c.3
#bit ccp1ie = 0x8c.2
#bit tmr2ie = 0x8c.1
#bit tmr1ie = 0x8c.0
//PIE2 for C
#bit osfie = 0x8d.7
#bit cmie = 0x8d.6
#bit eeie = 0x8d.4
// OPTION Bits
#bit not_rbpu = 0x81.7
#bit intedg = 0x81.6
#bit t0cs = 0x81.5
#bit t0se = 0x81.4
#bit psa = 0x81.3
#bit ps2 = 0x81.2
#bit ps1 = 0x81.1
#bit ps0 = 0x81.0
// EECON1 Bits
#bit eepgd = 0x18c.7
#bit free = 0x18C.4
#bit wrerr = 0x18C.3
#bit wren = 0x18C.2
#bit wr = 0x18C.1
#bit rd = 0x18C.0
//ADCON0
#bit CHS0 =0x1F.3
#bit CHS1 =0x1F.4
#bit CHS2 =0x1F.5
#use delay(Clock = 4000000)
int8 temp = 0;
int8 adc;
#int_TIMER1
void TIMER1_isr(void)
temp++;
if(temp == 4) //400us = 40% muc cao.
output_high(PIN_D0);
else if(temp == 6)
output_low(PIN_D0); //600us = 60% muc thap.
temp = 0;
set_timer1(65335);
void adc_read(void)
setup_adc(ADC_CLOCK_DIV_2);
setup_adc_ports(sAN0);
set_ADC_channel(0);
delay_us(10);
while(true)
adc==read_adc();
output_B(adc);
if( adc>128)
{ output_low(PIN_D1);}
void main()
//Khoi tao T1 va ngat.
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1); //T1 dem xung noi, ti le chia 1
enable_interrupts(INT_TIMER1);
enable_interrupts(GLOBAL);
set_timer1(65335); //Thach anh 8 MHz => CK may = 4/8 = 0,5us
//100us ngat 1 lan = 200xung = 65535 - 65335
//Thiet lap cac pin xuat nhap
set_tris_d(0x00);
set_tris_b(0xff);
adc_read();//PORTD xuat du lieu.
while(true);
anh cho em hỏi những lệnh này hiểu thế nào ạ :
và trong lệnh này : set_ADC_channel(0);
giá trị của channel mình có thể chọn tùy mình phải không ạ hay bị ràng buộc gì không ạ .
Và cho em hỏi đoạn này luôn ạ :
- Cách để mình tính toán các giá trị nhập cho timer nha anh.
Cảm ơn các anh.
cái này hình như chưa đúng ạ :
#include "16f887.h"
- đang dùng thư viện pic 887 sao lại khai báo device 16F877 ạ.
- cho em hỏi luôn giá trị đặt cho timer1 là 65335 là vì :
16 bit là 65536-1 , trừ cho giá trị xung timer là ra giá trị đặt cho timer . Hiểu vậy đúng ko ạ
anh cho em hỏi là :Nguyên văn bởi langtu_711 Xem bài viếtsetup_adc(ADC_clock_div_2) là lệnh chọn xung clock , rồi chia cho 2 , tùy vào ứng dụng mà bạn muốn chia nhỏ tần số,
set_ADC_channel(0)là lệnh chọn kênh adc mà bạn muốn, kênh nào cũng được
- lập trình pic 887 dùng CCS thì có cần set các thanh ghi ANSEL và ANSEL hay không ạ ? hay cách khác ạ . Vì nếu dùng HTC thì phải set 2 thanh ghi này lên 1 thì là chân analog và 0 là digital anh ạ . Cảm ơn anh .
hôm nay, 19:50 -
06-12-2025, 17:17 -
05-12-2025, 19:59 -
