LCD với PIC18f4550
  • LCD với PIC18f4550
    mình mới chuyển qua PIC18f, sau khi tham khảo chán chê mê mỏi các topic thì mình viết 1 đoạn code hiển thị lcd, tuy nhiên khi mô phỏng trên proteus thì ko thấy chạy, mình viết bằng C18, mong mọi người giúp đỡ
    #include <p18cxxx.h>
    #include<delays.h>
    #include<xlcd1.h>
    #include<xlcd1.c>
    #pragma config PWRT = ON,BOR = OFF,WDT = OFF,PBADEN = OFF
    unsigned char FullName[] ="NGUYEN TIEN TRIEN";
    unsigned char Birthday[]="Date:22/02/1991";
    void main(void)
    unsigned char config = 0xFF,i=0,addr=0,data=0;
    ADCON1 = 0xFF;
    config = EIGHT_BIT & LINES_5X7;
    PORTA=0;
    PORTB=0;
    //******** cau hinh LCD 8bit va ma tran hien thi 5x7 *********************************
    OpenXLCD(config);
    while(BusyXLCD()); //cho cho toi khi LCD het ban
    //*********** HIEN THI ********
    while (1)
    WriteCmdXLCD(0x06);
    SetDDRamAddr(0x00); //80
    while(BusyXLCD()); //cho ban
    putsXLCD(FullName); //hien thi FullName
    SetDDRamAddr(0xC0); //hien thi bat dau o dong thu 2
    putsXLCD(Birthday); //hien thi Birthday
    Delay10KTCYx(1000);
    đây là file xlcd1.h
    #ifndef __XLCD1_H
    #define __XLCD1_H
    /* PIC18 XLCD peripheral routines.
    * >>>>>>>>>>> MODIFIED BY DWD FOR THE PICDEM 2 PLUS LCD SETUP
    * Notes:
    * - These libraries routines are written to support the
    * Hitachi HD44780 LCD controller.
    * - The user must define the following items:
    * - The LCD interface type (4- or 8-bits)
    * - If 4-bit mode
    * - whether using the upper or lower nibble
    * - The data port
    * - The tris register for data port
    * - The control signal ports and pins
    * - The control signal port tris and pins
    * - The user must provide three delay routines:
    * - DelayFor18TCY() provides a 18 Tcy delay
    * - DelayPORXLCD() provides at least 15ms delay
    * - DelayXLCD() provides at least 5ms delay
    /* Interface type 8-bit or 4-bit
    * For 8-bit operation uncomment the #define BIT8
    /* #define BIT8 */
    /* When in 4-bit interface define if the data is in the upper
    * or lower nibble. For lower nibble, comment the #define UPPER
    /* #define UPPER */
    /* DATA_PORT defines the port to which the LCD data lines are connected */
    /* FOR PICDEM 2 PLUS - USE PORTB */
    #define DATA_PORT PORTB
    #define TRIS_DATA_PORT TRISB
    /* CTRL_PORT defines the port where the control lines are connected.
    * These are just samples, change to match your application.
    /* FOR PICDEM 2 PLUS - USE PORTA */
    #define RW_PIN LATAbits.LATA1 /* PORT for RW */
    #define TRIS_RW TRISAbits.TRISA1 /* TRIS for RW */
    #define RS_PIN LATAbits.LATA2 /* PORT for RS */
    #define TRIS_RS TRISAbits.TRISA2 /* TRIS for RS */
    #define E_PIN LATAbits.LATA0 /* PORT for E */
    #define TRIS_E TRISAbits.TRISA0 /* TRIS for E */
    /* Adjustment of XLCD Violin*/
    /* Display ON/OFF Control defines */
    #define DON 0b00001111 /* Display on */
    #define DOFF 0b00001011 /* Display off */
    #define CURSOR_ON 0b00001111 /* Cursor on */
    #define CURSOR_OFF 0b00001101 /* Cursor off */
    #define BLINK_ON 0b00001111 /* Cursor Blink */
    #define BLINK_OFF 0b00001110 /* Cursor No Blink */
    /* Cursor or Display Shift defines */
    #define SHIFT_CUR_LEFT 0b00010000 /* Cursor shifts to the left */
    #define SHIFT_CUR_RIGHT 0b00010100 /* Cursor shifts to the right */
    #define SHIFT_DISP_LEFT 0b00011000 /* Display shifts to the left */
    #define SHIFT_DISP_RIGHT 0b00011100 /* Display shifts to the right */
    /* Function Set defines */
    #define FOUR_BIT 0b00101100 /* 4-bit Interface */
    #define EIGHT_BIT 0b00111100 /* 8-bit Interface */
    #define LINE_5X7 0b00110000 /* 5x7 characters, single line */
    #define LINE_5X10 0b00110100 /* 5x10 characters, single line */
    #define LINES_5X7 0b00111000 /* 5x7 characters, multiple line */
    #define LINES_5X10 0b00111100 /* 5x10 characters */
    #define PARAM_SCLASS auto
    #define MEM_MODEL far /* Change this to near for small memory model */
    #endif
    ko có ai ạ
    trienst Tìm hiểu thêm về trienst
