Mã C# cho pp1 tạm gọi pp 3T
File txt dữ liệu và hình ảnh với giá trị 11001010 bit thấp phát trước.
Code:
using System; namespace FSK { class FSKClass { static int InputValue = 0; static int Phase = 0; static int PhaseShift = 0; static int FS = 8000; static int F0 = 1300; static int F1 = 2100; static int DeltaW0; static int DeltaW1; static System.IO.StreamWriter file; [STAThread] static void Main(string[] args) { DeltaW0 = Round(360*F0/FS); DeltaW1 = Round(360*F1/FS); InputValue = 202; file = new System.IO.StreamWriter("c:\\test.txt"); FSK(); file.Close(); Console.ReadLine(); } static void FSK() { for (int i=0; i<=40000;i++) { if ((i % 750) == 0) SampleInt(); if ((i % 5000) == 0) BaudInt(i); } } static void SampleInt() { Phase += PhaseShift; if (Phase >= 360) Phase = Phase - 360; file.WriteLine("{0}",LookupSin(Phase)); } static void BaudInt(int i) { if (i!=0) Phase += Round(PhaseShift*(i % 750)/750); if ((InputValue & 1) == 0) { PhaseShift = DeltaW0; } else { PhaseShift = DeltaW1; } Console.WriteLine("{0} {1}",InputValue & 1,PhaseShift); InputValue = InputValue >> 1; if (i!=0) Phase -= Round(PhaseShift*(i % 750)/750); } static int LookupSin(int degrees) { return Round((1+Math.Sin(Math.PI*degrees/180))*2048); } static int Round(double v) { return System.Convert.ToInt32(v); } } }
